Danfoss LC13 temperature
Luigi87
Re: Danfoss LC13 temperature
Post by Luigi87 »
marcelr wrote:I have a razberry right now, operating the lc-13's through its native software and webinterface. Not an extremely well working environment. It does its job, but that's it. Connected to domoticz, it's probably way better. I bought an aeonlabs usb stick (gen5 IIRC), haven't found the time to play with it yet.
grtz,
marcelr
Ah, Ok. I have now ordered the Z-wave.me UZB. because of the Z-wave plus and the Z-wave.me compatibility. What I want to do is connect the LG-13's (9 pieces) to Domoticz, and combine the setpoint with the actual temp trough a Z-wave temp sensor. When there is too much difference between these two I will command the CV to heat the system (trough the OTGW).
But i need to change also my radiators and valves, so the full test of this system will probably work at the end of this year ;)
I realy like the design and the functions of the LG-13
Goldwing1973
Domoticz version: Stable
Post by Goldwing1973 »
Is there any progress in using the Danfoss LC-13 and Domoticz?
There is a youtube clip showing the Danfoss connected to a Fibaro HC2, it would be nice to be able to do that also with Domoticz
https://www.youtube.com/watch?v=tycEDG3sVSM
And with the HC2 it's apparently also possible to read the temperature from the Danfoss, any luck with Domoticz?
https://www.youtube.com/watch?v=OEb6pUhypmI
Over 50 Z-Wave Devices (Fibaro and Neo), 4xLogitech Hub, 2xPhilips Hue Bridge+55 Lights, 1x Nest Thermostat, 2xNetatmo Weather Station, 1xSkybell v1 Doorbell, 3 Kwikset KEVO Doorlocks and Domoticz running on a Intel NUC
LouiS22
Post by LouiS22 »
Goldwing1973 wrote:Is there any progress in using the Danfoss LC-13 and Domoticz?
With LC-13 you cannot read temperature from the device as it's not supported by the device itself (no built-in thermometer). But, there are two modified/upgraded version of this device sold by Devolo and Popp - with built-in thermometer.
Goldwing1973
Do you mean this one? the POPE010101
http://www.vesternet.com/z-wave-popp-heating-thermostat
and this one? the Devolo Home Control 9356
http://www.devolo.nl/producten/devolo-h ... ermostaat/
LouiS22
Post by LouiS22 »
Goldwing1973 wrote:Do you mean this one? the POPE010101
Yup. But have on look on the forum here, there's an ongoing topic about this device ;)
