with sudo apt-get install Motion, i received the following result. How can I fix it Motion is not installed.....
pi@raspberrypi:~$ sudo apt-get install motion
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
libc6-dev : Depends: libc-dev-bin (= 2.19-18+deb8u3) but 2.19-18+deb8u6 is to be installed
motion : Depends: libavcodec56 (>= 6:11~beta1) but it is not going to be installed or
libavcodec-extra-56 (>= 6:11~beta1) but it is not going to be installed
Depends: libavformat56 (>= 6:11~beta1) but it is not going to be installed
Depends: libavutil54 (>= 6:11~beta1) but it is not going to be installed
Depends: libjpeg8 (>= 8c) but it is not going to be installed
Depends: libmysqlclient18 (>= 5.5.24+dfsg-1) but it is not going to be installed
Recommends: ffmpeg but it is not installable
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Could not install motion package
- Domoticz version: 4.10538
Re: Could not install motion package
Is your system up to date?
sudo apt-get update
sudo apt-get upgrade
sudo apt-get update
yes, did it before..
sorry, "sudo apt-get upgrade" install is also failed
pi@raspberrypi:~$ sudo apt-get upgrade
You might want to run 'apt-get -f install' to correct these.
libc6-dev : Depends: libc-dev-bin (= 2.19-18+deb8u3) but 2.19-18+deb8u6 is installed
E: Unmet dependencies. Try using -f.
pi@raspberrypi:~$
pi@raspberrypi:~$
What's the error report on the proposed command?
- Domoticz version: 2020.2
Have you tried only
apt-get -f install
apt-get -f install
Ubuntu 20.04 on ACEPC AK1 (previously RPi3b+)
Z-Stick Gen5, RFXtrx433E, Philips HUE Bridge, Yeelight, ESP8266 NodeMCU, Broadlink RM
dZvents, bash, php, Node-RED
