Is it gonna rain within the next X minutes?
happyman
Re: Is it gonna rain within the next X minutes?
Post by happyman »
I add an line so the log is more compleet.
print('Regen verwacht: '..regen..' mm binnen '..minuten..' minuten.')
..regen.. is the function from your script.
The last time the script gives an strange result:
2016-12-03 15:15:00.854 LUA: Regen verwacht: nan mm binnen 20 minuten.
And the switch in continuos ON.
I cannot found where the nan is generated. Any ideas?
jvdz
Domoticz version: 4.107
Post by jvdz »
What is the content of the file downloaded by the script? (rain.txt)
Jos
mikeoo
Post by mikeoo »
happyman wrote:Hi,
I think the nan is because the value is 0 when there is no rain predicts.
https://en.wikipedia.org/wiki/NaN
happyman
Post by happyman »
Here is the complete code
-- IsItGonnaRain( int minutesinfuture)
-- returns: int avarage rainfall for the next minutesinfuture
-- Function to get rain prediction from Buienradar.nl (dutch)
-- http://gratisweerdata.buienradar.nl/#Buienradar You may use their free service for non-commercial purposes.
-- Written in LUA by Hans van der Heijden (h4nsie @ gmail.com)
-- Spring 2015
-- 28-03-2015 v0.3 bug: quotes around url added.
-- 27-03-2015 v0.2 return value is now average for next time
-- 26-03-2015 v0.1 Initial release
-- todo: some error checking on http and file handling (tmp file)
function IsItGonnaRain( minutesinfuture )
-- config ---------------------------------------------------------
  lat='52.65160'   -- example lat/lon for Den Haag
  lon='5.10954'
  debug=false
  tempfilename = '/var/tmp/rain.tmp' -- can be anywhere writeable
  url='http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon
  if debug then print(url) end
  read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
  file = io.open(tempfilename, "r")
  totalrain=0
  rainlines=0
  -- now analyse the received lines, format is like 000|15:30 per line.
  while true do
     line = file:read("*line")
     if not line then break end
     if debug then print('Line:'..line) end
     linetime=string.sub(tostring(line), 5, 9)
     if debug then print('Linetime: '..linetime) end
        -- Linetime2 holds the full date calculated from the time on a line
        linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
        difference = os.difftime (linetime2,os.time())
     -- When a line entry has a time in the future AND is in the given range, then totalize the rainfall
     if ((difference > 0) and (difference<=minutesinfuture*60)) then
        if debug then print('Line in time range found') end
        rain=tonumber(string.sub(tostring(line), 0, 3))
        totalrain = totalrain+rain
        rainlines=rainlines+1
        if debug then print('Rain in timerange: '..rain) end
        if debug then print('Total rain now: '..totalrain) end
  file:close()
  -- Returned value is average rain fall for next time
  -- 0 is no rain, 255 is very heavy rain
  -- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
  averagerain=totalrain/rainlines
return(averagerain)
time = os.date("*t")
if ((time.min % 15)==0) then
   ----- REGEN ------
   minuten=15
   regen = IsItGonnaRain(minuten)
    if regen > 70 and otherdevices['Rain expected']=='Off' then
      commandArray['SendNotification']='Regenscript#Regen verwacht'
      commandArray['Rain expected']='On'
    if regen == 0 and otherdevices['Rain expected']=='On' then
       commandArray['SendNotification']='Regenscript#Geen regen meer verwacht'
       commandArray['Rain expected']='Off'
I'm not at home right now so I cannot view the rain.txt file. Will follow.
When I enter the url in explorer there is data.
http://gadgets.buienradar.nl/data/raintext?lat=52.65160&lon=5.10954
000|17:35
000|17:40
000|17:45
000|17:50
035|17:55
057|18:00
057|18:05
070|18:10
057|18:15
057|18:20
080|18:25
070|18:30
057|18:35
035|18:40
035|18:45
035|18:50
035|18:55
000|19:00
000|19:05
000|19:10
000|19:15
000|19:20
000|19:25
000|19:30
MaffeMuis
Domoticz version: 3.9483
Post by MaffeMuis »
Put debug on to TRUE
Also I think your URL need to be:
http://gadgets.buienradar.nl/data/raint ... 5&lon=5.11
Set your
lat to 52.65
and
lon to 5.11
I think they changed something, you get an MOVE PAGE is you used the more advaned lat en lon.
Ik ben en blijf een brabander!
|Node-Red|Mqtt|ESPboards|tasmota|NAS|
Domoticzfun
Domoticz version: 3.8153
Post by Domoticzfun »
I tried this script today and got it working after a change. Thanks for the nice work!
As already been said the URL needed has been changed,
It is changed to this one:
url='http://gpsgadget.buienradar.nl/data/rai ... 5&lon=5.11'
(tried it in the webbrowser and checked the file, this is working now as I see values for one hour for every 5 minutes in /var/tmp/rain.tmp)
lat and lon are auto rounded in 2 decimals so more decimals in the variables are useless.
Rob
Brutus
Post by Brutus »
sander815 wrote:i am not getting this to work anymore.
Url is working, but my virtaul switch Rain expected remains 0mm
/var/tmp/rain.txt is looking ok
112|13:30
117|13:35
106|13:40
106|13:45
087|13:50
087|13:55
087|14:00
057|14:05
057|14:10
057|14:15
057|14:20
057|14:25
070|14:30
035|14:35
000|14:40
035|14:45
000|14:50
000|14:55
000|15:00
and in teh log i see this:
2017-02-22 13:30:01.531 LUA: Regen verwacht: 109.66666666667 mm binnen 15 minuten.
what am i doing wrong?
Maybe you can post your script?
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
Brutus
Post by Brutus »
-- Spring 2015
  lat='51.70'   -- example lat/lon for Den Haag
  lon='5.98'
  debug=false
  totalrain=0
  rainlines=0
  while true do
  file:close()
return(averagerain)
   ----- REGEN ------
   minuten=15
You say that you "Rain Expected" Virtual Switch remains 0mm. Its a Switch so you can only set it "On" or "Off". As the script does at the bottom.
When was the last time this switch has changed in the log?
28x Fibaro Modules
SMA Solar System
EldigoR
Post by EldigoR »
FYI
I saw errors like these in the logging from time to time..
Error: EventSystem: Warning!, lua script Lua Rain Expected has been running for more than 10 seconds
So I added a 5 seconds timeout to the curl command.
read = os.execute('curl --connect-timeout 5 -s -o '..tempfilename..' "'..url..'"')
zicht
Domoticz version: 2023.1+
Post by zicht »
I noticed that you use a temp file to write data to. :ugeek:
Just to make you aware that this is not needed at all i post my sollution around that ... 8-) ( I hate writing temp files for obvious reasons)
function to read directly any page into a string :!: :
function os.capture(cmd, raw)				-- os.command uitvoeren en resultaat daarvan lezen in string
  local f = assert(io.popen(cmd, 'r'))
  local s = assert(f:read('*a'))
  f:close()
  if raw then return s end
  s = string.gsub(s, '^%s+', '')
  s = string.gsub(s, '%s+$', '')
  s = string.gsub(s, '[\n\r]+', ' ')
  return s
And then in you following code you can do (just an example) :
       -- construct the request URL
        local url = 'http://gadgets.buienradar.nl/data/raintext/ -F lat=51.0 -F lon=5.51'
	content = os.capture("Curl "..url)
Content will contain all data that you will need to split into a table to manipulate. :idea:
In the table rain {} you will find rain, In the table rtime{} you will find corresponding times.
sep = "%s"
	local rain={}
	local rtime={}
	i=1
	        for str in string.gmatch(content, "([^"..sep.."]+)") do
                rain[i]=string.sub(str, 1, 3)
				rtime[i]=string.sub(str, 5, 10)
				if (tonumber(rain[i]) > 0) then
					if (eersteregen == "" ) then eersteregen = rtime[i] end
					totalrain=totalrain + tonumber(rain[i])
					rainlines=rainlines + 1
					alletijden=alletijden .. " " .. rtime[i]
			i = i + 1
	averagerain = round(totalrain /rainlines,2)
	averagerain = round(10^((averagerain-109)/32),1)
Hope it helps you all to avoid writing unneeded files :D
gielie
Domoticz version: latest β
Post by gielie »
Can someone explain how to create a text switch with rain expected, i can't get it to work. I use the latest script but i only have an on/off switch and a print in the log but i want this in a text switch.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
BarryT
Domoticz version: 2024.3
Post by BarryT »
local RainTextIDX = 19   -- your domoticz text device
debug = false -- enable or disable debug output
tempfilename = '/home/pi/domoticz/scripts/barry/rain.tmp' -- be sure this is in the correct map, and give it chmod 0666
totalrain = 0
rainlines = 0
   url='http://gadgets.buienradar.nl/data/raintext/?lat=1.1&lon=1.1' -- this is important!! change the lat and lon to your needs!!
   while true do
   file:close()
   return(averagerain)
function round(num, idp)
   local mult = 10^(idp or 0)
   return math.floor(num * mult + 0.5) / mult
   minuten=30
   RainPrediction = IsItGonnaRain(minuten)
   RainmmHour=10^((RainPrediction-109)/32)
   if (RainPrediction > 20  ) then
      verw = 3
      RainPredictionText=('('..round(RainmmHour, 1)..' mm) regen verwacht!')
      verw = 2
      RainPredictionText=('Voorlopig blijft het droog!')
   commandArray[2] = {['UpdateDevice'] = RainTextIDX .. '|0|' .. tostring(RainPredictionText)}
I have included this script in events system @lua and works perfect :)
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
totalrain = 0
rainlines = 0
   while true do
   file:close()
   return(averagerain)
   minuten=30
      verw = 3
      verw = 2
But how do we use this?
Is this instead of script_time_rain?
SwordFish
Post by SwordFish »
totalrain = 0
rainlines = 0
   while true do
   file:close()
   return(averagerain)
   minuten=30
      verw = 3
      verw = 2
Edit;
Get it working
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Thx for the script.
In addition to the previous posted i added 2 extra virtual rain expectation widgets.
-> 30 minutes -> 60 minutes -> 120 minutes
And set the script to update every 30minutes.
-- Get System Time
local m = os.date('%M')
-- Buienradar
	local RainTextIDX = 192   --your domoticz text device
	local Rain60TextIDX = 193   --your domoticz text device
	local Rain120TextIDX = 194   --your domoticz text device
	tempfilename = '/mnt/storage/domoticz_scripts/logging/buienradar/rain.tmp' -- be sure this is in the correct map, and give it chmod 0666
	totalrain = 0
	rainlines = 0
	   while true do
	   file:close()
	   return(averagerain)
if (m % 30 == 0) then -- run once in 30 min
	   minuten=30
	   minuten60=60
	   minuten120=100
-- Buienradar - Update virtual text device
	   if (RainPrediction > 5  ) then
		  verw = 3
		RainPredictionText=('Komende 30min wordt er een buitje verwacht!')
			RainPredictionText60=('Komende uur wordt er een buitje verwacht!')
				RainPredictionText120=('Na het komende uur word er een buitje verwacht!')
	   elseif (RainPrediction > 12  ) then
		  verw = 2
		RainPredictionText=('Komende 30min ('..round(RainmmHour, 1)..' mm) regen verwacht!')
			RainPredictionText60=('Komende uur ('..round(RainmmHour, 1)..' mm) regen verwacht!')
				RainPredictionText120=('Na het komende uur word er ('..round(RainmmHour, 1)..' mm) regen verwacht!')
		  verw = 1
		RainPredictionText=('Komende 30min blijft het voorlopig droog!')
		  	RainPredictionText60=('Komende uur blijft het voorlopig droog!')
				RainPredictionText120=('Na het komende uur blijft het voorlopig droog!')
	   commandArray[1] = {['UpdateDevice'] = RainTextIDX .. '|0|' .. tostring(RainPredictionText)}
	   commandArray[2] = {['UpdateDevice'] = Rain60TextIDX .. '|0|' .. tostring(RainPredictionText60)}
	   commandArray[3] = {['UpdateDevice'] = Rain120TextIDX .. '|0|' .. tostring(RainPredictionText120)}
edited:
optimised script
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
gielie
Post by gielie »
I have a problem with my rain script, especially with the text switch which never changes.
this is my code.
-- Original script here: https://www.domoticz.com/wiki/Is_it_gonna_rain
-- Spring 2015
-- Marco van Wijngaarden
-- 30-08-2016 v1.0 Adopted and updated the above scripts
-- 30-08-2016 v1.1 Updated the request URL, apparently buienrader is redirecting to different url
-- 30-08-2016 v1.2 Updated CURL to follow redirect and reverted (back to documented) request URL
-- Buienradar.nl --
-- Gratis Weerdata --
-- Buienradar stelt gratis weerdata beschikbaar voor particulieren en bedrijven (website/intranet).
-- Het gebruik van onderstaande weerdata is alleen toegestaan voor niet-commerciële doeleinden.
-- Het gebruik voor mobiele toepassingen of commerciële doeleinden vereist toestemming van Buienradar, zie ook de Disclaimer.
-- Vraag hier toestemming aan voor het gebruik van de weerdata: http://www.buienradar.nl/overbuienradar/contact
-- Vragen, suggesties of een leuk idee? Neem contact met ons op en bouw mee aan Buienradar!
-- Buienradar widget - Neerslagdata op basis van coördinaten
-- Op basis van de door u gewenste coördinaten (latitude en longitude) kunt u de neerslag tot twee uur vooruit ophalen in tekstvorm.
-- De data wordt iedere 5 minuten geüpdatet.
-- Op deze pagina kunt u de neerslag in tekst vinden: http://gps.buienradar.nl/getrr.php?lat=51&lon=3
-- De waarde 0 geeft geen neerslag aan (droog), de waarde 255 geeft zware neerslag aan.
-- Gebruik de volgende formule voor het omrekenen naar de neerslagintensiteit in de eenheid millimeter per uur (mm/u):
-- Neerslagintensiteit = 10^((waarde-109)/32)
-- Ter controle: een waarde van 77 is gelijk aan een neerslagintensiteit van 0,1 mm/u.
-- config ------------------------------------------------------------------------------------------------------
-- Set your local position (latitude and longitude)
local latitude                  = '52.65'             -- your home latitude, set as a user variable
local longitude                 = '4.77'             -- your home longtitude, set as a user variable
-- timewindow for prediction
local minutesinfuture           = 30                                -- (int) minutes in future to calculate rain
-- threshold for switch (when do we actually call it rain and want to act accordingly)
local switchthreshold           = 70                                -- (int) value to toggle virtual switch
-- Rain switch (ON when rain above threshold, else OFF)
local rainswitchname            = "Regen verwacht"                  -- (str) name for switch to toggle
-- Virtual device (txt) displays textual result
local idxRegenmmUur             = 370                               -- IDX for virtual (text) sensor
-- Show results in log
local debug                     = 1                                 -- 1 = ON or 0 = OFF
-- NMA notifications (only during the day)
local notify                    = false                             -- (bool) set 'false' or 'true'
-- URL for data rewquest
local requesturl                = "http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon"
-- redirects to "http://gadgets.buienradar.nl/data/raintext"
-- Where do we store the data (tmp) file
local tempfilename              = "/home/pi/domoticz/scripts/tmp/rain.tmp"
-- default to activate script (set 'false' to run once every 5 minutes or 'true' to run every minute)
local active                    = false                             -- (bool) set 'false' or 'true'
-- No edit required below this line
-- execute (activate) every 5 minutes
local time = os.date("*t")
if ((time.min % 5)==0) then
    -- set to active
    active = true
-- Functions ---------------------------------------------------------------------------------------------------
-- function to split a string --
function splitString(str, delim, maxNb)
    -- Eliminate bad cases...
    if string.find(str, delim) == nil then
        return { str }
    if maxNb == nil or maxNb < 1 then
        maxNb = 0    -- No limit
    local result = {}
    local pat = "(.-)" .. delim .. "()"
    local nb = 0
    local lastPos
    for part, pos in string.gmatch(str, pat) do
        nb = nb + 1
        result[nb] = part
        lastPos = pos
        if nb == maxNb then break end
    -- Handle the last field
    if nb ~= maxNb then
        result[nb + 1] = string.sub(str, lastPos)
    return result
-- function to request rain data
function IsItGonnaRain(requesturl,latitude,longitude,tempfilename,minutesinfuture,debug)
    local averagerain = 0
    local totalrain = 0
    local rainlines = 0
    local url = requesturl..'?lat='..latitude..'&lon='..longitude
    -- print to log
    if (debug == 1) then print("| Request URL .............. : " .. url) end
    -- now get the data
    local trigger_action = 'curl -Lo '..tempfilename..' "'..url..'"'
    -- CURL options:    -s for Silent (no error messages)
    --                  -o for Write output to file instead of stdout.
    --                  -L Follow redirects if the server reports that the requested page has moved (indicated with a Location: header and a 3XX response code)
    handle = os.execute(trigger_action)
    -- print request result to log
        if handle then
            print("| CURL Data request ........ : Success")
            print("! CURL Data request ........ : Failed")
    -- open file and process data
        -- count datalines
        local linenbr = 0
        while true do
            -- count received lines
            linenbr = linenbr+1
            -- line/data format is like 000|15:30 per line, we need to split the string
            raindata    = splitString(line,"|")
            rain        = tonumber(raindata[1])
            linetime    = raindata[2]
            -- Linetime2 holds the full date calculated from the time on each line
            -- calculate the time difference between data/line and os time
            -- When a line entry has a time in the future AND is within the given range, then add/totalize the rainfall
            if ((difference >= 0) and (difference <= minutesinfuture*60)) then
                -- print (relevant) data to log
                if (debug == 1) then print("| Rain data (line) ......... : " .. line) end
                -- calculate totals
                rainlines = rainlines+1
    -- close the file
    file:close()
    -- Returned value is average rain fall for next (int) minutes
    averagerain = totalrain/rainlines
    -- print summary to log
        print("| Rain data received # lines : " .. linenbr)
        print("| In timerange # lines ..... : " .. rainlines)
        print("| Total rain ............... : " .. totalrain)
        print("| Average rain calculated .. : " .. averagerain)
    return(averagerain)
-- Functions to round a number to the given number of decimal places
-- returns result as string (text)
  return string.format("%." .. (idp or 0) .. "f", num)
-- returns result as a number
function round2number(num, idp)
  return tonumber(string.format("%." .. (idp or 0) .. "f", num))
-- Note: If the number is rounded in order to be printed (as text) use function "round" (removed the tonumber function)
-- Converting to number then back to string would reintroduce rounding errors, so for numbers use "round2number" function
-- Process -----------------------------------------------------------------------------------------------------
-- start numbering at 1
indexArray=1
-- executes when active (every 5 minutes)
if (active) then
    -- when debugging set to 1, writing to log starts here
        print("+--------------------------------------------------+")
        print("| =============== IS IT GONNA RAIN =============== |")
    -- rain variables
    local regen = 0
    local regenmmUur = 0
    local rainstr = ""
    -- execute function (for given future minutes)
    regen = IsItGonnaRain(requesturl,latitude,longitude,tempfilename,minutesinfuture,debug)
    -- round result
    if (regen > 0) then
        regen = round2number(regen, 0)
    -- convert rain to mm/uur
    if (regen > 0) then
        regenmmUur = 10^((regen-109)/32)
        regenmmUur = round(regenmmUur, 3)
    -- textual result
    if (regen > 0) then
        rainstr = tostring("Regen verwacht: "..regen.." (".. regenmmUur.." mm/uur) binnen "..minutesinfuture.." minuten")
        rainstr = tostring("Geen regen verwacht binnen komende "..minutesinfuture.." minuten")
    -- write value to virtual (text) sensor
    if ((idxRegenmmUur) and (regenmmUur)) then
        commandArray[indexArray] = {['UpdateDevice'] = tostring(idxRegenmmUur)..'|0|'..rainstr}
        indexArray=indexArray+1
    -- when debugging set to 1, write to log
        print("| Rain text ................ : " .. rainstr)
    -- toggle switch ON
    if regen > switchthreshold and otherdevices[rainswitchname]=='Off' then
        -- send notification during the day
        if (timeofday['Daytime']) and (notify) then
            commandArray[indexArray] = {['SendNotification']=rainstr}
        -- change switch to ON
        commandArray[indexArray] = {[rainswitchname]='On'}
    -- toggle switch OFF
    if regen == 0 and otherdevices[rainswitchname] =='On' then
        -- change switch to OFF
        commandArray[indexArray] = {[rainswitchname]='Off'}
    -- logging end
        print("| --------------------- END ---------------------- |")
this is my error
 2017-04-18 21:05:00.479 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_rain.lua: /home/pi/domoticz/scripts/lua/script_time_rain.lua:165: bad argument #1 to 'sub' (string expected, got nil)
Does someone have any idea how to solve this?
- FIBARO FGS223
- Toon
- Kodi Media Server
BarryT
Post by BarryT »
gielie wrote:I have a problem with my rain script, especially with the text switch which never changes.
this is my code.
-- Spring 2015
-- Buienradar.nl --
    -- set to active
    active = true
        return { str }
    local result = {}
    local nb = 0
    local lastPos
        nb = nb + 1
        result[nb] = part
        lastPos = pos
    if nb ~= maxNb then
    return result
    local totalrain = 0
    local rainlines = 0
    -- print to log
    -- now get the data
        if handle then
        -- count datalines
        local linenbr = 0
        while true do
            linenbr = linenbr+1
                -- calculate totals
    -- close the file
    file:close()
    return(averagerain)
indexArray=1
if (active) then
    -- rain variables
    local regen = 0
    local rainstr = ""
    -- round result
    if (regen > 0) then
    if (regen > 0) then
    -- textual result
    if (regen > 0) then
    -- toggle switch ON
    -- logging end
this is my error
Did you changed the buienradar url as mentioned earlier?
poudenes
Domoticz version: 3.8993
Post by poudenes »
Maybe stupid question, But whats script filename ending? .ph .pl other? :)
Siewert308SW wrote:Thx for the script.
-- Get System Time
-- Buienradar
	totalrain = 0
	rainlines = 0
	   while true do
	   file:close()
	   return(averagerain)
	   minuten=30
	   minuten60=60
	   minuten120=100
		  verw = 3
		  verw = 2
		  verw = 1
edited:
optimised script
jvdz
Post by jvdz »
poudenes wrote:Maybe stupid question, But whats script filename ending? .ph .pl other? :)
None of those but it is a LUA script. ;)
Jos
Siewert308SW
@poudenes
It's a Lua script.
But forget about the script i amended.
After a closer look it aint working as i intended.
The 60 and 120min forecast are printed but are presenting the 30min prediction.
Need a closer look.
Setup:
- DS923+ Docker
