i ordered another 3 devices of these.
But when i add them to my network i'm getting some strange stuff.
If i check the log file, this is what i'm getting:
2016-12-30 17:34:19.391 Always, Dumping queued log messages
2016-12-30 17:34:19.392 Always,
2016-12-30 17:34:19.393 Always,
2016-12-30 17:34:19.393 Always, End of queued log message dump
2016-12-30 17:34:29.465 Error, Node021, ERROR: Dropping command, expected response not received after 1 attempt(s)
2016-12-30 17:34:29.465 Always,
2016-12-30 17:34:29.466 Always, Dumping queued log messages
2016-12-30 17:34:29.467 Always,
2016-12-30 17:34:29.467 Always, End of queued log message dump
2016-12-30 17:34:39.539 Error, Node021, ERROR: Dropping command, expected response not received after 1 attempt(s)
2016-12-30 17:34:39.540 Always,
2016-12-30 17:34:39.540 Always, Dumping queued log messages
2016-12-30 17:34:39.541 Always,
2016-12-30 17:34:39.542 Always, End of queued log message dump
and if i want to change some settings of this device, after a couple of seconds the 'old' values are back.
I have another wallplug i have for 2years and this one is working ol, but i noticed this is not a Zwave+ device
The 3 other one i have now are Zwave+
Should there be something updated?
My controller is Rpi B+ with Aeon Labs Z-Stick S2 and domoticz v3.6277 (latest beta)
Thank you
Fibaro Wall Plug FGWPE-102 ZW5 Topic is solved
ropske
- Domoticz version: V3_8394
Re: Fibaro Wall Plug FGWPE-102 ZW5
btw, i have this problem for all 3 new wall plugs
ropske
nevermind, just noticed my old wall plug was a FGWPE-101 and was using the xml file: fgwpe.xml
and when checking the manual, the index'es are ok according to this type.
but with the new wall plug FGWPE-102, this device is using the same xml file, but the index's according to the hardware manual are different, so will need to make a new xml file, will post it here when finished and tested
ropske
Here is the file:
upload this one to /config/fibaro/
and change /config/manufacturer_specific.xml
Original:
<Product type="0600" id="1000" name="FGWPE Wall Plug" config="fibaro/fgwpe.xml" />
<Product type="0602" id="1001" name="FGWPE Wall Plug" config="fibaro/fgwpe.xml" />
into new:
<Product type="0602" id="1001" name="FGWPE Wall Plug Zwave+" config="fibaro/fgwpezw5.xml" />
Now you can configure all settings correctly without receiving errors
Original:
into new:
ropske
btw, you will need to exclude your device after you installed these files
after this, you need to include your device again, so it loads the correct file!!
nizaga
Hi! Would this procedure work using the latest domoticz stable versión? I see you are running the latest beta, not the stable, i don't want to update to the latest beta yet... thanks
Enviado desde mi iPad utilizando Tapatalk Pro
ropske
this should work on stable and betanizaga wrote:Hi! Would this procedure work using the latest domoticz stable versión? I see you are running the latest beta, not the stable, i don't want to update to the latest beta yet... thanks
nizaga
I will try! Thanks
Enviado desde mi iPhone utilizando Tapatalk Pro
Gravityz
- Domoticz version: 2025.1
Yes and to make it complete You can do this 2 ways.
Method1:
like robske is describing and after that EXCLUDE/INCLUDE MODULE NECESSARY (the new module id with new config is put in the zwcfg_xxxxx.xml file under a new id)
eg if your highest zwave module id=16 and you do an exclude/include the module will be given id=17
and if you do not want to exclude/include
method2:
stop zwave/domoticz
edit zwcfg_xxxxx.xml file and delete the complete entry which belongs to the module ID you want reconfigured)
start domoticz (new device config file is put into zwcfg_xxxx.xml file under the same zwave id)
if you have a simple module which generates a couple of devices in domoticz first methode will work.
If you however have a more complex setting and do not want to loose the power consumption history of the device you might want to go for methode 2
Method1:
method2:
stop zwave/domoticz
