[Solved]How to? set switch (via GPIO) with temperature?
PeM1664
Post by PeM1664 »
Hi all, I'm using a raspberry for seeing temperature and GPIO for controlling light and heat but how can i set low temperature to turn on a Gpio port? I am looking on the documentation and my raspi domoticz (local)web site but even if I make a scene, I don't find an option for automation heat (switch) function of temperature...
do you have any idea?
tks to you :)
stlaha2007
Re: How to? set switch (via GPIO) with temperature?
Post by stlaha2007 »
You need a script for this lua/php/bash. Even Blockly can help you to start with.
So start with blockly is the easiest.
You create a if block where you define your tempsensor with equal or lower then temp, then define the do part where yku set the switch on.
Also build a second if block within where you set upper limit to switch off the switch.
PeM1664
Post by PeM1664 »
Thanks for your answer! If I understand well I have to use Blockly in event menu in Domoticz and create 2 blocks for define the lowest temperature and the action and the highest temperature and the other action?
PeM1664
Post by PeM1664 »
something like this?
Sans titre.png (115.92 KiB) Viewed 2120 times
PeM1664
Post by PeM1664 »
Greats!! Thanks to you! It's working!
Last edited by PeM1664 on Thursday 24 November 2016 19:13, edited 1 time in total.
stlaha2007
Re: RE: Re: How to? set switch (via GPIO) with temperature?
PeM1664 wrote:Greats!! Thanks to you! It's work!
Nice to hear it works...
