homebridge-edomoticz Plugin
TheRamon
Re: homebridge-edomoticz Plugin
Post by TheRamon »
@simon_rb:
I have just fixed the issue with brightness. How I reproduced it:
- Open Home app
- Dim value to 50% or so.
- Turn off the lamp
- Close and kill Home app
- Reopen Home app
- Turn on the lamp (would return to 100% here..)
Have also committed a new version to the master branch.
TheRamon
Post by TheRamon »
@hpapagaj:
It's really really hard for me to reproduce this issue. I saw you're not using MQTT so I've turned that off on my side, too.
Please have a look at my logs. I have created two scenarios. One where the light was already on at 50%~ish. One where the light was totally off (turned it off when the light was 50%~ish).
I have added the Domoticz log and the Philips Hue (emulator) log. Please see what happens.
You'll see the Hue light report brightness 252. That's 100%. (There's still a bug that prevents me from sending 255. But that's another problem).
Light on, 50%. -> SIRI: Dim light 100%.
Domoticz: 2016-11-10 11:09:49.935  User: Admin initiated a switch command
Domoticz: 2016-11-10 11:09:49.937  (Hue Bridge Emulator) Lighting Limitless/Applamp (Hue Lamp 1)
Philips Hue: Thu, 10 Nov 2016 11:09:49   [{"success":{"/lights/1/state/bri":252}},{"success":{"/lights/1/state/on":true}}]
Light was off, last state was 50%. -> SIRI: Dim light 100%.
Domoticz: 2016-11-10 11:11:25.941  User: Admin initiated a switch command
Domoticz: 2016-11-10 11:11:25.943  (Hue Bridge Emulator) Lighting Limitless/Applamp (Hue Lamp 1)
Domoticz: 2016-11-10 11:11:25.944  User: Admin initiated a switch command
Domoticz: 2016-11-10 11:11:25.946  (Hue Bridge Emulator) Lighting Limitless/Applamp (Hue Lamp 1)
Philips Hue: Thu, 10 Nov 2016 11:11:25   [{"success":{"/lights/1/state/on":true}}]
Philips Hue: Thu, 10 Nov 2016 11:11:25   [{"success":{"/lights/1/state/bri":252}},{"success":{"/lights/1/state/on":true}}]
simon_rb
Post by simon_rb »
TheRamon wrote:@simon_rb:
- Open Home app
- Turn off the lamp
- Reopen Home app
Excellent, I shall try it out tonight when I get home. That really was quick! Top man!
UPDATE:- Hasn't fixed my issue. Force closing and reopening the app doesn't seem to replicate my fault as I tried that before I updated. If you restart homebridge then turn on a dimmer it will jump to 100% and doesn't remember the Domoticz value. So my wall lights said 80% in domoticz, I turned them on from Home App and it went straight to 100% and my wall lights turned on at 80% (Domoticz value) then jumped straight to 100%, Domoticz now shows them at 100%. Hope that helps. If I lower them to 80%, turn them off and when turning them back on they will remember the 80% however if I leave it 5 mins and turn them back on it repeats the same thing (going to 100% and changing domoticz to 100%)
UPDATE2:- Bizzarely is currently working! I'll keep and eye on it. Cheers TheRamon!!
TheRamon
Post by TheRamon »
I can imagine cached values being empty after restarting "the code". Apparently first time value caching is bugged since it goes to 100%. I'll have a look anyway!
TheRamon
Post by TheRamon »
^ Have just fixed the dimmer issue. Values are now saved and fetched properly, even when terminating the Homebridge plugin.
Please see master for a new commit.
simon_rb
Post by simon_rb »
Cheers dude. Amazing work. :)
UPDATE:- Have reset Homebridge after the latest update and its remembered the dimmer values. Top man! Thanks again.
madrian
Post by madrian »
TheRamon wrote:@hpapagaj:
Hi, today I updated to the latest version too, still no luck.
2016-11-11 22:18:08.359 User: Admin initiated a switch command (25/LED/Set Level)
2016-11-11 22:18:08.365 LUA: dev Set Level: 96 %
2016-11-11 22:18:08.365 LUA: Value received from Domoticz was 31
2016-11-11 22:18:08.365 LUA: Calculated value for ESP is 1023
2016-11-11 22:18:08.365 LUA: Dimming LED to 1023
2016-11-11 22:18:08.365 LUA: echo Fadetimer=2000,LED1_target=1023 | socat - TCP:192.168.1.10:43333
2016-11-11 22:18:08.360 (Quinled_1) Lighting 5 (LED)
2016-11-11 22:18:08.780 User: Admin initiated a switch command (25/LED/On)
2016-11-11 22:18:08.787 LUA: dev On
2016-11-11 22:18:08.787 LUA: Value received from Domoticz was 0
2016-11-11 22:18:08.788 LUA: Calculated value for ESP is 8
2016-11-11 22:18:08.788 LUA: Dimming LED to 8
2016-11-11 22:18:08.788 LUA: echo Fadetimer=2000,LED1_target=8 | socat - TCP:192.168.1.10:43333
2016-11-11 22:18:08.781 (Quinled_1) Lighting 5 (LED)
homebridge.log
[eDomoticz] LED sent command succesfully.
Here is the LUA script, which is watching the LED status: here. It's so simple, it's only combines together the value of the dimmer + some parameter.
One more info:
Don't brother with this one. Received value was 0, because I can't receive the last state of the switched off dimmer ( :evil: ), so we switching to the first brightness, which is 8.
The only question is that why it is still requesting an On command after Set Level. :twisted:
aram
Domoticz version: V3.6707
Post by aram »
I have an outdoor Oregon temp/humidity/pressure device + weather underground setup. on domoticz web interface all the measurements are correct.
however using Eve and Home apps negative temperature values are converted to positive. e.g. now its -4.8C outside, it shows as 4.8C in Eve and 5C in Home. I had the same issue with both non MQTT version and after switching to MQTT. Bug or an issue on my side?
Another strange issue - Eve shows all devices from Domoticz while Home shows Unsupported or does not show at all. is this expected behaviour?
Raspberry PI2 + Aeon Stick Gen5, Motion Sensor, Energie Meter 2e + Fibaro Switches, Motion Sensors, Wall plugs + Everspring Flood Sensors+ RFLink + RFXcom + Oregon temp\hum + Soil sensor + Global Cache + Wemo + Mysensors ESP WiFi Gateway (sensors in dev)
simon_rb
Post by simon_rb »
@TheRamon,
I have a 100 step dimmer that for some reason is 1% below the domoticz dimmer value. Its a 0-99 step dimmer.. I'll say set my Surround Sound to 65 and it will set it to 64 in domoticz.. However if it set it to 65 in Domoticz it will stay at 64 within Homekit.. Can't quite figure it out lol
Just checked all my 0-99 dimmers and all behave the same lol 1% out when using Siri or Homekit sliders
MikeF
Domoticz version: V2022.2
Post by MikeF »
@simon_rb, what do you use for your 100-step dimmers?
simon_rb
Post by simon_rb »
MikeF wrote:@simon_rb, what do you use for your 100-step dimmers?
LMS player and Denon Amp volumes
G3rard
Domoticz version: No
Post by G3rard »
@TheRamon
I also have a 100 step dimmer (just as simon_rb) and have an issue when updating it via Siri.
2016-11-12 15:42:29.022 Dummy: Light/Switch | Sonos keuken volume
2016-11-12 15:42:29.021 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":411,"switchcmd":"On"}
2016-11-12 15:42:28.871 Dummy: Light/Switch | Sonos keuken volume
2016-11-12 15:42:28.871 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":411,"level":30,"switchcmd":"Set Level"}
It is sending a On command after updating the level. That is causing the volume being set to 0.
Strange thing is that I updated eDomoticz to the latest version and then added the above switch (idx=411).
With a switch which was already there before updating eDomoticz, the On command is being sent before the level update (see below idx=409) and then it is working fine.
2016-11-12 15:40:26.094 Dummy: Light/Switch | Sonos kantoor volume
2016-11-12 15:40:26.094 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":409,"level":20,"switchcmd":"Set Level"}
2016-11-12 15:40:25.943 Dummy: Light/Switch | Sonos kantoor volume
2016-11-12 15:40:25.942 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":409,"switchcmd":"On"}
Information on the dimmer
"SubType" : "Switch",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
Any idea's how to prevent the On command from being send, or at least being send before setting the level?
Edit: SOLVED, did a npm update but that's not containing the latest git changes.
Thanks simon_rb :)
Last edited by G3rard on Saturday 12 November 2016 23:03, edited 3 times in total.
Not using Domoticz anymore
simon_rb
Post by simon_rb »
@G3rard
Have you updated from the latest branch via git rather than NPM. I don't think the fix has been implemented to NPM branch yet..
The behaviour your describing is what was happening to me before TheRamon fixed the issue.
G3rard
Post by G3rard »
Used NPM update indeed. Shall update via Git this evening. Cheers.
MikeF
Post by MikeF »
I believe that it is the case that the iOS 10 Home app doesn't support combined temp / humidity / pressure sensors - I have the same with a MySensors node which I built - shows OK in Eve.
G3rard
Post by G3rard »
simon_rb wrote:@G3rard
I indeed updated via NPM earlier, so to update via git I have done the following steps:
sudo rm -r /usr/lib/node_modules/homebridge-edomoticz/
then in /usr/lib/node_modules/
sudo git clone https://github.com/PatchworkBoy/homebridge-edomoticz.git
But restarting homebridge gives the following error:
Error: The requested platform 'eDomoticz' was not registered by any plugin.
What am I missing? I tried a 'npm update' but that makes no difference.
Also the homebridge-edomoticz gets installed in that folder, so that went okay.
Edit: solved it by manually updating the changed files in the homebridge-edomoticz/lib folder.
But there must be an easier way :?
At least the dimmer issues are gone now :mrgreen:
G3rard
Post by G3rard »
simon_rb wrote:@TheRamon,
Seems to be something that is caused by MQTT. When sending the following to MQTT directly
mosquitto_pub -h localhost -t "domoticz/in" -m '{"command":"switchlight","idx":409,"level":2,"switchcmd":"Set Level"}'
it also sets the level 1 lower.
I have changed the following code in domoticz_accessory.js
var dim = (level / this.factor == 15) ? 16 : level / this.factor;
to
var dim = (level / this.factor == 15) ? 16 : (level / this.factor) + 1;
Not sure although if that is the best solution.
simon_rb
Post by simon_rb »
Sorry G3rard, been out. Have you got the git working?
G3rard
Post by G3rard »
No, solved it by manually updating the changed files in the homebridge-edomoticz/lib folder.
Have an issue when updating via git, see http://www.domoticz.com/forum/viewtopic ... 99#p103888.
simon_rb
Post by simon_rb »
Glad you got it to work. Might have to do the above if that fixes the 1% discrepancy.. maybe TheRamon will implement it..
