domoticz lost Z-wave ID and type after reinstall
laggmunk
Post by laggmunk »
My domoticz install running on an old raspberry pi crashed, I installed a new installation on a raspberry pi 2 and moved my aeon labs Z-wave+ stick to that one and restored the domoticz.db.
after that most of my z-wave devices have the correct name, but an ID and type of 0x0000
the configuration of the devices are not visible.
out of about 30 devices only 2 have the correct ID´s, tried including a new Z-wave device and that works
I can see traffic from these devices in OZW log when running the controller in debug mode, but I cannot issue commands or include/exclude the devices.
when pushing a button on a z-wave remote this can be seen in the OZW log:
2016-12-10 10:48:57.406 Info, Node021, ApplicationCommandHandler - Unhandled Command Class 0x2b
2016-12-10 10:48:57.725 Detail, Node021, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x15, 0x02, 0x84, 0x07, 0x67
2016-12-10 10:48:57.726 Info, Node021, Received Wakeup Notification from node 21
2016-12-10 10:48:57.726 Info, Node021, Node 21 has been marked as awake
2016-12-10 10:48:57.726 Detail, Node021, Queuing (WakeUp) WakeUpCmd_NoMoreInformation (Node=21): 0x01, 0x09, 0x00, 0x13, 0x15, 0x02, 0x84, 0x08, 0x25, 0xb0, 0xeb
2016-12-10 10:48:57.727 Detail, Node021, Notification: Notification - Node Awake
2016-12-10 10:48:57.728 Info, Node021, Sending (WakeUp) message (Callback ID=0xb0, Expected Reply=0x13) - WakeUpCmd_NoMoreInformation (Node=21): 0x01, 0x09, 0x00, 0x13, 0x15, 0x02, 0x84, 0x08, 0x25, 0xb0, 0xeb
2016-12-10 10:48:57.734 Detail, Node021, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-10 10:48:57.734 Detail, Node021, ZW_SEND_DATA delivered to Z-Wave stack
2016-12-10 10:48:57.749 Detail, Node021, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x15, 0x02, 0x84, 0x07, 0x67
2016-12-10 10:48:57.750 Info, Node021, Received Wakeup Notification from node 21
2016-12-10 10:48:57.750 Detail, Node021, Queuing (WakeUp) WakeUpCmd_NoMoreInformation (Node=21): 0x01, 0x09, 0x00, 0x13, 0x15, 0x02, 0x84, 0x08, 0x25, 0xb1, 0xea
2016-12-10 10:48:57.849 Detail, Node021, Received: 0x01, 0x05, 0x00, 0x13, 0xb0, 0x01, 0x58
2016-12-10 10:48:57.850 Detail, Node021, ZW_SEND_DATA Request with callback ID 0xb0 received (expected 0xb0)
2016-12-10 10:48:57.850 Info, Node021, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-10 10:48:57.850 Info, Node021, Node 21 has been marked as asleep
2016-12-10 10:48:57.851 Detail, Node021, Notification: Notification - Node Asleep
but nothing is noted in the domoticz.log.
so it seems commands are getting through to OZW but not further
what could have gone wrong? where do I start fixing this?
laggmunk
Re: domoticz lost Z-wave ID and type after reinstall
Post by laggmunk »
this is real weird, but after half a day most devices are back and working even though I changed nothing.
it does not seem normal for a discovery to take like 4 hours, but it did.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Normal for battery powered devices.
