[Plugin now available in Beta] Help with Yeelight Bulb
weiweipossible
Re: [Plugin now available in Beta] Help with Yeelight Bulb
Post by weiweipossible »
corbin wrote:I'm fixing up some of the Yeelight commands, and for the mono light there is warm and cool white buttons. Are these modes possible with the mono light?
From the "support" header in discover response message, you can find all the supported actions for each different type of device.
For "mono", it only supports "set_bright", no rgb or ct adjustment.
deennoo
Post by deennoo »
Still waiting my mono one's from ali...made some test with rgbw one with mono selection
using Full Light button doesn't works, it set bulb on a cold with with mid bright, can you help please ?
http://domo-attitude.fr
corbin
Post by corbin »
Thanks, I was thinking I'd missed something seeing those buttons there for the mono light.
corbin
Post by corbin »
How do you change the RGBW to mono in Domoticz?
deennoo
Post by deennoo »
Delet rgbw and add the new as a mono
corbin
Post by corbin »
The reason the Full light button doesn't work as you expect is that only the brightness command is currently sent, as it expects a Mono light where setting brightness is sufficient.
With a RGBW light, it should go to full brightness for the colour it is currently set to. What if you send warm white or cool white prior to the full light command?
deennoo
Post by deennoo »
corbin wrote:The reason the Full light button doesn't work as you expect is that only the brightness command is currently sent, as it expects a Mono light where setting brightness is sufficient.
What do you mean by prior ? before sending full bright ?
corbin
Post by corbin »
yes, if you want a white light at full brightness.
otherwise it will go to full brightness for the currently set colour.
deennoo
Post by deennoo »
Back to rgbw, will spoke about mono when mine arrive.
My probleme is that actually, when i turn on the bulb it start a 100% bright and cold white.
With last domo stable.
As a bed room light : not so good.
I'm helping another HA to implented yeelight, they do it great (as you) on/off don't change temp and bright.
corbin
Post by corbin »
When using the "Limitless_LedOn" command, my lights are turning on to the same brightness they were last at, when I use Domoticz or the Yeelight Android app. Yes the bedroom light is nice to be dim! one of the reasons I started looking for these kind of lights.
So I think your lights could be behaving differently, or maybe you are not triggering the "Limitless_LedOn" command, which sends:
{"id":1,"method":"set_power","params":["on", "smooth", 500]}\r\n
deennoo
Post by deennoo »
I made some dummy device and lua script to improve yeelight implantation, i think that natively domotigz have to add the device for each yeelight bulb
Interest of this dummy device : they can be trigger with api, or scene, or lua script
white temp yeelight.PNG (55.45 KiB) Viewed 2599 times
add to this lua script :
DomDevice = 'White Temp Yeelight';
IP = '192.168.0.207';
PORT = '55443'
--PIN = "4";
if devicechanged[DomDevice] then
   if(devicechanged[DomDevice]=='Off') then
     DomValue = 0;
     runcommandoff = "sudo echo -ne '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";;
     os.execute(runcommandoff);
     DomValue = otherdevices_svalues[DomDevice];
   CalcValue = ((DomValue-1) * 48)+1700;
   if CalcValue==nil then CalcValue=0 end
     runcommand = " sudo echo -ne '{\"id\":1, \"method\":\"set_scene\",\"params\":[\"ct\"," .. CalcValue .. ", 75]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
   os.execute(runcommand);
   print(runcommand)
   print("Color Temp= "..CalcValue);
turn automaticaly bulb and set it to the white temp color choose
yeelight dimmer.PNG (49.96 KiB) Viewed 2599 times
join to this script
[codecommandArray = {}
DomDevice = 'Yeelight Dimmer'; -- here name of your dimmer
TempDevice = 'White Temp Yeelight' -- here name of your white temperature slider
IP = 'youryeelightbulbip';
PORT = '55443'
     DomValue = 0;
    TempValue = otherdevices_svalues[TempDevice];
    CalcValue = ((TempValue-1) * 48)+1700;
     runcommand = "sudo echo -ne '{\"id\":1, \"method\":\"set_scene\", \"params\":[\"ct\", " .. CalcValue .. ", " .. DomValue .. "]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
   print(runcommand)
   print("bright value= "..DomValue);
This Dimmer turn automaticaly On and Off Yeelight Bulb to the dimmer value and the color temp choose on the Color temp Slider
Yeelight Sceen selector :
yeelight sceen.PNG (63.19 KiB) Viewed 2599 times
Working on the lua script
This one allow to choose sceen, as disco can't work, and ccan not be call from the api, for yeelight bulb,
Want to add red alerte sceen need help from @weiweipossible to get mobile app scene if possible, send me an MP please.
Westcott
Post by Westcott »
Hi Deennoo,
I've done much the same with Lua to control my light.
My light is used mainly as a security warning, showing different colours and flash patterns depending on the warning.
It's also a welcome and night light.
they all use different colo(u)r flow 'start_cf' commands, configured in Lua.
Creating Disco won't be too difficult.
It looks like endless smooth 0.5s transitions between red, yellow/green, pale blue, pink
deennoo
Re: RE: Re: [Plugin now available in Beta] Help with Yeelight Bulb
Post by deennoo »
Westcott wrote:Hi Deennoo,
Can you share you lua please ? To see if they use sale kind of api.
Westcott
Post by Westcott »
The code can be included with -
package.path = '/home/pi/domoticz/scripts/lua/?.lua;' .. package.path
YEE = require("Yee")
It can be run either from Domoticz Lua, or from a stand-alone Lua test script.
It should be able to support multiple lamps, but that's untested.
It uses a socket, but could probably use io.popen(url) instead to get the lamp's status.
local Yee = {};
	package.loadlib("core.so", "*")
    local Socket = require "socket"
	local YeeName = 'Study Yee'
	local YeeNames  = {}
    YeeNames[YeeName] = '172.16.176.75'
	local YeeIP = YeeNames[YeeName]
    local YeePort = 55443
	local YeeState
    function TCPopenYee()
        local tcp = Socket.connect(YeeIP, YeePort)
        if not tcp then
        	print("Socket connect failed for Yee")
        	return
--			print("Yee OK")
        tcp:settimeout(2)
        return tcp
	function SendToYee(method, params)
		if not params then params = "" end
		sendStr = string.format('{"id":1,"method":"%s","params":[%s]}\r\n', method, params)
--		sendStr = string.format('{"id":1,"method":"get_prop","params":["power", "bright", "rgb"]} \r\n')
		tcp = TCPopenYee()
    	i, status = tcp:send(sendStr);
    	if not i then
    		print("Yee send failed - "..status)
	    s, status, partial = tcp:receive()
    	if (status) then
    		print("Yee receive - "..status)
    	local line = (s or partial)
--		print(line)
        tcp:close()
	function GetState()
		sendStr = string.format('{"id":1,"method":"get_prop","params":["power","bright","rgb","flowing"]} \r\n')
		tcp = TCPopenYee()
    	if not i then
			return
    	if (status) then
			return
    	local result = (s or partial)
        tcp:close()
		state, bright, rgb, flowing = string.match(result, '%["(%a+)","(%d+)","(%d+)","(%d)"')
		return state, flowing
	function SetPower(param1, speed)
		if not YeeState then YeeState = GetState() end
		if (YeeState ~= param1) then SetSpeed("set_power", param1, speed) end
	function SetSpeed(method, param1, speed)
		if speed then
			effect = "smooth"
			effect = "sudden"
			speed  = 0
		params = string.format('%s,"%s",%d', param1, effect, speed)
	function Yee.Bright(bright, speed)
		SetSpeed("set_bright", bright, speed)
	function Yee.Colour(colour, speed)
		SetSpeed("set_ct_abx", colour, speed)
	function Yee.RGB(hexRGB, speed)
		rgb = tostring(tonumber(hexRGB, 16))
		SetSpeed("set_rgb", rgb, speed)
	function GetAction()
		if not YeeState then YeeState, flowing = GetState() end
		if (flowing == "1") then
			print("Yee is flowing")
			action = -1
		elseif (YeeState == "on") then
--			print("Yee is ON "..YeeState)
			action = 0
		else -- Turn lamp on, action 2 will turn it off afterwards
--			print("Yee is OFF "..YeeState)
			SetSpeed("set_power",'"on"', 500)
			action = 2
		return action
	function Yee.OnFor(secs, colour, bright)
        hex = string.match(colour, "%x%x%x%x%x%x")
		if hex then
			col = tostring(tonumber(hex, 16))
			mode = 1
			col = tostring(colour)
			mode = 2
		action = GetAction()
		if (action > 0) then
			params = string.format('2, %d, "250,%d,%s,%d, %d,7,50,50"', action, mode, col, bright, secs*1000)
			SendToYee("start_cf", params)
			print("Yee on for "..secs)
	function Yee.Pulse(colour, reps, speed, bmax, bmin)
		if colour then col = tonumber(colour, 16) else col = tonumber("aaaaaa", 16) end
		if reps then reps = reps*2 else reps = 6 end
		if not speed then speed = 500 end
		if not bmax  then bmax  = 100 end
		if not bmin  then bmin  = 5 end
			params = string.format('%d,%d,"%d,1,%d,%d,%d,1,%d,%d"', reps, action, speed, col, bmax, speed, col, bmin)
			print("Yee pulse "..reps)
	function Yee.On(speed)
		SetPower('"on"', speed)
	function Yee.Off(speed)
		SetPower('"off"', speed)
	function Yee.Toggle()
		SendToYee("toggle")
	function Yee.Default()
		SendToYee("set_default")
	function Yee.Stop()
		SendToYee("stop_cf")
	function Yee.Set(name)
		YeeIP    = YeeNames[name]
		YeeName  = name
return Yee;
corbin
Post by corbin »
Good work guys, the way Domoticz works scripting is needed to do this fine control. It is a good thing you can make it do what you want rather than be limited to what the GUI offers.
deennoo
Post by deennoo »
Westcott wrote:The code can be included with -
local Yee = {};
	local YeeNames  = {}
	local YeeState
        if not tcp then
        	return
--			print("Yee OK")
        tcp:settimeout(2)
        return tcp
		tcp = TCPopenYee()
    	if not i then
    	if (status) then
--		print(line)
        tcp:close()
	function GetState()
		tcp = TCPopenYee()
    	if not i then
			return
    	if (status) then
			return
        tcp:close()
		if speed then
			effect = "smooth"
			effect = "sudden"
			speed  = 0
			action = -1
			action = 0
			action = 2
		return action
		if hex then
			mode = 1
			mode = 2
		SendToYee("toggle")
	function Yee.Stop()
		YeeName  = name
return Yee;
As i'm not a script coder familiar (i begin with this), please can you comment this ? and add an real lua script who use it ?
deennoo
Post by deennoo »
corbin wrote:Good work guys, the way Domoticz works scripting is needed to do this fine control. It is a good thing you can make it do what you want rather than be limited to what the GUI offers.
Gui can be change, by using appropriate device (not the limitlessled ones who was done for another hardware
Exemple : for rgbw bulb
using a RGBW switch at creation instead of a limitless one (who add unusful button)
and add selector for pre registred scene
and dimmer slider set as a white temp slider.
bright dimmer can stay a dummy and lua script device, i made it for my comfort.
Easy to say, but surely not easy to do for none Domoticz c++ Dev
somiarun
Domoticz version: 3.5877
Post by somiarun »
Hi i have 3 yeelight i am running in my home automation setup. When i register into domoticz yeelight is registered as RGB bulb and i am able to tun on and off lights and as well change colours but i want to create a scene so that when i set the scene normal mode i want the Yeelight to be able to switch to normal Yellow/White mode as opposed to RGB mode - can anyone help please.
I tried few commands with various parameters but cant seem to be able to do so. I even registered the lights only as mono but no luck.
My aim to to setup 3 scenes that i can use with alexa - Normal mode (Normal Yellow/White lights , Movie - Blue colour and Music mode - Trigger Disco Lights)
Any help from the forum would much appreciate
deennoo
Re: Help with Yeelight Bulb
Post by deennoo »
somiarun wrote:Hi i have 3 yeelight i am running in my home automation setup. When i register into domoticz yeelight is registered as RGB bulb and i am able to tun on and off lights and as well change colours but i want to create a scene so that when i set the scene normal mode i want the Yeelight to be able to switch to normal Yellow/White mode as opposed to RGB mode - can anyone help please.
My solution was to use the white dummy dimmer + lua script and then trigger it from scene (it will turn bulb on and off)
somiarun
Post by somiarun »
what do you mean when you say White Dummy Dimmer - you mean add a virtual sensor
I am on domoticz 3.5877 but there is no white dummy dimmer only RGB or RGBW
