Control LED with RFXtrx433 USB 433.92MHz
- CopyCatz
- Developer
- Target OS: -
Re: Control LED with RFXtrx433 USB 433.92MHz
On the remote I see color up & down, can we specify an rgb value through rfxcom?
Definitely very interesting. Since I'm rather clueless on led lightning what other components should I order on dx?
Does anyone have the answer to this question? I already have a RGB led strip. Controlling it with Domoticz would be great!CopyCatz wrote:On the remote I see color up & down, can we specify an rgb value through rfxcom?
- robpow
- Domoticz version: Beta :)
Not from what I've seen. The LWRF RGB LED support is the same as what the LWRF RGB remote provides which is, colour and subcolour selection and automatic cycling. No direct colour selection.goedh452 wrote:Does anyone have the answer to this question? I already have a RGB led strip. Controlling it with Domoticz would be great!CopyCatz wrote:On the remote I see color up & down, can we specify an rgb value through rfxcom?
Matt
tjoep
- Target OS: -
So this controller can be controlled by Domoticz? That would be great.jeroenkl wrote:http://dx.com/p/mini-rgb-led-wireless-r ... 025-191275
is working!
The version non-RGB isn't!
Is it also possible to control the specific colors?
b_weijenberg
- Target OS: -
The RGB LED driver can only be switched ON/OFF.
It has no color selection but a color cycle with only a few colors.
The MDREMOTE is a one color LED driver.
Some other RGB LED drivers will be tested soon and hopefully with color selection.
RFX-433, RFX-433EMC, RFX-868
b_weijenberg
- Target OS: -
RFXtrx433 Type1 version 71 can control these dx.com RGB modules:
This one has a learn option and any ID can be used: http://dx.com/p/rf-remote-touch-rgb-controller-130913
This one has a fixed ID and the ID of the remote must be used: http://dx.com/p/wireless-touch-panel-re ... ight-67412
Use Type2 firmware to receive the remote ID
Re: Sv: Control LED with RFXtrx433 USB 433.92MHz
Great, let's hope for some domoticz love to support these tob_weijenberg wrote:RFXtrx433 Type1 version 71 can control these dx.com RGB modules:
Using Tapatalk
I have a few of these at home to, can they be added to domoticz, if so, how do i figure out id/unit code if they are lightwave devices?tjoep wrote:So this controller can be controlled by Domoticz? That would be great.jeroenkl wrote:http://dx.com/p/mini-rgb-led-wireless-r ... 025-191275
is working!
Using Tapatalk
kylegordon
- Domoticz version: Trunk
I've got hold of 2 of these lovely MDRemote dimmers, and they're absolutely tiny and nice
I've been able to grab their codes using the display undecoded feature of my RFXCom, but I'm wondering how to get Domoticz to control them. Is there a place that I can plug the ID into so that it will control the unit?
Cheers
Kyle
Cheers
Kyle
1 x HP DL380 & KVM
1 x RPI
1 x RFXtrx433 V78
11 x LWRF Switches
1 x LIFX
2 x Echo Dots
6 x Byron PIRs
2 x Nexa PIRs
2 x Kodi
2 x ESP8266 MQTT
1 x GPIO/MQTT PIR
1 x GPIO(PWM)/MQTT LEDs
1 x GPIO(SPI)/MQTT LPD6803 LEDs
Lots of Node-Red glue
1 x RPI
1 x RFXtrx433 V78
11 x LWRF Switches
1 x LIFX
2 x Echo Dots
6 x Byron PIRs
2 x Nexa PIRs
2 x Kodi
2 x ESP8266 MQTT
1 x GPIO/MQTT PIR
I've bought one of these devices, and they work fine in the RFXManager.fldc wrote:Great, let's hope for some domoticz love to support these tob_weijenberg wrote:RFXtrx433 Type1 version 71 can control these dx.com RGB modules:
Is there anyway to add these devices in Domoticz?
Developer of phpMyDomo, a Web Interface for Domoticz
kylegordon
The other day I created this request in the tracker http://www.domoticz.com/forum/tracker.php?p=2&t=108
Not sure if it can be voted upon, but you can certainly subscribe to it.
1 x HP DL380 & KVM
1 x RPI
1 x RFXtrx433 V78
11 x LWRF Switches
1 x LIFX
2 x Echo Dots
6 x Byron PIRs
2 x Nexa PIRs
2 x Kodi
2 x ESP8266 MQTT
1 x GPIO/MQTT PIR
1 x RPI
1 x RFXtrx433 V78
11 x LWRF Switches
1 x LIFX
2 x Echo Dots
6 x Byron PIRs
2 x Nexa PIRs
2 x Kodi
2 x ESP8266 MQTT
1 x GPIO/MQTT PIR
- sincze
- Domoticz version: 2024.4
Just ordered my first RGB 3028 led strip.
As a lot of DX items described in this topic are sold out
, what RGB controller should I buy to use the strip in Domoticz and my trusty RFXCom ??
In a different topic I found the TRC02
http://www.aliexpress.com/item/Free-Shi ... .17.szannb
Seems to be a little 'expensive'
compared to the cost of the LED strip
http://www.aliexpress.com/item/Big-Prom ... 92574.html
Or something like this would also work as it seems to be supported natively by domoticz itself:
http://www.aliexpress.com/item/mi-light ... 32503.html
http://www.aliexpress.com/item/New-Dimm ... 59729.html
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
SDISDI
- Domoticz version: 3.4834
Quick silly question!
I bought the DX.COM TRC02 remote (with 3 batteries) - I am trying to learn the ID of the remote. Can I do this inside Domoticz or do I need to use other software?
Thanks.
Thanks.
RFXtrx433E
Hive 2 Active Heating
Owl CM180 Energy Monitor
Various HomeEasy Receivers
LightwaveRF Plug-in sockets
b_weijenberg
- Target OS: -
See chapter 10 in the RFXtrx User Guide.
beware: some new TRC02 models have again another protocol implemented by our Chinese friends. This version is not working.
Users browsing this forum: willemd and 1 guest
