StellaZ vs Danfoss Living connect vs Komforthaus Comet ?
guantolento
Domoticz version: LastBeta
Re: StellaZ vs Danfoss Living connect vs Komforthaus Comet ?
Post by guantolento »
Szmalu wrote:
guantolento wrote:danfoss lc-13 need a external temperetur sensor
No it doesn't. Danfoss works fine as it is. It's got build in temperature sensor (just doesn't reporting temperature state outside).
Sorry, but i want tell the same thing. So, it's impossible to know the state of the valve lc-13 or the temperature of the same valve. if i want to start the boiler only when the temperature is under the set point i need to buy a thermometer zwave or 433 mhz. it' correct ? thanks to all.
Master (pi3) - MB sensors + Dummy + Sysfs gpio + 1 NodOn MSP-3 + 1 Aeotec DSB28 Energy Meter + 3 Danfoss RS Room + 7 Danfoss Z Thermostat + 1 Swiid Inter + 9 FGS222
Slave01 (pi2) - MB sensors + Dummy + Weather Underground + 2 FGS223 + 1 FGWPE/F
ervine
Post by ervine »
Use the devolo or the popp version of the danfoss lc13. They report the temperature back.
Verzonden vanaf mijn iPad met Tapatalk Pro
guantolento
but something has used devolo or popp or iam the firts ?
ervine
Post by ervine »
I have the Popp. Working just fine.
guantolento
ervine wrote:I have the Popp. Working just fine.
Now i have 4 LC-13 and i need another 3 valve. Iam just in time to return the LC13 to the store. I'm so confused. I don't know if buy another LC-13 and some thermostat everspreeng to start/stop the boyler from 3 zones (day, night, bathrooom) or take 7 Poop new without the thermostat ande the Popp start/stop the boiler.
Can you post a screenshot of the sensor present in the node Popp ? thank you.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Being able to read the temperature of the the internal thermometer in the valve has nothing to do with a relay to switch a boiler.
It's just that you maybe don't need a extra thermometer in the room. But then you don't have the option to place the thermometer where you want it.
guantolento
Good morning, now i have the LC13 with 3 setpoint imposted in alternative zone hours.
example:
00:00-08:00 18.5°
08:00-16:00 21°
16:00-00:00 19.5°
So this degrees setting in valve are necessari to open or close the valve in function on the temperature read from the same valve ( but i don't know this date).
I can't switch always on the boyler, i want that the boyler come on when the temperature in the room in under the set poin end off when the temperature is over. what i need to take this operation? i think its necessary read the room temperature and comparate the date with the setpoint impostated in the valve.
Egregius
Post by Egregius »
Have you read my reply above?
guantolento
Egregius of course i read your post. Sorry but i don't understand what do you mean. My english is poor and iam sorry for that. If i can i send you a mp tomorrow.
Egregius
Post by Egregius »
It's simple:
for each room you need a thermometer and a valve.
If you use the Popp valve you can use the built-in thermometer, if you use the Danfoss valve you need another thermometer.
For the heater you need a switch with a potential free contact (if your boiler has just a relay input and is not opentherm).
ropske
Domoticz version: V3_8394
Post by ropske »
Egrerius,
I see you are from beitem, not far away from me, i live in Rumbeke ;)
Im wondering, you have opentherm? Or you work with a relay to switch on your heating?
Im planning to order some popp , my heating is from Vaillant , but i see it does not support opentherm :(
Just want to know how someone else have done his installation, maybe some pics?
Egregius
Post by Egregius »
I just removed the room thermostat and placed a horstman relay in the gas heater. At that point I didn't know the Fibaro relays also have a potential free contact, those are cheaper.
I read here the Popp version has the advantage that it sends the temperature. I needed a thermometer in each room for that.
ropske
Post by ropske »
You mean something like this
https://www.sossolutions.be/fibaro-rela ... 0wodPqQBOA ?
I see with the horstman it will shutdowns by itself when its on too long, maybe better for the +-10€ more?
Safety issue
How you activate the relay? By setpoints in domoticz?
Egregius
Post by Egregius »
I didn't know that about the Horstman. No settings at all to configure for this device.
All is done with virtual setpoints, thermometers and valves in my pass2php script. There's quit some intelligence in it. Like stop the heater before the temperature is accomplished to avoid over heating, or start heater before it's to cold. I get a temp histeris of 0.1°C :)
See http://www.domoticz.com/forum/viewtopic ... 23&t=12343 and https://egregius.be/tag/domoticz
ropske
Post by ropske »
aansluiting.pdf
(94.32 KiB) Downloaded 109 times
here you can see the schematic of my vaillant ecotec plus vcw46
my current thermostat is connected now to 3-4 (230V/50Hz)
if a buy the Horstmann relay http://www.vesternet.com/z-wave-horstma ... ceiver-hrt
(like yours?)
where do i need to connect this relay then?
hopefully you can point me in the correct direction :oops:
thank you ;)
Egregius
Post by Egregius »
I would say on the same connectors. That's in the case you want to completely remove the room thermostat.
Another option is to use a double relay. One parallel and one in serie with your room thermostat.
That way you can override the roomthermostat with the first relay (in case you need heat in another room) or interrupt the roomthermostat (in case you're not at home etc).
My relay is defined as "Horstmann ASR-ZW Thermostat Receiver" in Domoticz. Picture looks the same.
I bought mine at https://www.betaalbare-domotica.be/
Secure Boiler Actuator 3A SEC_SSR303 1 € 52,85
ropske
Post by ropske »
You mean this one :
https://www.robbshop.nl/fibaro-schakelmodule-2-1-5-kw
Then i could do what you say (i think) :lol:
seems i need to be quickly, it's an end of life product :)
Egregius
Post by Egregius »
ropske
Post by ropske »
When i connect with a double relay like you said, i can not Harm my Vaillant heater?
This is the manual: https://www.robbshop.nl/amfilerating/fi ... le_id/203/
My thermostaat is now connected to pin3 and 4 at my Vaillant heater
Is it possible to make a drawing of how i should connect all? :oops:
Thank you!
Egregius
Post by Egregius »
How could you harm it?
If it's an ordinary thermostat now al it does: open the 2 wires = off, close/short circuit the 2 wires = on. Quite simple.
Functions:
Q1 Off Q2 Off = No heat
Q1 On Q2 Off = room thermostat controls heater
Q1 Off Q2 On = Domoticz requested heat
Q1 On Q2 On = room thermostat and domoticz requested heat
