P1 meter readings - from Toon to USB
rjblake
Post by rjblake »
I have recently installed and gotten Toon working, but over the past weeks it seems that Eneco/Quby's service is the biggest problem regards reliability. That being said, I'm going to interface directly using the P1 interface to get my gas/electric meter readings (at least they'll be consistent) with a cable from www.smartmeterdashboard.nl. Is there any way to move the usage data currently logged using Toon so that I can retain my history in one place, or do I need to start from scratch?
stlaha2007
Re: RE: P1 meter readings - from Toon to USB
Post by stlaha2007 »
rjblake wrote:I have recently installed and gotten Toon working, but over the past weeks it seems that Eneco/Quby's service is the biggest problem regards reliability. That being said, I'm going to interface directly using the P1 interface to get my gas/electric meter readings (at least they'll be consistent) with a cable from http://www.smartmeterdashboard.nl. Is there any way to move the usage data currently logged using Toon so that I can retain my history in one place, or do I need to start from scratch?
Have you investigated the replace device?
You can add dummy p1 meters for electricity and gas and push testdata into it with json-api (see wiki for details).
Feed it a couple of times and try to replace dummy-elec_1 with _elec_2 and also dummy_gas_1 with _gas_2. If thats works for you, let the new meters be created after installing the p1 meter cable and use these to replace your current meters with data collected by Toon already.
Used this with test dummies... Only rfxmeters seem to be not willing to be replaced.
