Domoticz on synology for evohome
fantilator
Domoticz version: 3.5877
Re: Domoticz on synology for evohome
Post by fantilator »
You do not have to add any devices to the hardware. When you run the "evo-update.sh init" command it will add all devices automatically.
Can you just tell me where you have places all files.
I have places all under the evohome-client2 folder in the chroot folder.
josimd
Post by josimd »
currently the files are in the root "evohome-client", so these should be relocated to the /volume1/@appstore/debian-chroot/var/chroottarget/home/evohome-client directory?
fantilator
Yes, this is because you run everything Inside the chroot environment.
When you moved the files, run all commands again.
josimd
Post by josimd »
Have moved the file to volume1/@appstore/debian-chroot/var/chroottarget/home/evohome-client
And have run the command: ./evo-update.sh
But no updates in Domoticz, do I miss a step?
Soulplayer
Post by Soulplayer »
Did you put in a task in dsm itself? Otherwise the values will not update.
For the first run you have to put in the command with init at the end
./evo-update.sh init
josimd
Post by josimd »
No not yet in DSM, but there are no evohome items created in Domoticz after the;
I receive no errors...
fantilator
try to fill in the ip address of your NAS instead of "localhost" or "127.0.0.1" helped here.
josimd
Post by josimd »
I already did;
#fill in Domoticz URL
url='192.168.0.15'
#fill in Domoticz port
port='8084'
#fill in script root e.g. script:///home/<user>/evohome-client script::///usr/local/bin etc
srt='script:///volume1/@appstore/debian-chroot/var/chroottarget/home/evohome-client'
So strange that it wound work....Wiki is quite clear.... but somehow it doesn't work... any other suggestions?
fantilator
What do you see when you dir the evoclient directory?
I use the evohomeclient2, so all my files are inside the "/evohome-client/evohomeclient2" folder
did you also compile the files as stated inside the tutorial?
josimd
Post by josimd »
thanks again for your reply:
followed the wiki:
chmod +x evo-update.sh
Below the directory
-rw-r--r-- 1 root root 269 Nov 25 22:08 :
drwxr-xr-x 6 root root 4096 Nov 30 20:38 .
drwxr-xr-x 3 root root 4096 Nov 29 20:16 ..
drwxr-xr-x 3 root root 4096 Nov 25 21:39 docs
-rwxr-xr-x 1 root root 324 Nov 30 20:28 evoconfig.py
-rw-r--r-- 1 root root 322 Nov 29 20:22 evoconfig.pyc
drwxr-xr-x 2 root root 4096 Nov 25 21:39 evohomeclient
drwxr-xr-x 2 root root 4096 Nov 26 20:57 evohomeclient2
-rw-r--r-- 1 root root 0 Nov 25 22:27 evo-update.py
-rwxr-xr-x 1 root root 0 Nov 27 20:15 evo-update.sh
-rw-r--r-- 1 root root 0 Nov 30 20:16 fixed_script.py
drwxr-xr-x 8 root root 4096 Nov 25 21:39 .git
-rw-r--r-- 1 root root 579 Nov 25 21:39 .gitignore
-rw-r--r-- 1 root root 11323 Nov 25 21:39 LICENSE.txt
-rw-r--r-- 1 root root 1105 Nov 30 20:38 npm-debug.log
-rw-r--r-- 1 root root 1 Nov 27 12:57 readme.md
-rw-r--r-- 1 root root 315 Nov 25 21:39 README.md
-rw-r--r-- 1 root root 40 Nov 25 21:51 setup.cfg
-rw-r--r-- 1 root root 555 Nov 30 20:17 setup.py
/volume1/@appstore/debian-chroot/var/chroottarget/home/evohome-client/evohomeclient2#
drwxr-xr-x 2 root root 4096 Nov 26 20:57 .
drwxr-xr-x 6 root root 4096 Nov 30 20:38 ..
-rw-r--r-- 1 root root 922 Nov 25 21:39 base.py
-rw-r--r-- 1 root root 1418 Nov 26 20:57 base.pyc
-rw-r--r-- 1 root root 4388 Nov 25 21:39 controlsystem.py
-rw-r--r-- 1 root root 4982 Nov 26 20:57 controlsystem.pyc
-rw-r--r-- 1 root root 569 Nov 25 21:39 gateway.py
-rw-r--r-- 1 root root 872 Nov 26 20:57 gateway.pyc
-rw-r--r-- 1 root root 1273 Nov 25 21:39 hotwater.py
-rw-r--r-- 1 root root 2034 Nov 26 20:57 hotwater.pyc
-rw-r--r-- 1 root root 4934 Nov 25 21:39 __init__.py
-rw-r--r-- 1 root root 5809 Nov 26 20:57 __init__.pyc
-rw-r--r-- 1 root root 1469 Nov 25 21:39 location.py
-rw-r--r-- 1 root root 1744 Nov 26 20:57 location.pyc
-rw-r--r-- 1 root root 2653 Nov 25 21:39 zone.py
-rw-r--r-- 1 root root 3445 Nov 26 20:57 zone.pyc
fantilator
my folder structures
volume2/@appstore/debian-chroot/var/chroottarget/home/evohome-client
drwxr-xr-x 6 root root 4096 Nov 16 18:31 .
drwxr-xr-x 4 root root 4096 Nov 13 20:39 ..
drwxr-xr-x 8 root root 4096 Nov 13 12:39 .git
-rw-r--r-- 1 root root 579 Nov 13 12:39 .gitignore
-rw------- 1 root root 12288 Nov 13 13:01 .swp
-rw-r--r-- 1 root root 11323 Nov 13 12:39 LICENSE.txt
-rw-r--r-- 1 root root 315 Nov 13 12:39 README.md
drwxr-xr-x 3 root root 4096 Nov 13 12:39 docs
drwxr-xr-x 2 root root 4096 Nov 13 12:39 evohomeclient
drwxr-xr-x 3 root root 4096 Nov 16 22:55 evohomeclient2
-rw-r--r-- 1 root root 40 Nov 13 21:08 setup.cfg
-rw-r--r-- 1 root root 555 Nov 13 12:39 setup.py
/volume2/@appstore/debian-chroot/var/chroottarget/home/evohome-client/evohomeclient2
drwxr-xr-x 3 root root 4096 Nov 16 22:55 .
drwxr-xr-x 6 root root 4096 Nov 16 18:31 ..
-rw-r--r-- 1 root root 4934 Nov 13 12:39 __init__.py
-rw-r--r-- 1 root root 922 Nov 13 12:39 base.py
-rw-r--r-- 1 root root 4388 Nov 13 12:39 controlsystem.py
-rwxr-xr-x 1 root root 899 Nov 16 18:17 evo-setdhw.sh
-rwxr-xr-x 1 root root 1342 Nov 16 18:15 evo-setmode.sh
-rwxr-xr-x 1 root root 996 Nov 16 22:02 evo-settemp.sh
-rwxr-xr-x 1 root root 1234 Nov 16 22:55 evo-settemp.sh.save
-rwxr-xr-x 1 root root 731 Nov 16 22:30 evo-settemp_test.sh
-rwxr-xr-x 1 root root 6049 Nov 16 12:52 evo-update.sh
-rw-r--r-- 1 root root 344 Nov 16 19:49 evoconfig.py
-rw-r--r-- 1 root root 344 Nov 16 19:58 evoconfig.py.save
-rw-r--r-- 1 root root 300 Nov 16 19:58 evoconfig.py.save.1
-rw-r--r-- 1 root root 379 Nov 16 19:50 evoconfig.pyc
-rw-r--r-- 1 root root 0 Nov 13 22:17 evoconfig.sh
-rw-r--r-- 1 root root 569 Nov 13 12:39 gateway.py
-rw-r--r-- 1 root root 1273 Nov 13 12:39 hotwater.py
-rw-r--r-- 1 root root 1469 Nov 13 12:39 location.py
-rw-r--r-- 1 root root 2653 Nov 13 12:39 zone.py
josimd
Post by josimd »
I'm a little bit further... ./evo-update.sh gives:
File "./evo-update.sh", line 58, in <module>
hwl=json.loads(r.text)
File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 364, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python2.7/json/decoder.py", line 382, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
fantilator
can you try what is posted over here? and return what works and what fails?
thanks to Gordonb3 for the orginal post.
login to NAS via SSH as root:
Chance directory to /volume1/@appstore/debian-chroot/var/chroottarget/home/evohome-client
B3 evohome # python
Python 2.7.10 (default, Nov 11 2015, 23:44:37)
[GCC 4.8.4] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> from evohomeclient2 import evoconfig
>>> from evohomeclient2 import EvohomeClient
>>> client = EvohomeClient(evoconfig.usr,evoconfig.pw)
>>> fi=client.full_installation()
>>> print fi
Which should spit out a bunch of information including your email and home address. This is the evohome part and I think you'll find this to be running correctly.
Exit python:
>>> quit()
now change your directory to /volume2/@appstore/debian-chroot/var/chroottarget/home/evohome-client/evohomeclient2
Test your connection to domoticz:
B3 evohome # python
>>> import evoconfig
>>> import requests
>>> r=requests.get("http://%s:%s/json.htm?type=hardware" % (evoconfig.url,evoconfig.port))
>>> print r.text
Which should give you a json listing of the hardware you enabled in domoticz.
fantilator
I got the settemp and setmode modules working! :D
my solution was, move following files from the /evohome-client/evohomeclient2 folder to the /evohome-client folder
-evo-settemp.sh
-evo-setdhw.sh
-evo-setmode.sh
-evo-update.sh
mv evo-settemp.sh ..
mv evo-setdhw.sh ..
mv evo-setmode.sh ..
mv evo-update.sh ..
change these 4 files:
change lines from:
import evoconfig
to
change the files inside the evohomeclient2 folder:
-evoconfig.py
remove the /evohomeclient2 from the script root
srt='script:///volume2/@appstore/debian-chroot/var/chroottarget/home/evohome-client'
-remove the following files:
-evoconfig.pyc
rm evoconfig.pyc
compile 4 files in the evohome-client
chmod u+x evo-settemp.sh
chmod u+x evo-setdhw.sh
chmod u+x evo-setmode.sh
chmod u+x evo-update.s
h
Change the script in the DSM task scheduler
test run everything again.
Soulplayer
Still trying to get multiple locations to work.
Found this online. Can someone do something with this? I don't think it would work with domoticz.
https://github.com/freeranger/evologger
fantilator
My evo-settemp file looks like this.
import sys
import dateutil.parser
if len(sys.argv)<5:
        until = '0-0-0T00:00:00'
elif sys.argv[4][:1] == '0':
else:
        until = dateutil.parser.parse(sys.argv[4]).strftime('%Y-%m-%dT%H:%M:%SZ')
#connect to evohome web portal @ http://www.mytotalconnect.com
client.locations[0]._gateways[0]._control_systems[0].zones_by_id[sys.argv[1]]._set_heat_setpoint({"HeatSetpointValue":0.0 if len(sys.arg$
open ("/var/tmp/evo-noup.tmp","w")
Soulplayer
If I use your code, I get an error:
-client# ./evo-settemp.sh
  File "./evo-settemp.sh", line 28
SyntaxError: invalid syntax
Edited your code a bit because my files are in evohomeclient folder:
#!/usr/bin/python
# Copyright 2015 - fullTalgoRythm
# Licensed under GNU General Public License 3.0 or later.
# Some rights reserved. See COPYING, AUTHORS.
# @license GPL-3.0+ <http://spdx.org/licenses/GPL-3.0+>
# see http://www.domoticz.com/wiki/Evohome
# see http://evohome-client.readthedocs.org/en/latest/index.html
import evoconfig
import sys
if len(sys.argv)<5:
else:
open ("/var/tmp/evo-noup.tmp","w"))
I thought perhaps there is some code missing so i added:
client.locations[0]._gateways[0]._control_systems[0].zones_by_id[sys.argv[1]]._set_heat_setpoint({"HeatSetpointValue":0.0 if len(sys.arg[b]v)<4 else float(sys.argv[3]),"SetpointMode":int(sys.argv[2]),"TimeUntil":until})[/b]
but then I get the previous error back:
  File "./evo-settemp.sh", line 28, in <module>
    client.locations[0]._gateways[0]._control_systems[0].zones_by_id[sys.argv[1]]._set_heat_setpoint({"HeatSetpointValue":0.0 if len(sys.argv)<4 else float(sys.argv[3]),"SetpointMode":int(sys.argv[2]),"TimeUntil":until})
IndexError: list index out of range
fantilator
That was also my problem, I had to move them to the Evohome-client folder,
have you tried setting the zonetemp with an end time?
If I put it permanently it does not work.
Soulplayer
OMG it works... I thougt I already tried to not use the permanent settings. Thank you so much!
Now that settemp works: does setting the mode for the gateway also work on your system?
josimd
Post by josimd »
Hi Fantilator,
Followed you steps...
>>> print fi
{u'locationInfo': {u'city': u'OosXXXe', u'name': u'Home', u'useDaylightSaveSwitching': True, u'country': u'Netherlands', u'locationOwner': {u'username': u'[email protected]', u'lastname': u'Simdorn ', u'userId': u'1396603', u'firstname': u'JXXX'}, u'streetAddress': u'HXXXringseweg ', u'locationId': u'1660670', u'postcode': u'3233SB', u'locationType': u'Residential', u'timeZone': {u'timeZoneId': u'WEuropeStandardTime', u'currentOffsetMinutes': 60, u'displayName': u'(UTC+01:00) Amsterdam, Berlijn, Bern, Rome, Stockholm, Wenen', u'offsetMinutes': 60, u'supportsDaylightSaving': True}}, u'gateways': [{u'gatewayInfo': {u'gatewayId': u'1529337', u'crc': u'6A47', u'mac': u'00D02D7DC3DF', u'isWiFi': False}, u'temperatureControlSystems': [{u'zones': [{u'name': u'Woonkamer', u'heatSetpointCapabilities': {u'valueResolution': 0.5, u'timingResolution': u'00:10:00', u'maxHeatSetpoint': 35.0, u'minHeatSetpoint': 5.0, u'allowedSetpointModes': [u'PermanentOverride', u'FollowSchedule', u'TemporaryOverride'], u'maxDuration': u'1.00:00:00'}, u'zoneId': u'1844220', u'modelType': u'HeatingZone', u'scheduleCapabilities': {u'timingResolution': u'00:10:00', u'minSwitchpointsPerDay': 1, u'maxSwitchpointsPerDay': 6, u'setpointValueResolution': 0.5}, u'zoneType': u'ZoneTemperatureControl'}], u'systemId': u'1844221', u'modelType': u'EvoTouch', u'allowedSystemModes': [{u'systemMode': u'Auto', u'canBePermanent': True, u'canBeTemporary': False}, {u'systemMode': u'AutoWithEco', u'timingMode': u'Duration', u'canBeTemporary': True, u'canBePermanent': True, u'timingResolution': u'01:00:00', u'maxDuration': u'1.00:00:00'}, {u'systemMode': u'AutoWithReset', u'canBePermanent': True, u'canBeTemporary': False}, {u'systemMode': u'Away', u'timingMode': u'Period', u'canBeTemporary': True, u'canBePermanent': True, u'timingResolution': u'1.00:00:00', u'maxDuration': u'99.00:00:00'}, {u'systemMode': u'DayOff', u'timingMode': u'Period', u'canBeTemporary': True, u'canBePermanent': True, u'timingResolution': u'1.00:00:00', u'maxDuration': u'99.00:00:00'},
root@iSIM_NAS:/volume1/@appstore/debian-chroot/var/chroottarget/home/evohome-client/evohomeclient2# python
Python 2.7.12 (default, Jul 27 2016, 05:41:41)
[GCC 4.9.3 20150311 (prerelease)] on linux2
>>> import evoconfig
>>> import requests
>>> print r.text
"result" : [
"Address" : "",
"DataTimeout" : 0,
"Enabled" : "true",
"Extra" : "",
"Mode1" : 0,
"Mode2" : 0,
"Mode3" : 0,
"Mode4" : 0,
"Mode5" : 0,
"Mode6" : 0,
"Name" : "Dummy",
"Password" : "",
"Port" : 1,
"SerialPort" : "1",
"Type" : 15,
"Username" : "",
"idx" : "3"
"Address" : "",
"DataTimeout" : 0,
"Enabled" : "true",
"Extra" : "",
"Mode1" : 0,
"Mode2" : 0,
"Mode3" : 0,
"Mode4" : 0,
"Mode5" : 0,
"Mode6" : 0,
"Name" : "Alarm",
"Password" : "",
"Port" : 1,
"SerialPort" : "1",
"Type" : 15,
"Username" : "",
"idx" : "4"
"Address" : "",
"DataTimeout" : 0,
"Enabled" : "true",
"Extra" : "",
"Mode1" : 83,
"Mode2" : 9,
"Mode3" : 8,
"Mode4" : 12,
"Mode5" : 47,
"Mode6" : 0,
"Name" : "RFXCOM",
"Password" : "",
/volume1/@appstore/debian-chroot/var/chroottarget/home/evohome-client/evohomeclient2# ./evo-update.sh init
File "./evo-update.sh", line 28, in <module>
File "/usr/lib/python2.7/site-packages/evohomeclient2/__init__.py", line 18, in __init__
self._login()
File "/usr/lib/python2.7/site-packages/evohomeclient2/__init__.py", line 69, in _login
self.access_token = self._convert(r.text)['access_token']
KeyError: 'access_token'
evoconfig.py file: (I use no username + password to login to domoticz..)
#fill in username
usr=''
#fill in pw
pw=''
