New kind of Amazon Dash button to start tasks
- Thijsvr
- Domoticz version: 2.4075
Amazon is releasing a new version of their Dash button specifically aimed at IoT tasks. So no longer predefined tasks, but you can now set your own.
http://www.engadget.com/2016/05/13/amaz ... utton-iot/
Of course you could already mess around with your original Dash buttons like here: https://familab.org/2016/02/hacking-the ... -button-3/
But it's nice that Amazon is now making life a little bit more straightforward.
Dash buttons now available on Amazon.de
The dashbuttons are now available on Amazon.de. On Github are quite a few projects that allow you to use the Dash to trigger actions.
See: https://github.com/hortinstein/node-dash-button
Re: New kind of Amazon Dash button to start tasks
Here's my code to control scenes - (i even handle the lack of 'Toggle') - you need both node-dash-button, as well as the domoticz-api node library.
Needs to be running Sudo (the ARP request packet checker needs elevated privileges).
var Domoticz = require('./node_modules/domoticz-api/api/domoticz');
var dash_button = require('node-dash-button');
var api = new Domoticz({
protocol: "http",
host: "127.0.0.1",
port: 8080,
username: "",
password: ""
var dash = dash_button(["ac:63:be:89:c9:b6", "ac:63:be:13:c2:b8", "ac:63:be:02:f7:0b"]);
var on = false;
var idx;
function changeScene(idx, sceneState) {
console.log("state = ", sceneState, " for idx - ", idx);
if(sceneState == 'Off'){
sceneState = 'On';
} else if(sceneState == 'On'){
sceneState = 'Off';
console.log("what's the scene state? ", sceneState);
api.changeSceneState({
idx: idx,
state: sceneState
}, function(params, callback) {
return(callback);
function getScene(idx) {
api.getScenesGroups(function(error, scene) {
// console.log("i'm getting the scenes")
if (error) {
console.log("uhoh - ", error);
var sceneArray = scene.results;
for (var i = 0; i < sceneArray.length; i++) {
var element = sceneArray;
if (element.idx == idx) {
var sceneState = element.status;
console.log("scene state is : ", sceneState);
changeScene(idx,sceneState);
function callDashButton(dash_id, callback) {
var dict = {
"ac:63:be:89:c9:b6": 6,
"ac:63:be:13:c2:b8": 7,
"ac:63:be:02:f7:0b": 1
console.log("Dash button" + dash_id + " was clicked!");
var IDX;
for (var key in dict) {
IDX = dict[dash_id];
// console.log(IDX)
getScene(IDX, callback);
dash.on("detected", callDashButton);
- Domoticz version: 3.5146
Nice, hopefully they will start selling these world wide.
Currently only prime it seems, and to expensive on eBay.
Sent from my Nexus 6P using Tapatalk
It's true that they're only available to Prime customers for now
Still, i use Amazon so much that i'm probably breaking even over 12 months by paying for Prime.
yeah, biggest problem with prime though is that it is us only if I am remember it correctly
- blackdog65
yeah, I'm an Amazon.co.uk Prime customer but it's still only available in the US for $19.99
Why do we have to be 2nd place all the time? The poor neighbours.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
In sweden we don´t have amazon at all, and no prime
Easiest is to use a shipping provider like borderlinx, but it gets expensive.
well that's sad
I have two you can have if you like?
hmm - I realised last night that won't work - you need to have an account to configure them to connect to your wifi :/
I just had a 'prime' friend order me 2 dash buttons.
Using node-dash-button and requestify.
Here's my code, run in /etc/rc.local -- sudo node /home/pi/node_modules/node-dash-button/node-dash
So far my first button toggles a pair of lights.
#!/usr/bin/env node
var dash = dash_button(["50:f5:da:11:11:11","ac:63:be:11:11:11"], null, null, 'arp'); //mac address from node-dash-button setup scan
var requestify = require('requestify');
dash.on("detected", function (dash_id){
if (dash_id === "50:f5:da:11:11:11"){
//console.log("Dash1");
requestify.get('http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx=325&switchcmd=Toggle');
} else if (dash_id === "ac:63:be:11:11:11"){
//console.log("Dash2");
requestify.get('http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx=326&switchcmd=Toggle');
if (devicechanged["Dash1"]) and otherdevices["Dash1"]=="On" then
commandArray[1]={['Loft 1']='On'}
commandArray[2]={['Loft 2']='On'}
elseif (devicechanged["Dash1"]) and otherdevices["Dash1"]=="Off" then
commandArray[1]={['Loft 1']='Off'}
commandArray[2]={['Loft 2']='Off'}
Hi and thanks for sharing this, @pdjm43
In Italy we just got the official Dash button, and I've got one for testing.
I'm trying to install node-dash-button, but I'm getting a lot of errors during installation on my Cubie and also on Raspi.
In any case, I'm also trying to use with other example, like this one
But nothing happen.
I've got the Mac address from Fing, an Android app that scan the local network for any device connected, and I see an Amazon one, and I got from there the MAC addr.
But when launching that python code nothing happens, when pushing the button!!!!
Any help where I can check?
I would like to integrate then in domoticz and see what can be an usage.
from scapy.all import *
def arp_display(pkt):
if pkt[ARP].op == 1: #who-has (request)
if pkt[ARP].psrc == '0.0.0.0': # ARP Probe
if pkt[ARP].hwsrc == 'xx:xx:xx:xx:xx:xx': # Huggies
print "Pushed Something"
else:
print "ARP Probe from unknown device: " + pkt[ARP].hwsrc
print sniff(prn=arp_display, filter="arp", store=0, count=10)
I only tried node-dash because it was updated recently (they say the dash changed it's output) and it worked straight away. The only advice for your scapy is that the arp scan needs sudo to run.woody4165 wrote:Hi and thanks for sharing this, @pdjm43
But nothing happen.
Hi All,
I'm just trying to get my dash button setup and running. As usual I'm being a bit thick in terms of some of the unix setup.
So far I have done the following:
What file do I create and where?
Does anyone have a template?
How do I get this running on reboot?
do I need to set special permissions?
I heard it has a 4 second delay (assuming to protect against repeat commands?)
Any help would be appreciated
- Spoiler: show
My Setup: Pi, RFXtrx433, HomeEasy: 13 Dimmers & 4 Sockets, 2 motion-sensors, 3 magnetic switches, 1 OWL Electricity Sensor, 3 Oregon Temp Sensor.
ok so I have read a bit more and have created a file called node-dash.js with some of the suggested code in this. Then I executed with
Unfortunately I get an error
Now trying to resolve with
sudo node node-dash.js
module.js:442
throw err;
Error: Cannot find module 'requestify'
at Function.Module._resolveFilename (module.js:440:15)
at Function.Module._load (module.js:388:25)
at Module.require (module.js:468:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/home/pi/node_modules/node-dash-button/node-dash.js:4:18)
at Module._compile (module.js:541:32)
at Object.Module._extensions..js (module.js:550:10)
at Module.load (module.js:458:32)
at tryModuleLoad (module.js:417:12)
at Function.Module._load (module.js:409:3)
sudo npm update -g
sudo npm update -g
This didn't work after a reboot. Now stuck again
ok so creating a test file "node-test.js" with the contents "console.log('hello world');" and running "sudo node node-test.js"
returns the desired results
so it must be the dependencies within the code thats throwing the error.
Error: Cannot find module 'requestify' <---- Is this the issue? cant it find requestify? A path issue?
Last edited by thebeetleuk on Monday 05 December 2016 23:09, edited 1 time in total.
Hi -
pimping my code again.
download it - and the node_modules dir from here:
https://github.com/madgeni/domo-dash
create a folder, put it all in there then:
Create Groups in Domoticz, and put the device you want to control in that.
In the domo-dash.js - put your mac addresses in the array,
and then again, next to the group IDX (find it in domoticz - setup>devices) here:
Then run it using :
nohup sudo node dash_control.js &
//put Dash Mac Addresses here - to find them, use node-dash-button's info: https://github.com/hortinstein/node-dash-button
var dash = dash_button(["ac:63:be:89:c9:b6", "ac:63:be:13:c2:b8", "ac:63:be:02:f7:0b", "50:f5:da:5a:a1:ae"]);
var dict = {
"ac:63:be:89:c9:b6": 5,
"50:f5:da:5a:a1:ae": 4,
got it working!
had to install requestify. doh!
once done then it all works
npm install requestify
Just curious, what are the advantages of the API over Json calls?
async callbacks via the API call
