I'm trying to make a switch for a heater (2000w) so I use a Conrad remote switch (https://www.conrad.nl/nl/rsl-draadloze- ... 40303.html).
But when I want to add it is is not working. So I follow the steps:
1. under settings tab, make sure "accept new hardware/sensors is enabled.. if not enable it and disable when done.
2. go to hardware tab
3. press create rflink device
4. enter string: 20;21;Conrad;ID=220c49;SWITCH=01;CMD=ON;
5. press OK
6. go to devices tab find the new conrad device, press green arrow and name it
7. go to switches tab and locate the new device
8. set the switch in learning mode and press "ON" on the device to pair it to the switch.
At step 8 however nothing happens. Should I enter a different string? Or protocol? Or is my device not supported yet?
Hope someone is able to help
