sorry
Fibaro RGBW control by Fibaro switch Topic is solved
- emme
- Domoticz version: latest
Re: Fibaro RGBW control by Fibaro switch
uh..
sorry
sorry
"We always done this way"
piokuc
No
It no works ok. Because when i Turn OFF KINKIET for about some time it Turn ON automatical.
I dont know what is it.
- emme
leave only the script and remove the secondary dependecy from devices....
piokuc
ok
I corrected script and now works fast and good:
BTW
Problem which i post with setting SLAVE/SECONDARY device also should be repaired by developer.
@emme thanks for your HELP
if devicechanged['Kinkiet'] and otherdevices['Kinkiet'] == 'On' then
if otherdevices['Switch2'] == 'Off' then
commandArray['Switch2'] = 'On'
if devicechanged['Kinkiet'] and otherdevices['Kinkiet'] == 'Off' then
if otherdevices['Switch2'] == 'On' then
commandArray['Switch2'] = 'Off'
if devicechanged['Switch2'] and otherdevices['Switch2'] == 'On' then
if otherdevices['Kinkiet'] == 'Off' then
commandArray['Kinkiet'] = 'On'
if devicechanged['Switch2'] and otherdevices['Switch2'] == 'Off' then
if otherdevices['Kinkiet'] == 'On' then
commandArray['Kinkiet'] = 'Off'
return commandArrayProblem which i post with setting SLAVE/SECONDARY device also should be repaired by developer.
piokuc
BTW
I can use script lua to control relay by GPIO from directory /scripts to use it in GUI in menu EVENTS ?
-- script_device_Zaluzje_pietro.lua
local sensor = 'Zaluzje pietro'
if (devicechanged[sensor] == 'On') then
print ("Odsloniecie zaluzji na pietrze przez przekaznik na GPIO 19")
os.execute ("/usr/local/bin/gpio export 19 in")
os.execute ("/usr/local/bin/gpio export 19 out")
os.execute ("sleep 0.1")
if (devicechanged[sensor] == 'Off') then
print ("Zasloniecie zaluzji na pietrze przez przekaznik na GPIO 16")
os.execute ("/usr/local/bin/gpio export 16 in")
os.execute ("/usr/local/bin/gpio export 16 out")
if (devicechanged[sensor] == 'Stop') then
print ("Ustawienie zaluzji na pietrze w pozycji MY przez przekaznik na GPIO 13")
os.execute ("/usr/local/bin/gpio export 13 in")
os.execute ("/usr/local/bin/gpio export 13 out")
return commandArray- emme
GPIO needs to be exported BEFORE domoticz Start (see http://www.domoticz.com/wiki/GPIO )
then you can see them as devices
piokuc
yes ok but if now i use script in directory i can not exported GPIO. But if i want use scipt in event i must exported ?
- emme
if you want to use GPIO it would be better to export them and configure the hardware in domoticz
Running from a script is not a good idea:
each os.execute is a different thread, so except the first, all others generate an error for missing gpio definition
by the time the os.execute finish, all the settings regard the GPIO are lost... no more output, no more input
If you have always connected a switch to a gpio... than configure it as hardware
piokuc
but how control gpio in lua script by Events menu ?
