Action Promax
Re: Action Promax
How can i see if i've got ext2 firmware? Boughed this set 3 days ago.
Domotica is v3.4834 but I can't update this to 5877. Stops after 2 seconds/percentage... I'm still looking for an answer to fix this.
Raspberry is connected by LAN (no keyboard, mouse, hdmi attached)
So very new in this material...
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
b_weijenberg
- Target OS: -
Re: Action Promax
No need to update Domoticz.
Download Ext2 firmware from http://www.rfxcom.com/Downloads
Update the RFXtrx433E firmware with the latest version 1009.
You can update the firmware using Domoticz or connect the RFXtrx433E to a Windows system and use RFXflash.
RFX-433, RFX-433EMC, RFX-868
Re: Action Promax
wrong message
Last edited by Melissen on Saturday 19 November 2016 14:31, edited 1 time in total.
Re: Action Promax
wrong message
- 20161119_142024.jpg (116.49 KiB) Viewed 2423 times
- 20161119_142007.jpg (323.04 KiB) Viewed 2423 times
- Schermafdruk 2016-11-19 14.20.47.png (133.24 KiB) Viewed 2423 times
Re: Action Promax
Yeah... after updating the firmware to 1009.hex, it does work.
Now I have to figure out how to update the domoticz from v3.4834 to 5877
Frankm
Re: Action Promax
I've got the non 'e' version of the 433. This means currently i'm not able to control the promax switches. Will there be a firmware upgrade for this or do I need to purchase a new 433E?
Regards Frank
Regards Frank
- Sine
Re: Action Promax
Is it just me ... or has something changed with the intertek support ?
Learning a switch with the testbutton works (ID set to 1 01 01 01, unit 1), but I'm unable to switch it on in domoticz.
When I then try to turn on the newly created switch it does nothing, The promax switch stays off and the switch in domoticz stays off.
It does write to the log however "2016-12-12 22:25:27.181 User: Admin initiated a switch command (525/test2/On)"
I'm using the latest build. 3.6132
The old switches that are already in the system work fine, but when I look at the devices list the newly added switch has an extra character
For reference, it used to look like this:
478 Rfx0 00BE10 2 Bel2 Lighting 5 Intertek,FA500,PROmax Off
525 Rfx0 21A6E0C 1 test2 Lighting 5 Intertek,FA500,PROmax OffRe: Action Promax
Having the same issue as Sine.
The previously learned switches work flawless, but at the moment I can't control any new added switches....
Using Domoticz V3.6046 and rfxtrx433E ext2 firmware v1011
Frankm
Re: Action Promax
I finally managed tomget the right rfxcom, however i'm getting the same problem as above. I can create a switch, switching it onnswitches the real switch on, however te ine in domoticz stays off. The problem this causes is that you cannot switch the switch off. Anyone any ideas? I am running the rfx e version with the 1012 ext2 firmware and domoticz ver 3.0.6169-7 on synology
Thanks in advance
Thanks in advance
