It now can find 2 version on my linux server and Pi, hopefully it will find at least one on yours
Kodi Mediaserver Support
- Dnpwwo
Re: Kodi Mediaserver Support
@jake, can you try the newest beta. I've changed the logic around locating python.
jake
After reading your message, I upgraded immediately to the latest beta, but ....Dnpwwo wrote:@jake, can you try the newest beta. I've changed the logic around locating python.
Filter: X
2016-12-20 09:44:31.959 Domoticz V3.6214 (c)2012-2016 GizMoCuz
2016-12-20 09:44:31.960 Build Hash: 8b2980e, Date: 2016-12-20 09:03:48
2016-12-20 09:44:31.961 System: Raspberry Pi
2016-12-20 09:44:31.961 Startup Path: /home/pi/domoticz/
2016-12-20 09:44:32.210 EventSystem: reset all events...
2016-12-20 09:44:32.251 PluginSystem: Failed dynamic library load, Python not found on your system. - Dnpwwo
@jake, didn't really you would be so quick !
The pull request was merged an hour ago so, unless you build from source, you may have pulled the beta too soon. I'm not sure how long after the merge it takes before ther new beta is produced.
Can you try again a bit later?
EDIT: I take it back, it still won't work. You must be running a RaspberryPi with the old Wheezy operating system rather than the newer Jessie. I've reproduced the problem and will look into it.
EDIT2: Okay, I've got this.which should now give you:I have no idea why the library is not on the machine when python3 is but this fixed it for me.
sudo apt-get install libpython3.2
sudo updatedb
locate libpython3.2.soCode: Select all
/usr/lib/python3.2/config-3.2mu/libpython3.2.soThe reasonable man adapts himself to the world; the unreasonable one persists to adapt the world to himself. Therefore all progress depends on the unreasonable man. George Bernard Shaw
- Brutus
How about the Windows Users
Do we need to install a windows version of Python and its done or do you need to make changes for this also?
Greetings Brutus
Greetings Brutus
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
- Dnpwwo
@Brutus,
It will work on Windows, you just need to make sure that the python folder ends up in the Windows PATH variable.
When I installed the 32bit version (even though I run 64bit Windows 10) and I choseand you should see something likesomewhere in the output. If you do you should be good to go. Just run Domoticz and check the log to see it has found it okay.
If you look in that folder there is awhich is the file Domoticz needs (although it will work with the 32, 33 & 34 versions as well if you have one of those).
- To not install the launcher (don't use python directly)
- Install for all users
- Seem to remember there was an option around environment variables that I selected as well
set PATHCode: Select all
C:\Program Files (x86)\Python35-32\If you look in that folder there is a
python35.dllThe reasonable man adapts himself to the world; the unreasonable one persists to adapt the world to himself. Therefore all progress depends on the unreasonable man. George Bernard Shaw
tjabas
Is there a way to get the stop notification in the log? As for now, all i can se in the log is play and pause
- Brutus
@Dnpwwo,
Thnx for your nicely explained answer. Unfortunately I'm also getting the following error:
The DLL file as you described is in the "C:\Program Files (x86)\Python35-32\" folder.
Isn't it possible to implement Python the same way Lua is implemented in Domoticz with the build-in Editor?
2016-12-20 16:00:39.619 PluginSystem: Failed dynamic library load, Python not found on your system.Isn't it possible to implement Python the same way Lua is implemented in Domoticz with the build-in Editor?
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
IDANIT
@Dnpwwo I did as you describe but got this message
I've seen the Kodi Plugins, I can add it... but no Devices
sudo apt-get install libpython3.4 mayby???
PluginSystem: Invalid Python version '3.2.3' found, '3.4.0' or above required.Code: Select all
PluginSystem: 'lolo' Registration ignored, Plugins are not enabled.-
jake
Yes, this finally worked alright (I am on Wheezy), but after a restart with the very latest beta (of tonight, my 2nd update today), I still have the same error as described one post up:Dnpwwo wrote:@jake, didn't really you would be so quick !
EDIT2: Okay, I've got this.which should now give you:Code: Select all
sudo apt-get install libpython3.2 sudo updatedb locate libpython3.2.soI have no idea why the library is not on the machine when python3 is but this fixed it for me.Code: Select all
2016-12-20 19:45:08.308 PluginSystem: Invalid Python version '3.2.3' found, '3.4.0' or above required.You should get a single filename in the response. if you do, force Domoticz to use it with:
sudo ln -s <locate-filename-here> /usr/lib/libpython3.5.so- Dnpwwo
@jake, The hard part is over
You don't need to go back to my original instructions once python is located, just these ones http://www.domoticz.com/forum/posting.p ... 8#pr109294 about the plugin itself.
This is a sinple mistake on my part, although I made the startup look for versions back to 3.2 I left a constant in the code set to 3.4. I will push a fix.
@IDANIT, the same goes for you. Not sure what platform you are one, you should use the latest python version available.
Under the top level domoticz folder there is a 'plugins' folder where they will live. There is an 'examples' folder under it that has the 3 I developed while testing. Kodi is one of the.
@Brutus, is the python folder in the PATH? If not you can copy and paster the .dll into the same folder as domoticz.exe
- Brutus
@Dnpwwo, when installing without the all user option the setup of Python adds the "PATH" in the environment variables. When selecting the "install for all users" option it doesn't. So I add it myself: PATH --> C:\Program Files (x86)\Python35-32\
I also copied the dll file into the root of the Domoticz folder. It doesn't work
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
tjabas
Anyone?tjabas wrote:Is there a way to get the stop notification in the log? As for now, all i can se in the log is play and pause
jake
I updated to the latest beta again, but Domoticz didn't want to start anymore afterwards. Only when I do aDnpwwo wrote:@jake, The hard part is overYou don't need to go back to my original instructions once python is located, just these ones http://www.domoticz.com/forum/posting.p ... 8#pr109294 about the plugin itself.
./updatereleaseCode: Select all
./update betaCode: Select all
2016-12-21 15:21:20.967 PluginSystem: Started, Python version '3.2.3'.Folder permissions for the domoticz/plugins folder: 755 (drwxr-xr-x)
I still have the Kodi Media Player Server enabled in the hardware list.
IDANIT
same problem here and exact same solution... thx @jake
- Dnpwwo
@jake (and @IDANIT)
Just need to clarify a few things:
Can (one of) you please supply a full log of the start up until it crashes? From the command line you can use:in the domoticz directory
- So I assume doing:resolved the previous issue?
sudo apt-get install libpython3.2 - When you run the latest beta without doing anything with the new plugin it runs okay.
- When you say you 'add the Kodi Player', do you mean you drop the Kodi.py file into the plugins folder or that you go to the hardware page and add the hardware to Domoticz?
./domoticz > domoticz.logThe reasonable man adapts himself to the world; the unreasonable one persists to adapt the world to himself. Therefore all progress depends on the unreasonable man. George Bernard Shaw
jake
Yes, it doesDnpwwo wrote:@jake (and @IDANIT)
resolved the previous issue?Code: Select all
Yes, it does[*]When you run the latest beta without doing anything with the new plugin it runs okay.
Dropping the Kodi.py file in the domoticz/plugins folder (had to create it myself) doesn't hurt anything, the file is there all the time. I / we mean by 'adding Kodi Player' that we add the hardware in the hardware page of Domoticz. As soon as I hit the 'add' button there, Domoticz crashes[*]When you say you 'add the Kodi Player', do you mean you drop the Kodi.py file into the plugins folder or that you go to the hardware page and add the hardware to Domoticz?[/list]
There seems to be no need to be laughed at, since the Kodi.py file can sit in it's folder fine without any problems, as long as you don't add the hardware in the hardware page
If the crash is when you add the Kodi.py file to the directory the problem will probably be the manifest build which will make @gizmocuz laugh his head off. He's been hassling me to get rid of that all week and I haven't gotten around to it yet![]()
This is the log after I start Domoticz with the log function and in which session I add 'Kodi Players' hardware:Can (one of) you please supply a full log of the start up until it crashes? From the command line you can use:in the domoticz directoryCode: Select all
- Spoiler: show
- Spoiler: show
IDANIT
Exactly the same as above. The problem with crashes appears with newest beta versions only v3.6224, v3.6231. With previous beta version there were no crashes.
deennoo
Just try it on my side, considering that a begining of somehing great please considere all informaion that i provid as things i saw and live, not as critic.
VM on debian 8.5 64bit
Domoticz for github :
Version: 3.6231
Build Hash: ad2ee5b
Compile Date: 2016-12-22 18:31:42
Kodi Openelec : 6.0
Debug : true
Notification : True
Just add Kodi Players plugin, all seams to go well 4 device created
Logs are :
Refresh time isn't immediat between action on kodi and update to Domoticz
Version: 3.6231
Build Hash: ad2ee5b
Kodi Openelec : 6.0
Debug : true
Notification : True
Logs are :
2016-12-22 22:49:43.435 (Kodi openelec) Calling message handler 'onMessage'.
2016-12-22 22:49:43.435 (Kodi openelec) Player.OnPlay recieved, Player ID: -1
2016-12-22 22:49:43.435 (Status) Updating device from 1:'' to have values 4:''.
2016-12-22 22:49:43.443 (Kodi openelec) Update 4:'' (Status)
2016-12-22 22:49:43.443 (Playing) Updating device from 0:'0' to have values 2:'0'.
2016-12-22 22:49:43.445 (Kodi openelec) Update 2:'0' (Playing)
2016-12-22 22:49:43.445 (Kodi openelec) Sending data: '{"jsonrpc":"2.0","method":"Player.GetItem","id":1003,"params":{"playerid":1,"properties":["artist","album","year","channel","showtitle","season","episode","title"]}}'.
2016-12-22 22:49:43.597 (Kodi openelec) Calling message handler 'onMessage'.
2016-12-22 22:49:43.598 (Kodi openelec) 1003 response received: {"id":1003,"jsonrpc":"2.0","result":{"item":{"album":"","artist":[],"episode":-1,"id":24,"label":"Braqueurs amateurs","season":-1,"showtitle":"","title":"Braqueurs amateurs","type":"movie","year":2005}}}
2016-12-22 22:49:43.599 (Status) Updating device from 4:'' to have values 4:' Braqueurs amateurs (2005)'.
2016-12-22 22:49:43.601 (Kodi openelec) Update 4:' Braqueurs amateurs (2005)' (Status)
2016-12-22 22:49:43.601 (Kodi openelec) Sending data: '{"jsonrpc":"2.0","method":"Player.GetProperties","id":1002,"params":{"playerid":1,"properties":["live","percentage","speed"]}}'.
2016-12-22 22:49:43.652 (Kodi openelec) Calling message handler 'onMessage'.
2016-12-22 22:49:43.653 (Kodi openelec) 1002 response received: {"id":1002,"jsonrpc":"2.0","result":{"live":false,"percentage":0.005016164388507604599,"speed":1}}
2016-12-22 22:49:44.765 (Kodi openelec) Calling message handler 'onHeartbeat'.
2016-12-22 22:49:44.766 (Kodi openelec) Sending data: '{"jsonrpc":"2.0","method":"Player.GetProperties","id":1002,"params":{"playerid":1,"properties":["live","percentage","speed"]}}'.
2016-12-22 22:49:44.817 (Kodi openelec) Calling message handler 'onMessage'.
2016-12-22 22:49:44.818 (Kodi openelec) 1002 response received: {"id":1002,"jsonrpc":"2.0","result":{"live":false,"percentage":0.027727143839001655579,"speed":1}}
2016-12-22 22:49:54.758 (Kodi openelec) Calling message handler 'onHeartbeat'.
2016-12-22 22:49:54.758 (Kodi openelec) Sending data: '{"jsonrpc":"2.0","method":"Player.GetProperties","id":1002,"params":{"playerid":1,"properties":["live","percentage","speed"]}}'.
2016-12-22 22:49:54.809 (Kodi openelec) Calling message handler 'onMessage'.
2016-12-22 22:49:54.810 (Kodi openelec) 1002 response received: {"id":1002,"jsonrpc":"2.0","result":{"live":false,"percentage":0.22598412632942199707,"speed":1}}Domoticz stable 3.5877 for real & Domoticz beta for test
http://domo-attitude.fr
- Dnpwwo
@deenoo, great to see it works on some setups (other than mine
). Do you think the delay is due to the Domoticz web pages only refreshing every 10 seconds or does it appear slower than that?
@jake, thanks for the logs, it really helps. As you say this does not look like a manifest file writing issue (I'm removing it anyway though).
Interesting that it got as far as the 'initialized' message. All the Python set up is completed and there is just the call to the Plugin 'onStart' function left to do which is pretty straight forward. I've restored my old Wheezy Pi from a pre-Jessie upgrade and am current building from source to update it but that takes many hours so I'll try and reproduce the error tomorrow.
deennoo
About refresh, i made a test :
Adding domoticz native kodi hardware :
sometime (most ofen) domoticz was first updated, and sometime plugin was the first.
