But its driving me nuts.. it comes regulary(not always) with the error message that it is running for more than 10 seconds.
Could somebody tell me how I can prevent that.
-- script_device_windowcheck.lua
lat = 'XXX'
lon = 'XXX'
debug = false
tempfilenameRW = '/var/tmp/RainAmount.tmp' -- can be anywhere writeable
totalrain = 0
rainlines = 0
-- Lua Functions
function IsItGonnaRain( minutesinfuture )
url='http://gpsgadget.buienradar.nl/data/raintext/?lat='..lat..'&lon='..lon
if debug then print(url) end
read = os.execute('curl -s -o '..tempfilenameRW..' "'..url..'"')
file = io.open(tempfilenameRW, "r")
-- now analyse the received lines, format is like 000|15:30 per line.
while true do
line = file:read("*line")
if not line then break end
if debug then print('Line:'..line) end
linetime=string.sub(tostring(line), 5, 9)
if debug then print('Linetime: '..linetime) end
-- Linetime2 holds the full date calculated from the time on a line
linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
difference = os.difftime (linetime2,os.time())
-- When a line entry has a time in the future AND is in the given range, then totalize the rainfall
if ((difference > 0) and (difference<=minutesinfuture*60)) then
if debug then print('Line in time range found') end
rain=tonumber(string.sub(tostring(line), 0, 3))
totalrain = totalrain+rain
rainlines=rainlines+1
if debug then print('Rain in timerange: '..rain) end
if debug then print('Total rain now: '..totalrain) end
file:close()
-- Returned value is average rain fall for next time
-- 0 is no rain, 255 is very heavy rain
-- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
averagerain=totalrain/rainlines
return(averagerain)
function round(num, idp)
local mult = 10^(idp or 0)
return math.floor(num * mult + 0.5) / mult
WindowsText = ''
local Window_1 = 'Window 1'
local Window_2 = 'Window 2'
local Window_3 = 'Window 3'
local Window_4 = 'Window 4'
local Window_5 = 'Window 5'
local Window_6 = 'Window 6'
local Windowvar = 0
if ((otherdevices[Window_1] == 'Open')) then Windowvar = Windowvar + 1 end
if ((otherdevices[Window_2] == 'Open') ) then Windowvar = Windowvar + 2 end
if ((otherdevices[Window_3] == 'Open') ) then Windowvar = Windowvar + 4 end
if ((otherdevices[Window_4] == 'Open') ) then Windowvar = Windowvar + 8 end
if ((otherdevices[Window_5] == 'Open') ) then Windowvar = Windowvar + 16 end
if ((otherdevices[Window_6] == 'Open') ) then Windowvar = Windowvar + 32 end
-- print('-- ' .. Windowvar )
if Windowvar == 0 then WindowsText = "All Windows are closed"
elseif Windowvar == 1 then WindowsText = "Window 1 is open"
elseif Windowvar == 2 then WindowsText = "Window 2 is open"
elseif Windowvar == 3 then WindowsText = "Windows 1 and 2 are open"
elseif Windowvar == 4 then WindowsText = "Window 3 is open"
elseif Windowvar == 5 then WindowsText = "Windows 1 and 3 are open"
elseif Windowvar == 6 then WindowsText = "Windows 2 and 3 are open"
elseif Windowvar == 7 then WindowsText = "Windows 1, 2 and 3 are open"
elseif Windowvar == 8 then WindowsText = "Window 4 is open"
elseif Windowvar == 9 then WindowsText = "Windows 1 and 4 are open"
elseif Windowvar == 10 then WindowsText = "Windows 2 and 4 are open"
elseif Windowvar == 11 then WindowsText = "Windows 1, 2 and 4 are open"
elseif Windowvar == 12 then WindowsText = "Windows 3 and 4 are open"
elseif Windowvar == 13 then WindowsText = "Windows 1, 3 and 4 are open"
elseif Windowvar == 14 then WindowsText = "Windows 2, 3 and 4 are open"
elseif Windowvar == 15 then WindowsText = "Windows 1, 2, 3 and 4 are open"
elseif Windowvar == 16 then WindowsText = "Window 5 is open"
elseif Windowvar == 17 then WindowsText = "Windows 1 and 5 are open"
elseif Windowvar == 18 then WindowsText = "Windows 2 and 5 are open"
elseif Windowvar == 19 then WindowsText = "Windows 1, 2 and 5 are open"
elseif Windowvar == 20 then WindowsText = "Windows 2, 3 and 5 are open"
elseif Windowvar == 21 then WindowsText = "Windows 1, 3 and 5 are open"
elseif Windowvar == 22 then WindowsText = "Windows 2, 3 and 5 are open"
elseif Windowvar == 23 then WindowsText = "Windows 1, 2, and 5 are open"
elseif Windowvar == 24 then WindowsText = "Windows 4 and 5 are open"
elseif Windowvar == 25 then WindowsText = "Windows 1, 4, and 5 are open"
elseif Windowvar == 26 then WindowsText = "Windows 2, 4, and 5 are open"
elseif Windowvar == 27 then WindowsText = "Windows 1, 2, 4 and 5 are open"
elseif Windowvar == 28 then WindowsText = "Windows 3, 4, and 5 are open"
elseif Windowvar == 29 then WindowsText = "Windows 1, 3, 4 and 5 are open"
elseif Windowvar == 30 then WindowsText = "Windows 2, 3, 4 and 5 are open"
elseif Windowvar == 31 then WindowsText = "Windows 1, 2, 3, 4 and 5 are open"
elseif Windowvar == 32 then WindowsText = "Window 6 is open"
elseif Windowvar == 33 then WindowsText = "Windows 1 and 6 are open"
elseif Windowvar == 34 then WindowsText = "Windows 2 and 6 are open"
elseif Windowvar == 35 then WindowsText = "Windows 1, 2 and 6 are open"
elseif Windowvar == 36 then WindowsText = "Windows 3 and 6 are open"
elseif Windowvar == 37 then WindowsText = "Windows 1, 3 and 6 are open"
elseif Windowvar == 38 then WindowsText = "Windows 2, 3 and 6 are open"
elseif Windowvar == 39 then WindowsText = "Windows 1, 2, 3 and 6 are open"
elseif Windowvar == 40 then WindowsText = "Windows 4 and 6 are open"
elseif Windowvar == 41 then WindowsText = "Windows 1, 4 and 6 are open"
elseif Windowvar == 42 then WindowsText = "Windows 2, 4 and 6 are open"
elseif Windowvar == 43 then WindowsText = "Windows 1, 2, 4 and 6 are open"
elseif Windowvar == 44 then WindowsText = "Windows 3, 4 and 6 are open"
elseif Windowvar == 45 then WindowsText = "Windows 1, 3, 4 and 6 are open"
elseif Windowvar == 46 then WindowsText = "Windows 2, 3, 4 and 6 are open"
elseif Windowvar == 47 then WindowsText = "Windows 1, 2, 3, 4 and 6 are open"
elseif Windowvar == 48 then WindowsText = "Windows 5 and 6 are open"
elseif Windowvar == 49 then WindowsText = "Windows 1, 5 and 6 are open"
elseif Windowvar == 50 then WindowsText = "Windows 2, 5 and 6 are open"
elseif Windowvar == 51 then WindowsText = "Windows 1, 2, 5 and 6 are open"
elseif Windowvar == 52 then WindowsText = "Windows 1, 5 and 6 are open"
elseif Windowvar == 53 then WindowsText = "Windows 1, 3, 5 and 6 are open"
elseif Windowvar == 54 then WindowsText = "Windows 2, 3, 5 and 6 are open"
elseif Windowvar == 55 then WindowsText = "Windows 1, 2, 3, 5 and 6 are open"
elseif Windowvar == 56 then WindowsText = "Windows 4, 5 and 6 are open"
elseif Windowvar == 57 then WindowsText = "Windows 1, 4, 5 and 6 are open"
elseif Windowvar == 58 then WindowsText = "Windows 2, 4, 5 and 6 are open"
elseif Windowvar == 59 then WindowsText = "Windows 1, 2, 4, 5 and 6 are open"
elseif Windowvar == 60 then WindowsText = "Windows 3, 4, 5 and 6 are open"
elseif Windowvar == 61 then WindowsText = "Windows 1, 3, 4, 5 and 6 are open"
elseif Windowvar == 62 then WindowsText = "Windows 2, 3, 4, 5 and 6 are open"
elseif Windowvar == 63 then WindowsText = "Windows 1, 2, 3, 4, 5 and 6 are open"
minuten=15
RainPrediction = IsItGonnaRain(minuten)
URLtext = string.gsub( WindowsText, " ", "%%20")
if ((Windowvar > 0) and (RainPrediction > 20) and (otherdevices['RainmessageTimer'] == 'Off')) then
commandArray['RainmessageTimer'] ='On'
commandArray['OpenURL']='https://autoremotejoaomgcd.appspot.com/sendnotification?key=XXXXXXXXX&title=Message%20of%20the%20house&text=Precipitation%20is%20expected%20within%2015%20minutes%20and%20'..URLtext..'&url=xxxxxx.myfritz.net:8080'
if devicechanged['WindowsCheck'] == 'On' then
commandArray['WindowsCheck']='Off'
return commandArrayregards Hans
