Fibaro FGS-222 Double Relais Switch_ Double Tap, Hold?
grau
Post by grau »
Hi there,
this is my first post and first steps with domoticz (and it's awesome!)
Mono-Stable Switch on Fibaro Double Relay Switch FGS-222 over Aeotec Z-Stick Gen5 to Domoticz
I just want to use "Double Tap" and "Hold" as Commands and set the Options
14. to "Mono-stable input"
15. Enable Dimmer/Roller shutter control
and 6. Managing the transmission of control commands to the devices from first group of associations (key 1)
to "1"...
But I don't know how to get the signals for "double tap" and "hold" as separate actions (for switching other virtual devices) to Domoticz. Or should there be a "dimmer" then?
Any idea how to do this? Or what I'm doing wrong?
Regards, Thomas
Flopp
Re: Fibaro FGS-222 Double Relais Switch_ Double Tap, Hold?
Post by Flopp »
hi, did you find a way to control a virtual device with double tap?
