I am relatively new to Domoticz
I am using RFLINK with LightwaveRF
My standard RF switches are detected fine.
However I can't use the mood controller (wall switch) as either a switch or trigger scenes.
It just isn't detected when I go to add it.
Lightwaverf mood controller
gorstj
Re: Lightwaverf mood controller
a debug output when the button is pressed is as follows:
20;06;RFDEBUG=ON;
20;07;DEBUG;Pulses=37;Pulses(uSec)=210,210,120,1230,120,210,120,210,120,210,120,1230,120,210,120,210,120,210,120,210,120,1230,120,210,120,1230,120,240,120,1230,120,210,120,1230,120,210,3420;
20;08;DEBUG;Pulses=88;Pulses(uSec)=150,270,60,1290,120,210,120,1230,120,210,120,210,120,210,120,240,120,210,120,210,120,210,120,1230,120,210,120,1230,120,240,150,1200,120,210,120,1200,120,210,120,210,120,210,120,210,120,210,120,210,120,210,120,1200,120,210,120,1230,120,240,150,210,120,210,120,210,120,210,120,1230,120,210,120,1230,120,210,120,1230,120,210,120,1230,120,210,120,210,120,210,120,6990;
20;09;DEBUG;Pulses=144;Pulses(uSec)=30,420,120,210,120,1230,120,210,120,210,120,210,120,1230,120,240,120,210,120,210,120,210,120,1230,120,210,120,1230,120,210,120,1230,120,210,150,1230,120,210,120,210,150,210,120,210,150,210,120,210,120,210,120,1230,120,210,120,1230,120,240,120,1230,120,210,120,1230,120,210,120,210,120,210,120,240,120,210,120,210,120,210,120,1200,150,210,120,1200,150,240,120,1230,120,210,120,1230,120,210,120,210,120,210,120,210,120,210,120,210,150,210,120,1230,120,210,120,1230,120,210,120,210,120,210,120,210,120,210,120,1230,150,210,120,1230,120,210,120,1230,120,210,120,1230,120,210,120,210,120,210,120,6990;
20;0A;Lightwave;ID=f2f200;SWITCH=af;CMD=MOOD=01;
20;0B;DEBUG;Pulses=108;Pulses(uSec)=90,210,120,210,120,210,120,210,120,210,120,210,120,210,120,1200,120,210,120,1200,150,210,150,1200,150,210,120,1230,120,210,120,210,120,210,150,210,120,210,120,210,120,210,120,1230,120,210,120,1230,120,240,120,1230,150,210,120,1230,120,210,120,210,120,210,120,240,120,210,120,210,120,210,150,1230,120,210,120,1230,150,210,120,210,150,210,120,210,120,210,120,1230,120,210,120,1230,120,210,150,1230,120,210,120,1230,120,210,120,210,120,210,120,6990;
20;0C;DEBUG;Pulses=134;Pulses(uSec)=180,210,120,1140,120,210,120,210,120,180,120,180,120,1140,120,180,120,1200,120,210,150,1230,120,210,120,1230,120,210,150,210,120,210,120,210,120,210,120,210,120,210,120,1200,150,210,120,1230,120,240,120,1230,120,210,150,1200,150,210,120,210,120,210,120,210,150,210,120,210,120,210,120,1230,120,210,120,1230,120,210,120,1230,120,210,120,1230,120,210,120,210,120,210,150,210,150,210,120,210,120,210,120,1230,120,210,150,1230,120,210,120,210,120,210,120,210,150,210,150,1230,120,210,120,1230,120,210,150,1230,120,210,120,1230,120,210,120,210,120,210,120,6990;
20;0D;DEBUG;Pulses=88;Pulses(uSec)=180,210,120,1140,120,180,120,1170,120,210,120,180,120,180,120,210,150,210,120,210,120,210,120,1230,120,210,120,1230,150,240,120,1230,120,210,120,1230,120,210,120,210,120,210,120,240,120,210,120,210,120,210,150,1230,150,210,120,1230,120,210,120,210,120,210,120,210,120,210,120,1230,120,210,120,1230,120,210,150,1230,120,210,120,1230,120,210,120,210,120,210,120,6990;
20;0E;DEBUG;Pulses=144;Pulses(uSec)=0,420,120,210,120,1200,150,210,120,210,120,210,120,1230,120,210,120,210,120,210,120,210,120,1230,120,210,150,1230,120,240,120,1230,120,210,150,1200,120,210,120,210,120,210,120,210,120,210,150,210,120,210,150,1200,120,210,120,1200,150,210,150,1200,150,210,120,1200,120,210,120,210,150,210,120,240,120,210,120,210,120,210,120,1230,150,210,120,1230,120,240,120,1230,120,210,150,1230,120,210,120,210,120,210,150,210,120,210,120,210,120,210,120,1230,120,210,120,1230,120,210,120,210,120,210,120,210,120,210,120,1230,120,210,120,1230,120,210,120,1230,120,210,120,1230,120,210,120,210,120,210,120,6990;
20;0F;DEBUG;Pulses=80;Pulses(uSec)=180,210,120,210,120,180,120,210,120,180,120,180,120,180,120,1170,120,210,120,1170,120,210,120,1200,150,210,120,1230,150,210,120,210,120,210,120,210,120,210,150,210,150,210,120,1230,120,210,150,1230,120,210,120,210,120,210,150,210,120,210,120,1230,120,210,150,1230,120,210,120,1230,120,210,120,1230,120,210,120,210,120,210,120,6990;
20;10;DEBUG;Pulses=142;Pulses(uSec)=210,210,120,1230,120,210,120,210,120,210,120,1230,120,240,120,210,120,210,120,210,150,1230,120,210,120,1200,120,240,120,1230,120,210,150,1200,150,210,120,210,120,210,150,210,120,210,150,210,120,210,150,1200,120,210,150,1200,120,240,120,1230,150,210,120,1230,120,210,120,210,120,210,120,240,120,210,120,210,120,210,120,1230,120,210,120,1230,150,210,120,1230,120,210,120,1230,120,210,120,210,120,210,120,240,120,210,120,210,120,210,120,1230,120,210,120,1230,120,240,120,210,120,210,120,210,120,210,150,1230,120,210,120,1230,120,210,150,1230,120,210,120,1200,120,210,120,210,120,210,150,6990;
20;11;DEBUG;Pulses=76;Pulses(uSec)=180,180,120,210,120,180,120,180,120,180,120,1170,120,180,120,1170,120,210,120,1230,120,210,120,1230,120,210,120,210,120,210,120,210,120,210,150,210,150,210,150,1230,120,210,120,1230,120,240,120,210,120,210,150,210,120,210,120,1230,120,210,120,1230,120,210,120,1200,150,210,120,1200,120,210,120,210,120,210,120,6990;
20;12;DEBUG;Pulses=24;Pulses(uSec)=150,210,120,1170,120,180,120,1170,120,180,120,1140,120,180,120,1140,120,210,120,210,150,210,120,6990;
20;13;DEBUG;Pulses=118;Pulses(uSec)=30,1140,120,210,120,1170,120,180,120,1140,120,180,120,180,120,180,120,210,120,210,120,180,120,180,120,1200,120,210,120,1230,120,240,120,1230,150,210,120,1230,120,210,120,210,150,210,120,210,150,210,150,210,120,210,120,1230,120,210,150,1230,150,210,120,1230,120,210,150,1230,150,210,150,210,150,210,120,210,150,210,120,210,120,210,150,1230,120,210,150,1230,120,240,150,210,120,210,150,210,120,210,120,1230,120,210,120,1230,120,210,150,1200,120,210,120,1230,120,210,120,210,120,210,150,6990;
20;14;DEBUG;Pulses=116;Pulses(uSec)=210,210,120,1140,120,210,120,1140,120,210,120,180,120,180,120,210,120,210,120,210,150,210,120,1230,150,210,120,1230,120,240,120,1230,150,210,120,1230,120,210,120,210,150,210,120,210,120,210,120,210,120,210,120,1230,120,210,120,1230,120,210,120,1230,120,210,120,1230,120,210,120,210,120,210,120,240,120,210,120,210,120,210,120,1230,120,210,120,1230,120,240,150,210,120,210,120,210,120,210,120,1200,120,210,120,1230,120,210,150,1200,120,210,150,1200,120,210,120,210,120,210,120,6990;
20;06;RFDEBUG=ON;
