http://dl.free.fr/vI9q5mZFw - V1.102
Flat Design for icon (replace www/images)
Chakkie
Re: Flat Design for icon (replace www/images)
Hi gevaudan and all,
I am pretty unfamiliar with Raspberry and domoticz. Could you please step by step tell me how I can upload your Flat Design theme to the raspberry?? Really appreciated. Your theme looks really nice. Thanks
Chakkie
Hi I have got the icons working.
I am using Chrome. To clear the cache I use CCleaner. And remember the Chrome has to be completely closed. Open the Task Manager and see if the Chrome is still running in the background.
- gevaudan
- Domoticz version: 2.2563
Hello Chakkie,Chakkie wrote:Hi gevaudan and all, I am pretty unfamiliar with Raspberry and domoticz. Could you please step by step tell me how I can upload your Flat Design theme to the raspberry?? Really appreciated. Your theme looks really nice. Thanks
I'm sorry, but installation requires some knowledge (use unix command lines) . If this is too hard, I highly recommend you do not to try this change, you could lose data ...
Henk
- Domoticz version: 2020.2
About Icon missing, but very nice icons!
HoLeeShiet
- Target OS: -
vwebdevelopment
i am unable to oprn the link url http://dl.free.fr/vI9q5mZFw
can you please help me because i want to use this functionality in my future project.
- gevaudan
I re upload the file soon
- gevaudan
Link updated for 1.102 : http://dl.free.fr/vcvwOZF3s
energie
- Domoticz version: latest
Is there also an icon available for Lux? Currently it seems this is missing from the v1.102 set.
karl8754
- Domoticz version: stable
This is what I'm using for lux sensor at the moment: Just copy those two files in the icons/iconpack folder and overwrite the old onesenergie wrote:Is there also an icon available for Lux? Currently it seems this is missing from the v1.102 set.
- lux.png (1.65 KiB) Viewed 10437 times
EBOOZ
- Domoticz version: V3.8153
I've created a flat icon for the christmas tree since the original package didn't contain one
Source: http://www.iconarchive.com/show/free-ch ... -icon.html
- ChristmasTree.zip
- (13.34 KiB) Downloaded 261 times
- sincze
- Domoticz version: 2024.4
Just forgot to mention: I had to modify the icons.txt to correctly import the tree
So I had to remove the space, otherwise Domoticz did not want to import this nice icon
ChristmasTree;ChristmasTree;ChristmasTreeSo I had to remove the space, otherwise Domoticz did not want to import this nice icon
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- gevaudan
Hello Everybody !
New Update 1.103 available at http://dl.free.fr/bpp2FOV7f
credenty
thank you very much!
dressie
- Domoticz version: V2020.2
Looks good! Thank you for all your work!
landaisbenj
Thanks so much ;D
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
blauwebuis
- Domoticz version: current
Good news: the very latest beta version of Domoticz will not look for images in the theme folder first. This means that themes can come with their own icons built-in.
Would it be ok to use your icons in the Feynman theme?
- gevaudan
no problem ! you can use the iconset !
landaisbenj
blauwebuis wrote: Friday 11 August 2017 13:10 Good news: the very latest beta version of Domoticz will not look for images in the theme folder first. This means that themes can come with their own icons built-in.
Yeaahh nice. I've already do this for my own. It's roll really good.
Platforme: Rpbi3b
