Hello
I am trying to install Domoticz on VM ,ubuntu 16.10
I foloow the process in the Wiki https://www.domoticz.com/wiki/Linux
I compile open zwave without issue
Till cmake -DCMAKE_BUILD_TYPE=Release .
then I receive a message :
Cmake Error
python3 not found on your system
I have libpython 2.7 and 3.5 on my system
Can you please help
installation on Ubuntu 16.10
SweetPants
Re: installation on Ubuntu 16.10
Known issue, take a look at http://www.domoticz.com/forum/viewtopic ... 28&t=14799
Start with cmake -DCMAKE_BUILD_TYPE=Release -D USE_PYTHON_PLUGINS=NO CMakeLists.txt if you don't need python support
nono212
- Domoticz version: 3.6179
the objective is to use https://www.domoticz.com/wiki/EQ3_MAX! lua script .
I would like to know I f I can without python ?
Small question is there available a Vmware linux domoticz available with Zwave support that we can download ?
- gizmocuz
If you do not need python, or do not want to fix this compile error, it is also stated in the error message what to do when you do not want to use python (preprocessor set to NO)
SweetPants
There is nothing on the supplied link, but if it is a LUA script it is not depending on the Python support.nono212 wrote:the objective is to use https://www.domoticz.com/wiki/EQ3_MAX! lua script .
nono212
Thanks Sweetpants
I will use it without python then
by any chance do you think it is possible to download from somewhere a vm linux (for PC )
