Qubino Weather Station ZMNHZD1
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Hi Folks,
I bought myself a Qubino ZMNHZD1 Weather station. https://www.momotica.nl/Domotica/zwave/ ... -Wave-Plus
This weatherstation sends its 433 mhz signals to a z-wave stick.
I am recieving the 433 mhz perfectly with my rfxcom and the station is well included in z-wave. but I don't get devices in z-wave.
At startup I get this for node 44 which is the weather station.
Anyone any idea?
2016-07-11 08:47:32.206 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Direction, Instance: 7
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Unhandled Label: Direction, Unit:
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Velocity, Instance: 6
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 5
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 6
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Rain Rate, Instance: 12
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Unhandled Label: Rain Rate, Unit: mm/h
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Relative Humidity, Instance: 5
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 9
2016-07-11 08:47:32.210 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2016-07-11 08:47:32.210 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 2
2016-07-11 08:47:32.210 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 3
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 4
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 5
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 6
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 7
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 8
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 9
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 10
2016-07-11 08:47:32.225 RFXCOM: Using serial port: /dev/ttyUSB0
Thnx in advance for any help
Jan
JuanUil
Re: Qubino Weather Station ZMNHZD1
Post by JuanUil »
anyone any idea?
piotr
Post by piotr »
What is the point in "converting" from 433mhz to z-wave ? If rfxcom knows the Qubino protocol you can skip the z-wave part.
JuanUil
Post by JuanUil »
because I want to skip my rfxcom
tdv94lnn
Domoticz version: 3.5691
Post by tdv94lnn »
Have you been able to get it to work? I also have some problems with this.
see viewtopic.php?f=12&t=12813&p=91862&hilit=ZMNHZDx#p91862
JuanUil
Post by JuanUil »
Hi There,
I still get all the values by rfxcom but nothing from z-wave.
tdv94lnn
Post by tdv94lnn »
I get som sensor values after updating the openZWave configuration files, but not all...
Varazir
Post by Varazir »
I hade problem with my Qubino(not weather station), I removed and added the node for it and got my to work.
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
tdv94lnn
Post by tdv94lnn »
@Varazir, could you please post you configuration deta regarding this node. What is defined in zwcfg?????.xml file for this node.
Varazir
Post by Varazir »
tdv94lnn wrote:@Varazir, could you please post you configuration deta regarding this node. What is defined in zwcfg?????.xml file for this node.
I have a ZMNHOD1 not ZMNHZD1. As I said I just re added the device to zwave it started to work.
JuanUil
Post by JuanUil »
Hi there,
Has anyone made any progress on recieving the data via z-wave on this weatherstation?
Grtz. Jan
JuanUil
Post by JuanUil »
No one to report any progress?
CrazyFin
Post by CrazyFin »
I registered to this forum as a non-Domoticz user (have tested it a while ago though and use it sometimes for device testing as well).
I am trying to the Qubino Weather Station ZMNHZD1 on Indigo Domotics (with Aeon Labs Z-Wave USB stick, not the new Gen5 stick though) and I experience the same problems there, i.e the Z-Wave dongle for the weather station does not seem to transmit out sensor data for the temp/humidity sensor channel 2, rain sensor and wind sensor.
I can see on the dongle that it does indeed receive data from the sensors but somehow it does not transmit it further on to the Z-Wave controller.
I am not sure if this is a firmware bug or that the dongle transmits its Z-Wave data in wrong way or that the device specifications/command classes are not following the documentation. (See my thread in the Indigo forum at http://forums.indigodomo.com/viewtopic.php?f=58&t=16262).
I tested also with Z-Way Server on Windows together with the Z-Wave.ME UZB stick and same problems there.
Looking in Vera forums it seems that this weather station is not compatible with Vera either.
My dongle seems to have firmware 1.02.
I have emailed Qubino support but no repsonse yet.
CrazyFin
Post by CrazyFin »
Alright, I compiled OpenZWave library 1.4.2268 and used OpenZWave Control Panel on my Ubuntu 14.04 LTS test machine.
No issue to include/add the device to my controller ZWave.ME UZB1 stick (firmware 5.06).
After a few minutes I started to get updates from all 10 sensors/endpoints so the ZMNHZDx device is working as it should.
JorisVandoren
Post by JorisVandoren »
I've bought the same weatherstation and experience the same problems like JuanUil reported.
I have this station now already a couple of months but can't get it working in my z-wave network.
Here I read Jan was able to get it communicating via RFXCOM. I'd like to know what protocols need
to be enabled to start the communication between the sensors and RFXCOM.
Currently I have only AC and Oregon OWL enabled in the RFXtrx433 device.
Greetings,
Joris :?:
JuanUil
Post by JuanUil »
Hi I have,
Blind T1/T2/T3/T4
Oregon scientific
AC
ARC
X10
enabled, succes!!
Jan
tdv94lnn
Post by tdv94lnn »
Is fully supported in OpenHAB2 and works really well. To bad that Domoticz doesnt support it yet
JuanUil
Post by JuanUil »
An old post but since I am completely reconfiguring my Domoticz I was wondering if this weatherstation is now supported with Domoticz.
Anyone succeeded?
Jan
