Is it possible to send commands to the RFLink from Lua in a running Domoticz (on Linux)?
Thanks,
Mikkel
RFLink commands from Lua?
SweetPants
Re: RFLink commands from Lua?
What do you mean with "send commands to the RFLink"?
If a 'device', like a switch is learned through the RFLink, yes you can send 'on/off' commands in LUA.
mikkel75
I mean can I send a "10;Kaku;00004d;1;OFF;" directly to the RFLink from Lua while it's enabled in Domoticz?
SweetPants
Don't think so, then you need direct acces to the serial port which is not supported as far as i knowmikkel75 wrote:I mean can I send a "10;Kaku;00004d;1;OFF;" directly to the RFLink from Lua while it's enabled in Domoticz?
mikkel75
I would be a very nice feature (if direct access isn't possible) to be able to make a custom RFLink device/switch, where you may define the exact commands used for power ON/OFF/Dim etc...
- sincze
- Domoticz version: 2024.4
Re: RE: Re: RFLink commands from Lua?
What would be the advantage of that feature? I am missing that one sorrymikkel75 wrote:I would be a very nice feature (if direct access isn't possible) to be able to make a custom RFLink device/switch, where you may define the exact commands used for power ON/OFF/Dim etc...
Sent from my SM-G925F using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
D3LTA
- Domoticz version: 3.8153
Would love the feature too, ev1527 has no off only on.. when i can send commands directly it will save me from making dummy switches and just use the selector switch with the commands
