[MyDomoAtHome] Support thread
epierre
Re: [MyDomoAtHome] Support thread
Post by epierre »
Hello sorampage,
the name of the device is not useful to me, I need the result of the following to know what domoticz makes of it:
http://domoticz_ip:8080/json.htm?type=devices&filter=all&used=true&order=Name
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
sorampage
Domoticz version: LastStab
Post by sorampage »
Pocke
Post by Pocke »
I have a problem with MyDomoAtHome. Everytime i try to access http://web:3002/devices it crashes.
Only thing i found in any log is this when i try to access the url.
Dec 22 11:47:06 web MDAH[2273]: undefined:702
Dec 22 11:47:06 web MDAH[2273]: SyntaxError: Unexpected token
Dec 22 11:47:06 web MDAH[2273]: error: Forever detected script exited with code: 1
Dec 22 11:47:06 web MDAH[2273]: error: Script restart attempt #22
Node version is 4.7
MDAH version 0.2.7
Running on ubuntu 16.04
domoticz v3.5877 (is running on a separate raspberry pi)
Is it possible to turn on some debug log to get more info?
Evelen
Domoticz version: 2.4538
Post by Evelen »
I have used MyDomoAtHome on Ubuntu server a long time now, but how do I update it to a newer version? can't find any info on that.
sudo apt-get update
sudo apt-get install MyDomoAtHome
gives me:
Uten navn.png (58.22 KiB) Viewed 4173 times
mangegbg
Domoticz version: 6226
Post by mangegbg »
Hi, I have problems setting up Domoticz and Mydomoathome on a Synology Diskstation. MDAH says D is on port 8084, local settings on D is on 8080 (web port is on 8084). What is the solution for this? Should I change port on Domoticz local settings or in MDAH somehow?
gerardosamara
Domoticz version: 4.10778
Post by gerardosamara »
When Installing the MDAH software Debian package .deb on a RPI3+Raspbian jessie :
wget -qo - http://www.e-nef.com/domoticz/mdah/gpg.key | sudo apt-key add -
The "gpg.key.4" file is downloaded ( when no" _qo" in the wget command) but then the following error is displayed : gpg : No valid OpenPGP data found.
Any advice please ?
Domoticz Beta V4.11763 in Debian 10 VM
Domoticz Beta V4.11763 in RPI3
MDAH 0.2.42 + Imperihome Pro V4.3.17
App Android Domoticz Lite V0.2.201
epierre
Post by epierre »
Pocke wrote:Hi,
not easily without modifying code, I removed lot of logs to save PI sdcards from premature weraing out, can you try uninstalling and reinstalling it ?
epierre
Post by epierre »
Evelen wrote:I have used MyDomoAtHome on Ubuntu server a long time now, but how do I update it to a newer version? can't find any info on that.
sudo apt-get update
gives me:
the 0.2.7 is the latest version, see here:
if you were on the perl version, or if you haven't set the debian update automatically see:
https://github.com/empierre/MyDomoAtHome
epierre
Post by epierre »
mangegbg wrote:Hi, I have problems setting up Domoticz and Mydomoathome on a Synology Diskstation. MDAH says D is on port 8084, local settings on D is on 8080 (web port is on 8084). What is the solution for this? Should I change port on Domoticz local settings or in MDAH somehow?
With jumbotroll we made an out of the box work on that, so the 8084 is the one being used.
epierre
Post by epierre »
gerardosamara wrote:Hello,
Any advice please ?
remove local gpg.key and retry, also this is -qO (in upper case)
gerardosamara
Any advice please ?
Thank you , I got it working
The problem was the -qO not in upper case
Pocke
Post by Pocke »
epierre wrote:
Pocke wrote:Hi,
I tried to remove and reinstall still same error. only another undefined number. now 653
epierre
Post by epierre »
ok, now have a look at your device logs through 'dmesg', try rebooting it and look at 'dmesg' regarding filesystem issues.
if not, try reinstall (remember to check it is effectively shut down before.
on command line, try to go to (from memory) /usr/local/lib/Mydomoathome/, find the mdah.js and try to manually launch it 'node mdah.js' and see what it says. (shut it down before)
danielchagasrs
Domoticz version: 3.5837
Post by danielchagasrs »
I installed the gateway and android App. It's all working fine, the android App is beautiful and works great (Domoticz App should be like that, or at least be similar to the mobile view, because the Domoticz mobile App is really ugly).
I didn't figure out how do I set different mobile devices with different user credentials with ImperiHome...
Gateway is running on the same Domoticz server, and 127.0.0.1 is configured at "local networks" under domoticz settings.
My domoticz has 2 users, each one with different devices associated, plus the admin with all devices.
When using imperihome app, everybody can see all devices, because I can't set the login (says unable to connect), so I have to use the logins defined inside config.json file, and then It has admin rights and sees all devices.
Does mdah support multiple users from Domoticz at this moment?
epierre
Post by epierre »
ok tricky, I would suggest running different mdah instances on different port (3002, 3003, 3004...), and in the domoticz auth use this user's auth.
for each, in the conf file, in the domoticz auth and even the one above use "auth": { "username": "admin", "password": "admin" }, (replace admin by this user's auth). Using twice this auth would do the trick.
danielchagasrs
[quote=]
[/quote]
It doesnt make any difference, because both services are running on the same raspberry pi, and 127.0.0.1 is added to local networks (no login/password) in domoticz setting, so, imperihome is always connection with full admin rights, no mater what credentials I fill inside de config.json file.
"app_name": "Automacao",
"auth": { "username": "imperihomeapplogin", "password": "imperihomeapppassword" }, <----- This works
"domoticz": {
"ssl": false,
"host": "127.0.0.1",
"port": "8888",
"path": "/",
"auth": { "username": "whatever", "password": "whatever-doesn'tmakeanydifference" } <----- This doesn't make any difference
"port": 3002,
"passcode": ""
Evelen
Post by Evelen »
sudo apt-get update
gives me:
Hi, Can you maybe give me the commands I need to run?
danielchagasrs
Evelen wrote:Hi, Can you maybe give me the commands I need to run?
It looks like you are trying to run 2 commands as one...
1) sudo apt-get remove node (not needed, since you dont have node)
2) curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
3) sudo apt-get install -y nodejs
gerardosamara
Not sure this is the right place ..
Configuration :
- RPi3
- Version stable v3.5877
- Imperihome V2.8.5 (android)
I have setup the security panel in Domoticz and it is displayed in the dashboard.
I can ARM DISARM from the utility place in Domoticz .
It is working also in the android Domoticz Lite app.
But there a problem in the android imperihome app , I can create the widget and the Arm mode is displayed in the widget but when clicking in the widget nothing is proposed to change the house mode as for the Domoticz app.
However changing the mode in security panel is correctly displayed in Imperihome ( armhome , arm away)
The imperihome widget #1 is used (from the top of the screen) , the widget #2 does not worked , the widget #3 is the same than widget #1 with text instead of icon.
Q1 : Does anybody is using this configuration ?
Q2 : Wireshark is not catching messages from/to the IP of Imperihome phone ?
Attached the sreenshot of the domoticz app =OK
Screenshot_security panel imperihome.png (66.49 KiB) Viewed 3762 times
Last edited by gerardosamara on Wednesday 01 February 2017 20:19, edited 4 times in total.
markjgabb
Domoticz version: 3.8153
Post by markjgabb »
hi all i have just installed mydomoathome on my windows 2016 box, web page loads, everything seems fine, but I cant seem to see my config....
ive created config.json as per the git site instructions, placed it in the correct folder but this is the resoponse I get
error: Global conf parsing issue !
error:  Error: Error parsing your configuration file: [./config.json]: Unexpected end of JSON input
    at exports.File.File.loadSync (C:\MyDomoAtHome\MyDomoAtHome-nodejs\node_modules\nconf\lib\nconf\stores\file.js:160:11)
    at exports.Provider.Provider.add (C:\MyDomoAtHome\MyDomoAtHome-nodejs\node_modules\nconf\lib\nconf\provider.js:137:23)
    at exports.Provider.Provider.use (C:\MyDomoAtHome\MyDomoAtHome-nodejs\node_modules\nconf\lib\nconf\provider.js:110:10)
    at loadLocalConf (C:\MyDomoAtHome\MyDomoAtHome-nodejs\mdah.js:81:19)
    at Object.<anonymous> (C:\MyDomoAtHome\MyDomoAtHome-nodejs\mdah.js:129:1)
    at Module._compile (module.js:571:32)
    at Object.Module._extensions..js (module.js:580:10)
    at Module.load (module.js:488:32)
    at tryModuleLoad (module.js:447:12)
    at Function.Module._load (module.js:439:3)
error: Global conf load issue !
    at loadStore (C:\MyDomoAtHome\MyDomoAtHome-nodejs\node_modules\nconf\lib\nconf\provider.js:396:26)
    at C:\MyDomoAtHome\MyDomoAtHome-nodejs\node_modules\nconf\node_modules\async\lib\async.js:356:13
    at async.forEachOf.async.eachOf (C:\MyDomoAtHome\MyDomoAtHome-nodejs\node_modules\nconf\node_modules\async\lib\async.js:233:13)
    at _asyncMap (C:\MyDomoAtHome\MyDomoAtHome-nodejs\node_modules\nconf\node_modules\async\lib\async.js:355:9)
    at Object.map (C:\MyDomoAtHome\MyDomoAtHome-nodejs\node_modules\nconf\node_modules\async\lib\async.js:337:20)
    at loadBatch (C:\MyDomoAtHome\MyDomoAtHome-nodejs\node_modules\nconf\lib\nconf\provider.js:405:11)
    at exports.Provider.Provider.load (C:\MyDomoAtHome\MyDomoAtHome-nodejs\node_modules\nconf\lib\nconf\provider.js:449:7)
    at loadConf (C:\MyDomoAtHome\MyDomoAtHome-nodejs\mdah.js:104:15)
    at Object.<anonymous> (C:\MyDomoAtHome\MyDomoAtHome-nodejs\mdah.js:131:1)
warn: basic configuration not found in /etc/mydomoathome/config.json, defaulting
warn: domoticz access configuration not found in /etc/mydomoathome/config.json, defaulting
info: Domoticz server: http://127.0.0.1:8080/json.htm
info: Node version: 7.4.0
info: MDAH version: MyDomoAtHome 0.2.7
info: OS version: Windows_NT win32 10.0.14393
info: Hostname: Server 10.0.0.6 in C:\Users\Administrator C:\MyDomoAtHome
info: MDAH port: 3002
info: Refreshing version cache: v0.2.7
this is my basic config (obviously edited for passwords
  "app_name": "MyDomoAtHome",
  "auth": { "username": "admin", "password": "******" },
   "domoticz": {
    "ssl": false,
    "port": "8080",
    "path": "/",
    "auth": { "username": "remote", "password": "******"},
  "port": "3002",
  "passcode": ""
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
