Oh well... looked like something worth trying. I'll check back a year from now and see if things have improved.
Good luck.
I had no troubles getting open-zwave to work on a RPi3, see my makefiles in this post: Re: Domoticz on OpenWRTirimi wrote:Mmh, according to https://wiki.openwrt.org/toh/raspberry_ ... spberry_pi it seems RPi3 is still unsupported with "OpenWrt's Chaos Calmer" release.
For RPI3 recent openwrt's trunk version is required and actually I'm not able to compile OpenZWave due to strange compiler errors on that trunk version, hence no domoticz package possible for RPI3 , too.
Yes, indeed, your Makefiles are working fine. I'll update my feed, thank you very much !Timeless wrote: I had no troubles getting open-zwave to work on a RPi3, see my makefiles in this post: Re: Domoticz on OpenWRT
That's really strange ! From my point of view this tag does not match to archive content. If you unzip it , all files have the date 11.01.2016 and change log may be from January 16 , too !Timeless wrote:Mmh, v1.5 is from 15-Aug-2016 according to the Git Releases. We are only 6 days in 2017 hehe. I think using a trunk version for any software as a stable build is not always advised. And since I'm trying to get this in OpenWRT/LEDE a trunk version of anything will be rejected immediately.
vcgencmdAs far as I know openzwave is linked statically to domoticz according to CMake config. Since domoticz does not use the dynamic lib, this is not possible. I don't know how to configure the openwrt makefile that domoticz is build with dynamic use of openzwave lib.Timeless wrote:Have you once tried to update a new recompiled version of OpenZwave without recompiling and installing thesame version of Domoticz?
Users browsing this forum: suhanidash557 and 1 guest
