[Plugin now available in Beta] Help with Yeelight Bulb
Westcott
Re: [Plugin now available in Beta] Help with Yeelight Bulb
Post by Westcott »
Thanks, yes, but I really don't know what I did to get it to work.
Now to find out how to control it with Lua, although the 'Limitless' Wiki has nothing.
Might have to do it with YeeLight API calls, or the yee app I found.
cookerrr
Post by cookerrr »
I've ordered one of these yellights, and am very excited to play with it within domoticz. I've had a few milights with the wifi module and have sort of been unsatisfied with there reliability. I have it set to send commands multiple times cause it seems like sometimes it loses a udp packet for the command. I know this yeelight uses tcp. Does your plugin receive the acknowledgment packets to verify the yeelight received the command, and if it doesn't will it reissue the command to make sure the light gets it? just wondering as this would make this light bulb work allot better than the milight.
Westcott
Post by Westcott »
Hi Cookerrr,
I can't answer for Corbin, who wrote the plugin, but the GUI updates if you change the lamp with another app.
My experience is that the light is rock-solid at receiving commands.
According to the API the lamp immediately sends a response to every command received.
The lamp does all of the hard work interpreting each command, so you can tell it to run a long sequence, it says OK and gets on with it.
Mazzokun
Post by Mazzokun »
I have a question, why homebridge can't start if i'm using together er npm homebridge-yeelight plugin and this domoticz-yeelight plugin?
The Yeelight bulb in domoticz are on roomplan 2 and homebridge devices are on room plan 3..
LouiS22
Post by LouiS22 »
Hi folks, one question:
Is it possible to group several bulbs to act parallel (for example 2 or 4 light switching on or off together)?
deennoo
Re: RE: Re: [Plugin now available in Beta] Help with Yeelight Bulb
Post by deennoo »
LouiS22 wrote:Hi folks, one question:
Using scene or group ? That perfect for this kind of asking
http://domo-attitude.fr
corbin
Post by corbin »
Westcott wrote:Hi Cookerrr,
Yep, that sums it up pretty much.
I do have a different architecture for the code that works better than the polling method (maintaining a TCP socket to each light), but its been put on hold because it introduced another issue that I haven't worked around as yet.
deennoo
Post by deennoo »
Hi there finally got my first one rgbw bulb.
Immediately try with Domoticz. trying various brightness, disco etc etc makes my domoticz crash (have to reboot my VM) using last stable.
After reboot all is ok.
About white color, got an idea, don't know yet if bulb work like this, and if it's possible with Domoticz :
- Instead of create only 1 device, what about set 2 devices ?
- One for RGB bulb part : like milight RGB parts with dimmer of course.
- Second for White bulb part : like rgb one but only one color panel from yellow to cold white with dimmer of course.
deennoo
Re: Help with Yeelight Bulb
Post by deennoo »
weiweipossible wrote:
For example, set following command to bulb and you will see "sunrise" effect:
{"id":1, "method":"start_cf", "params":[3,1,"50,1,16731392,1,360000,2,1700,10,540000,2,2700,100"]}
Please refer to the inter-operation spec (page 12) for detailed explanation.
BTW, if your bulb is in OFF state, use "set_scene" command instead of "start_cf", which is to turn on the bulb firstly and then start color flow effect.
-Wilson
I just try :
nico@maison:~$ echo -ne '{"id":1, "method":"set_scene", "params":[3,1,"50,1,16731392,1,360000,2,1700,10,540000,2,2700,100"]}\r\n' | nc -w1 192.168.0.207 55443
With my bulb set off by domoticz way and i get this :
{"id":1, "error":{"code":-5000,"message":"general error"}}
bulb fw : 1.4.1_45
Westcott
Post by Westcott »
Hi Deennoo,
It's not quite that simple, 'set_scene' has a very different syntax, see here for the full spec -
http://www.yeelight.com/download/Yeelig ... n_Spec.pdf
deennoo
Post by deennoo »
corbin wrote:To compile my latest version, follow the instructions on the wiki at http://www.domoticz.com/wiki/Installing ... rom_Source
but you will need to change
git clone https://github.com/domoticz/domoticz.git dev-domoticz
to
git clone https://github.com/corbinmunce/domoticz.git dev-domoticz
Done on me side, to follow your work : did you change update script to your repro or do i need to recompil each time ?
corbin
Post by corbin »
deennoo wrote:Hi there finally got my first one rgbw bulb.
Are you still having a crash problem if you use Yeelight after the reboot?
corbin
Post by corbin »
You will need to recompile each time you make a change, which was fairly quick in my Linux VM.
deennoo
Post by deennoo »
No don't know what happen.
No problem with jour github master version
deennoo
Post by deennoo »
Ok done thx
stromboli59
Domoticz version: 3.5985
Post by stromboli59 »
I have the yeelight bulb white and i integrated the bulb in lua. it works but when i use the xiaomi app domoticz is not refresh.
it's normal because i don't keep the connection alive.
how i proceed:
I wrote a script in python to discover the id of my bulb (with udp)
When i receipt the id and the ip adress, i wrote a script in lua (with tcp).
Before to open socket in lua with domoticz i upgrade lua to accept socket.
i use the api of the color yeelight bulb to do this and i'm lucky because it's the same api.
If you want i can wrote a procedure and give you my script.
deennoo
Post by deennoo »
Just working on white bulb integration with domoticz (without lua or python) just missing the full light button and i will send a pull request.
Working on a lua script to have a dimmer for white color temp (from 1700 to 6500) just missing time to finish order send.
deennoo
Post by deennoo »
Hi there.
On my side a made a LUA Script for change white temp from warm to cold.
Need a dummy selector change as a dimmer and this script_device_yourname.lua (or set it on the events editor :
DomDevice = 'dimmyee'; --dummy selector switch set as a dimmer slide
IP = '192.168.0.207'; --yeelight bulb ip
PORT = '55443' -- yeelight bulb port
if devicechanged[DomDevice] then
   if(devicechanged[DomDevice]=='Off') then
     DomValue = 0;
     DomValue = otherdevices_svalues[DomDevice];
   CalcValue = ((DomValue-1) * 48)+1700;
   if CalcValue==nil then CalcValue=0 end
   runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_ct_abx\",\"params\":[" .. CalcValue .. " ,\"smooth\", 500]}\\r\\n' | nc -w1 " .. IP .. " " .. PORT .. "";
   os.execute(runcommand);
   --print(runcommand)
   --print("Color Temp= "..CalcValue);
--Surely this fonction have to be native on domoticz with json api
corbin
Post by corbin »
I'm fixing up some of the Yeelight commands, and for the mono light there is warm and cool white buttons. Are these modes possible with the mono light?
deennoo
Post by deennoo »
corbin wrote:I'm fixing up some of the Yeelight commands, and for the mono light there is warm and cool white buttons. Are these modes possible with the mono light?
No works with rgbw too, all my test are made with this one
