Z-wave product: Aoetec RGBW Led Bulb
Domoticz plattform: Raspberry Pi 3
Domoticz version: 3.5979 (Beta release channel)
Z-wave module: RazBerry2
Works perfectly to pair the Led bulb to Domoticz and I'm able to control on/off, dim and change colours.
But as I understand from the manual the LED bulb should have some lightning programs programmed (colour display modes). How can I access control of these modes? As for an example in the manual you have rainbow mode or multi colour mode.
Been searching on the internet but haven't found any solution for this specific task.
Also have in mind that I've only been using Domoticz for the past 6 months and I'm still in a learning process.
Thank you in advance!
Aoetec Z-wave RGBW Led Bulb - How to control colour display modes?
Re: Aoetec Z-wave RGBW Led Bulb - How to control colour display modes?
Found another document with all configurations tables for the Led Bulb. Seems like the parameter 37 should be used for this lamp to activate the different colour display modes.
But unfortunately I don't understand were/how I should configure that to the lamp. Anyone who have any tips would be appreciated.
I found a thread on this forum about the Fibaro RGBW animation programs and they tipsed about urls to configure the different animation programs, could that be the solution for this device?
How would those urls look like?
- emme
- Domoticz version: latest
look if thiscan be applied to your scenario also
I've setted a virtual selector with the links for each program
"We always done this way"
Thank you for your response Emme. I don't understand how I should create the correct urls for this light bulb.
I found a spreedsheet on another forum so I now know how the parameters should look like (in this post mike_1103 have attached an zip file with an excel document which helps you with the parameter values for number 37 and 38).
As an example rainbow mode with smooth transition, unlimited cycle count, fastest change speed and lowest residence time will look like this for parameter 37: 16842240
So now I will try to figure out how to create urls like they have posted for the fibaro rgbw module and after that create a similar virtual switch like Emme created.
To be continued...
To be continued...
Found this json request with developer tools in chrome (f12) https://.../json.htm?type=command¶m=applyzwavenodeconfig&idx=14&valuelist=37_MTY4NDIyNDA%3D_38_LTIwMjM0MDY4MTU%3D_32_SGFpbCBDQw%3D%3D_34_RGlzYWJsZQ%3D%3D_35_RGlzYWJsZQ%3D%3D_36_VW4tcmVib290IENvbG9yZnVsIG1vZGU%3D_80_QmFzaWM%3D_200_QWVvbiBMYWJzIFN0YW5kYXJkIFByb2R1Y3Q%3D_252_VW5sb2Nr_255_Tm9ybWFs_
So now I have the idx for my light bulb and can find the parameter settings how they look when they are url encoded.
Is this the correct method of getting the urls or is there an easier way of getting the urls?
Hi burnwall
I recently posted a question on how to control the actual color of the Aoetec Z-wave RGBW Led Bulb (parameter 39)
viewtopic.php?f=24&t=15715&p=116366&hil ... lb#p116366
as I can only find how to control the Multicolor mode (parameter 37 and 38) through the device settings in Domoticz. By the help of the mentioned spreadsheet it was possible to set the different color modes. But I cannot find a way to control the Color mode by using the switch or scenes.
I run the latest stable on Windows but I'm planning to move Domoticz to a Raspberry. How do you set the color? As I'm too new to this forum I'm not allowed to PM you perhaps you can PM me?
