Blockly examples
- BartdaMan
Re: Blockly examples
Bacinatorz,
You can solve this by adding a variable that changes state when the script runs. This way the script only triggers your Ledstrip once.
Here's an example:
https://postimg.org/image/k0dead18r/
Here's an example:
bacinatorz
Thnx for your clear screenshot, I have done this and now it works!BartdaMan wrote:Bacinatorz,
Here's an example:
- mAiden88
- Domoticz version: 3.7286
Here my example..
But it dont works got a error..
Anyone can build a fast processor. The trick is to build a fast system.
Derik
- Domoticz version: BETA
Dear All..
Is there someone that the OTG integrated in Blockley..
I do have a simple test, that is not working..: Do i something wrong.?
Or is OTG not integrated in Blockley..?
delfisastre
- Domoticz version: 2020.1
I don't know why is not working.
I have a motion sensor in the room, and I want to swicht off the light if the sensor detects no mottion. But the problem is, If I'm wathcing the TV, sometimes, the lights turn off, because the sensor don't detects motion. And put in a blockly. If detects no motion, but the TV is ON. Don't turn off the lights. But! the TV only is OFF is it's completly stops. (no with stantd by) and I put in the blockly if the electrical consumption to the TV is less than 20w ant no detects motion. Turn off the lights... But is not working.
Presencia Menjador = Motion Sensor
Tv = TV
Consum Actual TV = actual electrical consumption TV
Mnejador1 = Light 1
Menjador 2= Light 2
Derik
looks the actual i not working?
Strange perhaps some that make the blockley can fix this..[ gizmocuz not i believe ]
delfisastre
I don't know why.... but now it's working!!! maybe is the cache of the browser... I don't know. But works perfectly. Thanks for your help!
ztocken
I could use some help with my blockly event.
my devices:
rörelsesensor framsidan = motion sensor outside front of house
Entre = porch lamp
hallen = lamp hallway inside of house.
what i want to do:
if its dark outside i want the porch lamp (Entre) and the hallway lamp (hallen) to turn on for 5 minutes if there is movement outside.
But only if the porch lamp is not already on.
what happends is i get this error:
2016-11-07 21:51:29.319 Error: EventSystem: Lua script error (Blockly), Name: auto lampa framsida_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: ')' expected near 'comparevariable'
Anyone have a suggestion?
my devices:
Entre = porch lamp
what i want to do:
geezerrr
[Sunset = on] isn't a correct statement.ztocken wrote:I could use some help with my blockly event.
my devices:
Entre = porch lamp
what i want to do:
Maybe you can change it in [time >= sunset]
- StanHD
Also that's the wrong block for minutes. Try using the number block not a time block.
Python:- Broadlink RM2, Sonos
bjacobse
Ztocken,
This blockly is working with sunset and minutes, use as guide/inspiration
bonterra
I hope someone can help me. I've got a door sensor and a Qubino relay module installed to control a lamp inside my front door. The same light is also connected to a traditional switch for manual control. Door switch is "ON" when the door is open and "OFF" when the door is closed.
I would like to have two separate events, entry and exit. If the lamp is off and the door opens, turn it on for five minutes (entry). If the lamp is on and the door opens, turn it off after two minutes (exit). Both events are very simple but I just can't get them to work together.
I guess I need a dummy switch to separate these two events somehow?
- emme
- Domoticz version: latest
a LUA Device Script could help, but you have to use a variable:
Variable named: DOOROPERATION - string(1)
1 = ENTRY
2 = EXIT
0 = INOP
this should works...
Be aware that the uservariable determinates IF an operation is on going on the door... this means that for 2 minutes no action will be taken
There is not a real reason to set the variable to 1 or 2... since it tests only if it is 0 to run (but.. maybe just for debug information)
ciao
M
1 = ENTRY
2 = EXIT
0 = INOP
commandArray {}
if devicechanged['DoorSwitchName'] or devicechanged['extLampName'] then
if otherdevices['extLampName'] == 'Off' and otherdevices['DoorSwitchName'] == 'Off' and uservariables['DOOROPERATION'] = '0' then -- ENTRY
commandarray['variable:DOOROPERATION'] = '1'
commandArray['extLampName'] = 'On FOR 5'
elseif otherdevices['extLampName'] == 'On' and otherdevices['DoorSwitchName'] == 'Off' and uservariables['DOOROPERATION'] = '0' then -- EXIT
commandarray['variable:DOOROPERATION'] = '2'
commandArray['extLampName'] = 'Off AFTER 2'
commandarray['variable:DOOROPERATION'] = '0 AFTER 2'
ciao
M
"We always done this way"
four2six
I'd try virtual switches, one called 'entry', one 'exit'.
which leads to:
if 'entry' = 'off' and exit 'off' and 'door' = 'on' and 'lamp' = 'on'
set 'exit' = 'on' for 2 minutes
if 'entry' = 'off' and exit 'off' and 'door' = 'on' and 'lamp' = 'off'
set 'entry' = 'on' for 5 minutes
if 'entry' = 'on' or 'exit = 'on'
set 'lamp' = 'on'
if 'entry' = 'off' and 'exit = 'off'
set 'lamp' = 'off'
which leads to:
set 'lamp' = 'on'
set 'lamp' = 'off'
sailmich
@bonterra I tried with success what you want to do. See attachment.
Problem with that is if you changed your mind, for example you have forgotten something inside and you are open the door inside the 120 seconds, you will start the 5 minutes. At least in my opinion you need a PIR sensor inside your room to make the system running perfect.
regards
regards
- Bildschirmfoto vom 2016-11-14 16-19-41.png (23.4 KiB) Viewed 4091 times
four2six
not with my solutionsailmich wrote:Problem with that is if you changed your mind, for example you have forgotten something inside and you are open the door inside the 120 seconds, you will start the 5 minutes.
bonterra
Thanks, I might go for something like this.four2six wrote:I'd try virtual switches, one called 'entry', one 'exit'.
which leads to:
set 'lamp' = 'on'
set 'lamp' = 'off'
A PIR would be ideal, then it wouldn't matter if the door was opened twice during the active minutes. I'll have a look and see what I can find.sailmich wrote:@bonterra I tried with success what you want to do. See attachment.
regards
Thanks for your help, both of you!
Now I just have to figure out why I can't control the second channel of the Qubino (porch light) from the wall switch, it's wired just like the first channel (indoor light)...
sailmich
@four2six, virtual switches are fantastic. I tried as you wrote in one block but it doesn't work. With three it works.
I should more often create virtual switches
regards
regards
Could these virtual switches not be converted to variables? I find it confusing with all these virtual switches and if they are only used to hold on/off state it seems to be overkill.
Mvh Henrik
Mvh Henrik
sailmich
@HBrandt , could you please convert my blockly into one with variables. So I could see how it looks.
Thx
Thx
