RFLink commands from Lua?
433Mhz opensource Receiver & Transmitter.
mikkel75
Post by mikkel75 »
Is it possible to send commands to the RFLink from Lua in a running Domoticz (on Linux)?
Thanks,
Mikkel
SweetPants
Re: RFLink commands from Lua?
Post by SweetPants »
What do you mean with "send commands to the RFLink"?
If a 'device', like a switch is learned through the RFLink, yes you can send 'on/off' commands in LUA.
mikkel75
Post by mikkel75 »
I mean can I send a "10;Kaku;00004d;1;OFF;" directly to the RFLink from Lua while it's enabled in Domoticz?
SweetPants
mikkel75 wrote:I mean can I send a "10;Kaku;00004d;1;OFF;" directly to the RFLink from Lua while it's enabled in Domoticz?
Don't think so, then you need direct acces to the serial port which is not supported as far as i know
mikkel75
Post by mikkel75 »
I would be a very nice feature (if direct access isn't possible) to be able to make a custom RFLink device/switch, where you may define the exact commands used for power ON/OFF/Dim etc...
sincze
Domoticz version: 2024.4
Re: RE: Re: RFLink commands from Lua?
Post by sincze »
mikkel75 wrote:I would be a very nice feature (if direct access isn't possible) to be able to make a custom RFLink device/switch, where you may define the exact commands used for power ON/OFF/Dim etc...
What would be the advantage of that feature? I am missing that one sorry :) please advise.
Sent from my SM-G925F using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
D3LTA
Domoticz version: 3.8153
Post by D3LTA »
Would love the feature too, ev1527 has no off only on.. when i can send commands directly it will save me from making dummy switches and just use the selector switch with the commands
