Remotec ZRC-90 Scene Master
Heursqem
Post by Heursqem »
I just bought this great remote control to initiate scene activation
https://www.robbshop.nl/scene-master
Only now I understand that this device is not supported by Domoticz
Any having plans to build the needed librabry?
tequila
Re: Remotec ZRC-90 Scene Master
Post by tequila »
oh, I was just about to buy one too...
DanM
Post by DanM »
Me too. did you get it to work?
DanM
Post by DanM »
Done some digging on this and it looks like the command class isnt yet supported by OZW. I have no idea how much work it is to add to Domoticz once implemented there, but for now it seems this is an OZW issue rather than one for here.
On the plus side.. there are quite a few devices turning up with this command class so I would expect an implementation to be relatively forthcoming.
tequila
Post by tequila »
that's a valuable information indeed. so no go for the moment. hopefully we will see things moving soon
tequila
Post by tequila »
by the way can't this be used as a simple switch via the Learn Light/Switch option? I am quite new to Domoticz and I am not quite sure how this works, but ZRC-90 is being sold as a 'scene' controller. For my purposes it would be good enough if it worked as a simple HW switch used in Events scripts.
DanM
Post by DanM »
I dont believe so (I think that the class must be properly recognised by OZW before it would work there (and even then Im not sure if the learn switch only applies to RFlink/RFXCOM).. but Id be happy to be wrong). Some of the 'scene class' stuff has a backwards compatability via the setup parameters but it looks like the ZRC-90 doesn't.
Edit / addition:
It might be possible to read the openzwave logs and react to that (asuming you can include it in the network). Its not as quick, but it might as least save a £40 device going into a drawer. Id also be very interested to see if your idea above works!
renerene
Post by renerene »
Heursqem wrote:Only now I understand that this device is not supported by Domoticz
That makes two of us. Aaarrrghhh.
Included node: 8
Unknown: type=0001, id=8510
Last post on Google Group is from june 2016
The device is listed on Open Zwave device website as XML, but I have no idea if this is usefull, or what to do with it.
Deydier
Post by Deydier »
Included node: 8
That makes three of us. Aaarrrghhh....
DanM
Post by DanM »
Looks like some work is being done on this on the openzwave end.
https://github.com/OpenZWave/open-zwave/pull/993
I'm keen to buy one of these so as soon as someone gets it working Id love it if they feedback here.
GiantLeap
Post by GiantLeap »
Last post on Github is 12 days ago. If you have this device, does it work partially, or not at all with Domoticz?
renerene
Post by renerene »
It does not work with Domoticz.
Allthough there is activity at github, I have got no clue when OZW will support it, or how much work is further needed to make it work.
eltinio
Post by eltinio »
I believe the detection of the remote has improved since the last domoticz update.
The node is now recognized as Remotec ZRC-90, the last seen date is changed when a button is pressed but I'm not able to make it appear at the devices page.
Based on what I've found on a nodon remote it needs to be grouped with the controller (I checked this) and tot switch scene type on the configuration tab.
The problem is that I don't have any configuration options other than poling enable/disable.
I've tried the control panel and have some options there but none of them result in the ability to use the remove.
Is the lack of configuration options because it's not fully supported or can those configurations be set somewhere else?
Domosapiens
Domoticz version: V3.5981
Post by Domosapiens »
Take a look at how other remote controls are integrated:
http://www.domoticz.com/forum/viewtopic.php?f=17&t=6262
and
http://www.domoticz.com/forum/viewtopic ... te+control
and Rob (Gizmocuz) made also a post on solution for the Minimote RC.
http://www.domoticz.com/forum/search.ph ... s=minimote
eltinio
Post by eltinio »
Thnx for the directions I would like to start tweaking the .xml file to get a configuration for the ZRC -90.
The problem I have is kinda dumb an that is that I don't know there the .xml files are located so I can edit them?
I've seen talk about the manufacturer_specific.xml file but I can't even find that.
Domosapiens
Look in your Domoticz/Config folder for manufacturer_specific.xml.
Remotec ZRC-90 is already included.
Look in the Remotec folder for zrc-90.xml: it does look as very minimal (work in progress)
Configure the ZRC-90 as secondary controller.
Create the connections via Hardware -> Z-Wave (primary) controller blue setup button -> Node management -> Groups & Network
There I expect 8 groups plus a lifeline to the primary controller.
There you can make direct connections between your ZRC-90 and other Z-Wave devices.
If you have more question ... take the effort to show pictures.
gizmocuz
Post by gizmocuz »
In the upcoming beta (#6788+), ''initial'' support for command_class_central_scene (0x5b) has been included
There is still a problem that the scenes are not automatically being created, and i think this is an openzwave issue, but openzwave thinks not
Anyway, if you are on the latest beta version, i suspect button '1' should work directly.
To get the other buttons working, stop domoticz, edit the zwave configuration file (zwcfg_xxxx.xml) and add the scenes manual inside the config file like:
search for
 			<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE"
then in between, add the (missing) scenes:
			<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="4" innif="true" scenecount="0">
				<Instance index="1" />
				<Value type="int" genre="system" instance="1" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
				<Value type="int" genre="user" instance="1" index="1" label="Scene 1" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
				<Value type="int" genre="user" instance="1" index="2" label="Scene 2" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
				<Value type="int" genre="user" instance="1" index="3" label="Scene 3" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
				<Value type="int" genre="user" instance="1" index="4" label="Scene 4" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
				<Value type="int" genre="user" instance="1" index="5" label="Scene 5" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
				<Value type="int" genre="user" instance="1" index="6" label="Scene 6" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
				<Value type="int" genre="user" instance="1" index="7" label="Scene 7" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
				<Value type="int" genre="user" instance="1" index="8" label="Scene 8" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
			</CommandClass>
DanM
Post by DanM »
Thanks for this. Not withstanding that this is very early days and therefore very much buyer beware.. would you expect this to work with other deivces that use the central scene class - Im thinking the new Wallmote for example?
Freemann
Domoticz version: >=Béta
Post by Freemann »
trying to add the lines to the "zwcfg_xxx" file, but after after "domoticz start" the lines gone.
Als my Remotec shows no config uptions in "Hardware>OpenZWave USB":
Screenshot - 07_05_2017 , 10_32_34.png (80.88 KiB) Viewed 9618 times
anybody an idea whats wrong here?
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
mcflyyy
Post by mcflyyy »
I have the same problem.
I can see the remote in device list but not the configuration below.
No scene or switch added ... Did you try to switch the remote in "secondary controller mode" ( no success for mee )
