domoticz in synology as package! Available now.
Gravityz
- Domoticz version: 2026.3
upgraded to 6072
upgrade went smooth.
so far looking good.
- jumbotroll
Have you installed DSM 6.1 Beta? and what type NAS do you have?Gravityz wrote:upgraded to 6072
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- Egregius
- Domoticz version: v2024.7
6072? I just received 3.6147 on Syno DS1513+
edit: simultanous post
@Jumbotroll: thanks again for the great work you do for Syno
Gravityz
My nas is a DS112+
DSM 6.0.2-8451 Update 5
no 6.1 beta.
why is that a good thing
no 6.1 beta.
- jumbotroll
Ok I miss understood, because the latest beta for DSM 6.0.2 is Domoticz v3.0.6147-7 http://www.jadahl.com/domoticz_beta_6/?arch=88f6281Gravityz wrote:My nas is a DS112+
no 6.1 beta.
I miss understood, because the latest domoticz beta for DSM 6.1 Beta is Domoticz v3.0.6072-7 http://www.jadahl.com/domoticz_beta_6.1/?arch=88f6281
I have not tested DSM 6.1 Beta, will wait for the release
Jumbotroll
Jumbotroll
Gravityz
yes,
i just downloaded 6072 2 days ago(so i missed the latest version)
i noticed a new zwave module was not supported on 5019 but was supported on 6072
It turned out the module is recognised in 6072 but far from supported because a config file is missing.
i will buy the new module tomorrow and will test it out with a config file i made myself
Isane
- Domoticz version: Stable
Hardware:
Synology DS215J DSM 6.0.2-8451 Update 6
P1 USB cable
Package installed
Domoticz (version 3.0.5877-7)
UsbSerialDrivers DSM 6.0 beta (version 3-0)
I have the P1 cable in the USB3 port but Domoticz does not recognize the P1 cable.
How can I fix this issue? Is it a driver problem or something else?
P1 USB cable
Package installed
- sincze
- Domoticz version: 2024.4
did you try 'dmesg' to see if synology recognized the cable as USB device?
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Isane
Thanks. I see indeed some errors (I did 2 outputs, 1 with the p1 kabel and 1 without a p1 kabel).sincze wrote:did you try 'dmesg' to see if synology recognized the cable as USB device?
I see the following error with a p1 cable
- sincze
Isane wrote:Thanks. I see indeed some errors (I did 2 outputs, 1 with the p1 kabel and 1 without a p1 kabel).sincze wrote:did you try 'dmesg' to see if synology recognized the cable as USB device?
A yes, that is why it does not show up in Domoticz, not recognized as ttyUSBx device.
Sure you have the correct drivers??
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Isane
How can I pick the correct driver? The P1 cable works fine at the USB2 port. (but on that port i have the Aeotec USB Z-Stick - Z-Wave Plus)sincze wrote:Isane wrote:Thanks. I see indeed some errors (I did 2 outputs, 1 with the p1 kabel and 1 without a p1 kabel).sincze wrote:did you try 'dmesg' to see if synology recognized the cable as USB device?
I've installed the following packages:
EDIT: 20-12-2016: I removed UsbSerialDrivers DSM 6.0 beta (version 3-0) and Domoticz. I installed Domoticz again. (from http://www.jadahl.com/domoticz_stable_6/) . But thats also not the solution.
Gravityz
zwave control panel is only displaying correctly on an iphone or ipad.
Windows10 pc with edge, internet explorer or firefox does not work anymore.
is there a way to extract files from older spk packages.
i have problems with zwave control panel and need some files from an old package.
- jumbotroll
Domoticz with Python PluginManager for Synology test packages.
Download here: http://www.jadahl.com/domoticz_beta_6_python/
Before installing this package, you have to install Python 3.5.1-0104 from Synology package center!
Python package can also be downloaded manually here: http://download.synology.com/download/P ... .5.1-0104/
Plugin folder is located in folder /usr/local/domoticz/var/plugins/ on Synology!
After you have added *py files in the plugin folder, you have to stop and start domoticz from package center for modules to load.
BTW! Take backup of domoticz.db and all you script before you test as always
Merry christmas and happy new year!
Jumbotroll
Jumbotroll
- Egregius
What can you do with this?
- jumbotroll
Add python pluginsEgregius wrote:What can you do with this?
https://www.domoticz.com/wiki/Developin ... n#Overview
Jumbotroll
Jumbotroll
kaivalagi
That's great, hmmmm, lots of python libraries to utilise....I assume if a library works natively it will work via plugins? I.e. full library support?
Sent from my ASUS_T00P using Tapatalk
Soulplayer
- Target OS: -
My domoticz keeps crashing? Does anybody has an idea what is going wrong?
matsumoto
- Domoticz version: V3.9483
I have troubles with the lastest Domoticz version installed on my DS413j (events not working well, notifications not sent, no log on some devices ...).
It was working better with the previous version.
I'm still on DSM 5.2 and when i check for the lastest version available, it is Domoticz v3.0.5864-7 and i have ... v3.0.5877-7 ... which is supposed to be for DSM 6.0
Is it the source of my problems ?
Will it be an update for DSM 5.2 ?
Do i go back to 3.0.5864 and everything will be better ?
Thank you.
Thank you.
- jumbotroll
I do not update the DSM 5.2 domoticz packages so often anymore, but I can compile a new version for you if you want to test?matsumoto wrote:Hi,
I'm still on DSM 5.2 and when i check for the lastest version available, it is Domoticz v3.0.5864-7 and i have ... v3.0.5877-7 ... which is supposed to be for DSM 6.0![]()
Thank you.
Edit: Here you go
Domoticz v3.0.6343-7 for DS413j for DSM 5.2
http://www.jadahl.com/domoticz_beta/?arch=88f6282
Last edited by jumbotroll on Saturday 14 January 2017 19:53, edited 1 time in total.
Jumbotroll
Jumbotroll
matsumoto
OMG !jumbotroll wrote:I do not update the DSM 5.2 domoticz packages so often any more, but I can compile a new version for you if you want to test?matsumoto wrote:Hi,
Thank you.
Edit: Here you go![]()
You're so reactive and helpful !
Thank you !
... i should learn how to compile myself some day ...
