Hello Xoox,
Please provide your update on this.
My obervations exactly matches yours - I have 6 Fibaro Motion v3.2 sensors.
I am only interested in Motion, Temperature and Lux.
So, I have added the controller to :-
- Group 1 (to get temp and lux - but I also receive "Burglar, Alarm Level, and Alarm Type") and
- Group 4 (in order to get just "Sensor" - detect only motion)
So, is there a way to turn off "Burglar", "Alarm Level" and "Alarm Type" ?
I am checking if my configuration file for Fibaro Motion v3.2 is correct. Kindly let me know where to find the correct FGMS config file.
thanks.
Fibaro Motion Sensor Unknown
henryd
Re: Fibaro Motion Sensor Unknown
I got it working. (finally).
I had to assign the groups correctly because i did not use security i had to do this:
If you don't care security you can assign only the group 1,4 and 5 with the controller and now the sensor behaves like the old version sensor.
For group changes you have to take in mind that this can take several hours. So be patient.
Ofcourse you also need to add the new .xml file as discussed before this reply.
I now have lux, temp, and motion sensor working in domoticz.
- the new and the old fibario motion sensor in group overview
- Schermafbeelding 2017-01-24 om 09.46.09.jpg (93.31 KiB) Viewed 854 times
Raspberry Pi / Arduino / Youless / Aeon z-stick gen5 / RFXCom / Fibaro sensor / Qubino flush 2 relays / MySensors.org
Bikey
- Domoticz version: 2020.x
Hi, do you also have the issue that if you assign group 1 not only you will receive the Temp and Lux, but also an "alarm level secure" in the log whenever motion is detected? See also this thread.
