Ubuntu 14.04 installation failed
Richgam
Post by Richgam »
Hello everyone.
Just today I have started to install, this is my first time, domotic and it is very difficult to me.
I have configured the steps from installation guide "https://www.domoticz.com/wiki/Linux" and the make commands fail :o :
domoticz@domoticz:~/domoticz$
domoticz@domoticz:~/domoticz$ make
[  1%] Built target domoticz_gch
[ 14%] Built target lua
[ 15%] Built target sqlite
-- Found Git: /usr/bin/git (found version "1.9.1")
[ 15%] Built target revisiontag
[ 23%] Built target mqtt
[ 24%] Building CXX object CMakeFiles/domoticz.dir/main/EventSystem.cpp.o
/home/domoticz/domoticz/main/EventSystem.cpp: In member function ‘void http::server::CWebServer::RType_Events(http::server::WebEmSession&, const http::server::request&, Json::Value&)’:
/home/domoticz/domoticz/main/EventSystem.cpp:4089:31: error: conversion from ‘long long unsigned int’ to ‘Json::Value’ is ambiguous
      root["result"][ii]["id"] = itt->ID;
/home/domoticz/domoticz/main/EventSystem.cpp:4089:31: note: candidates are:
In file included from /home/domoticz/domoticz/main/../hardware/../json/json.h:10:0,
                 from /home/domoticz/domoticz/main/../hardware/Kodi.h:8,
                 from /home/domoticz/domoticz/main/EventSystem.cpp:9:
/home/domoticz/domoticz/main/../hardware/../json/value.h:312:3: note: Json::Value::Value(bool)
   Value(bool value);
/home/domoticz/domoticz/main/../hardware/../json/value.h:290:3: note: Json::Value::Value(const char*) <near match>
   Value(const char* value); ///< Copy til first 0. (NULL causes to seg-fault.)
/home/domoticz/domoticz/main/../hardware/../json/value.h:290:3: note:   no known conversion for argument 1 from ‘long long unsigned int’ to ‘const char*’
/home/domoticz/domoticz/main/../hardware/../json/value.h:289:3: note: Json::Value::Value(double)
   Value(double value);
/home/domoticz/domoticz/main/../hardware/../json/value.h:287:3: note: Json::Value::Value(Json::Value::UInt64)
   Value(UInt64 value);
/home/domoticz/domoticz/main/../hardware/../json/value.h:286:3: note: Json::Value::Value(Json::Value::Int64)
   Value(Int64 value);
/home/domoticz/domoticz/main/../hardware/../json/value.h:284:3: note: Json::Value::Value(Json::Value::UInt)
   Value(UInt value);
/home/domoticz/domoticz/main/../hardware/../json/value.h:283:3: note: Json::Value::Value(Json::Value::Int)
   Value(Int value);
/home/domoticz/domoticz/main/../hardware/../json/value.h:282:3: note: Json::Value::Value(Json::ValueType) <near match>
   Value(ValueType type = nullValue);
/home/domoticz/domoticz/main/../hardware/../json/value.h:282:3: note:   no known conversion for argument 1 from ‘long long unsigned int’ to ‘Json::ValueType’
/home/domoticz/domoticz/main/../hardware/../json/value.h:323:10: error:   initializing argument 1 of ‘Json::Value& Json::Value::operator=(Json::Value)’
   Value& operator=(Value other);
make[2]: *** [CMakeFiles/domoticz.dir/main/EventSystem.cpp.o] Error 1
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
make: *** [all] Error 2
I have installed simple-json (python library) and the problem is persistent, How i can solve it? I'm desperate :cry: any help will be welcome.
sj3fk3
Re: Ubuntu 14.04 installation failed
Post by sj3fk3 »
Richgam wrote:Hello everyone.
You are compiling a C++ program installing a python library won't help in this case. Did you install development tools and libraries needed for compiling Domoticz?
sudo apt-get install build-essential nano cmake git libboost-dev libboost-thread-dev libboost-system-dev libsqlite3-dev curl libcurl4-openssl-dev libssl-dev libusb-dev zlib1g-dev
SweetPants
Post by SweetPants »
This is a know issue and is being worked on.
Richgam
Post by Richgam »
Thank you for your answers,but... then what is the best way to install domiticz for testing prouposes?
Are there older versions? Maybe in rasberrypi? What is the alternative?
Thanks in advance
SweetPants
Richgam wrote:Are there older versions? Maybe in rasberrypi? What is the alternative?
Start with the stable version https://sourceforge.net/projects/domoticz/files/
gizmocuz
Post by gizmocuz »
Compilation should work again
SweetPants
gizmocuz wrote:Compilation should work again
yep, it does
Richgam
Post by Richgam »
Hi guys!
Thanks a lot! Now it works fine
