In New Zealand I can't get solar radiation nor UV on weather underground. I can get predicted however at http://solarview.niwa.co.nz/ (if anyone is interested)
But so thought about buying a weather station that does solar radiation, google came up with this one http://www.amazon.co.uk/Weather-Station ... B00C9MFQ1A (also available here) but would it work with rfxcom? does anyone else have a weather station from AERCUS Instruments. as would be cool if it uses the same protocols as La Crosse or Oregon scientific etc...
cheers
Larry
which weather station for solar radiation to get
b_weijenberg
- Target OS: -
Re: which weather station for solar radiation to get
The Oregon Scientific UVN800 is received by the RFXtrx
http://www.oregonscientificstore.com/UV ... or.product
RFX-433, RFX-433EMC, RFX-868
BristolBaz
I got solar and UV from Forecast IO - http://forecast.io/#/f/-41.4395,172.1936
Derik
- Domoticz version: BETA
Me to...BristolBaz wrote:I got solar and UV from Forecast IO - http://forecast.io/#/f/-41.4395,172.1936
Only i do not understand the data..
what is the forecast time. how many hours in the future?
I will see in the summer., or the data is correct....
Toulon7559
- Domoticz version: <2025
Difficult to understand what the Forecast-values are.
If you compare with calculation results of http://re.jrc.ec.europa.eu/pvgis/apps4/pvest.php# for Monthly Radiation or Daily Radiation no resemblance can be seen .....
Toulon7559
Perhaps this thread in this forum is an interesting entry to getting rough-order-of-magnitude info on local solar radiation, somewhat compensated for actual weather: http://www.domoticz.com/forum/viewtopic ... 23&t=10077
Question for you is which station in your vicinity provides a practical Octa-value
