How to get status of a group
- Domoticz version: 4.11083
Hi there all,
I am making a LUA-script to switch groups.
Now a group cAn have 3 states, on/off/mixed
how can I determine what stae the group is in in LUA?
I tried otherdevices_svalues but this gives an error, this is a table variable
Any help?
Thnx in advance
Jan
Any help?
Thnx in advance
Jan
- jvdz
- Domoticz version: 4.107
Re: How to get status of a group
From the Event Wiki page: https://www.domoticz.com/wiki/Events
JosTo switch a scene or group, put prefix 'Scene:' or 'Group:' in front of the scene name. Note that it is not possible to check the state of a scene or group, since that is not its intended use. Check a (significant) single device from the scene/group table before switching scenes.
Is there any plan to develop the ability to know the state of a group?
Try this and let me know how it works
function libs.GroupState(sArray)
-- v1.0. 2016-01-18
-- Checks the state of a group of swithces.
-- USAGE : GroupState({'Switch1','Switch2','Switch3','Switch4','Switch5',more switches})
-- RETURNS : 'On' if all switches are on.
-- : 'Off' if all switches are off.
-- : 'Mixed" if one or more, but not all switches are on.
local iState = 0
local iCount = 0
local sState = ''
for i,light in pairs(sArray) do
if (otherdevices[light] == 'On') then
iState = iState + 1
iCount = iCount + 1
if(iState == 0) then sState = "Off" end
if(iState > 0) then sState = 'Mixed' end
if(iState == iCount) then sState = 'On' end
-- print("iCount : " .. iCount)
-- print("iState : " .. iState)
-- print("sState : " .. sState)
return sState
Gert
Gert
Coool, it does work!
Thanks Gert!!!
Thanks Gert!!!
It changes state only when I open the floorplan. Is there a way to changes every x seconds?
I don't get you?Andrex wrote:It changes state only when I open the floorplan. Is there a way to changes every x seconds?
It just checks the state of a group of devices.
I use it as below:
if (devicechanged['Rörelse'] == 'On' and libs.GroupState(aLivingroom) == 'Off') then
If the return value is "On" or "Mixed" nothing will happen.
Gert
Gert
In the log I've got this error every minute:
Error: EventSystem: in Update groups state: [string "function libs.GroupState(sArray)..."]:1: attempt to index global 'libs' (a nil value)
Hmm. Remove the libs.
Make it look like this :
function GroupState(sArray)
I have my functions scripts in a singel libs file.
Gert
Gert
Now I get
But when does it run? Who tells it when to run?Error: EventSystem: Lua script Update groups did not return a commandArray
What I was saying previously is that in the floorplan the state of the group is updated only when i refresh the page (the single switches updates instantly).
- Domoticz version: BETA
what type of script is it?
lua with crontab?
lua with time?
Or ??
lua with crontab?
lua with time?
Or ??
It is not a script its a function:
Below is a part of my script script_device_motion.lua
The function checks if a group if switches is on, off or mixed.
GroupState(sArray)
-- v1.0. 2016-01-18
local iState = 0
local iCount = 0
local sState = ''
iState = iState + 1
iCount = iCount + 1
return sState
aLivingroom = {'Hörnbord','Soffbord','Blomma','Fönster','Bokhylla'}
if (devicechanged['Rörelse'] == 'On') then
time = os.date("*t")
if (GroupState(aLivingroom) == 'Off') then
if (libs.SunSet() < 30 and time.hour <= 22) then
commandArray['Group:Alla Vardagsrum']='On'
difference = libs.TimeDifference('Rörelse')
myTime = libs.SecondsToClock(tostring(difference))
tSunset = libs.SecondsToClock(tostring(libs.SunSet()))
commandArray[1] = {['UpdateDevice'] = '10|0|'..'Senaste rörelsen    : '..myTime..'<br>Tid till Solnedgång : '..tSunset}
commandArray[2] = {['UpdateDevice'] = '42' .. '|0|' .. tostring(libs.UpdateCounter('Movement Vardagsrum'))}
commandArray[3] = {['UpdateDevice'] = '43' .. '|0|' .. tostring(libs.UpdateCounter('Movement Vardagsrum1'))}
Gert
Gert
Hi Gert,
Thanks for the script function. Unfortunately I get some errors using it.
The log error is:
Error: EventSystem: in script_device_motion.lua: [string "-- script_device_motion.lua ..."]:3: attempt to index global 'libs' (a nil value)
Please see the complete script below:
-- v1.0. 2016-01-18
local iState = 0
local iCount = 0
local sState = ''
iState = iState + 1
iCount = iCount + 1
return sState
aLivingroom = {'hue_eettafel','hue_woonkamer_1','hue_keuken_1','hue_keuken_2'}
local motion_switch = 'WoonkamerPIR'
local time_switch = 'schema2'
if devicechanged[motion_switch] then
if otherdevices[motion_switch] == 'On' and (GroupState(aLivingroom) == 'Off') and otherdevices[time_switch] == 'On' then
commandArray['Group:Woonkamer']='On'
-- v1.0. 2016-01-18
local iState = 0
local iCount = 0
local sState = ''
iState = iState + 1
iCount = iCount + 1
return sState
Regards,
Jesse
- waaren
I did something similar in dzVents. Hope this will help. Please note that checkFirst() is available in dzVents 2.3.0 onwards which is part of domoticz Beta
-- CheckFirst() available in dzVents 2.3.0
-- active = false,
on = { devices = { "WoonkamerPIR" } },
execute = function( domoticz,motionDetector )
local timeSwitchState = domoticz.devices("schema2").state
local myGroup = domoticz.groups("Woonkamer")
if motionDetector.state == "On" and timeSwitchState == "On" then
myGroup.switchOn().checkFirst()
Thanks a lot for taking the time to help me! I need to update to beta but I can't do this (running Pi2b) because get errors when I want to update.waaren wrote: ↑Wednesday 24 January 2018 15:10 I did something similar in dzVents. Hope this will help. Please note that checkFirst() is available in dzVents 2.3.0 onwards which is part of domoticz Beta
-- CheckFirst() available in dzVents 2.3.0 return { -- active = false, on = { devices = { "WoonkamerPIR" } }, execute = function( domoticz,motionDetector ) local timeSwitchState = domoticz.devices("schema2").state local myGroup = domoticz.groups("Woonkamer") if motionDetector.state == "On" and timeSwitchState == "On" then myGroup.switchOn().checkFirst() end end }
I am going to fix the update first, then try the script and let you know!
Regards,
Jesse
Regards,
Jesse
So it took me some time to fix the upgrade. Now i am running dzvents 2.4.1 (this should support checkfirst).
The script is not working, I see no errors in the log but nothings happens when the motionsensor is activated (and the scheme is on)?
Should I choose a dzvents device script as type? Because i tried with dzvents device and dzvents group?
Regards,
Jesse
- waaren
<Edit> I don't use the internal script editor so I did not understood your question after first reading.
Script is a Device type and make sure you set the event to active before saving.
<end Edit>
I tested the script (with different names for sensor and group ) in 2.4.0 and it did what I expected.
If you have the Log Level for dzVents (setup, settings, other) set to "Errors + minimal execution level" you should see if the script is executed when the sensor is activated.
To see how the script run you could add some print commands and check the log when you activate the sensor. Like below
<end Edit>
on = { devices = { "WoonkamerPIR" } }, -- case sensitive must be the exact name of you sensor
print ("function started")
print ("schema2 and WoonkamerPIR both On"
print ("schema2 and / or WoonkamerPIR Off"
I tried it for a few days.
When the sensor detects motion, i see the following in the log:
2018-02-04 20:37:00.799 EventSystem: Script event triggered: slaapkamerjm_uit
2018-02-04 20:37:00.802 EventSystem: Script event triggered: woonkamer_uit
2018-02-04 20:37:39.593 dzVents: Info: ------ Start internal script: slaapkamerjm_aan: Device: "PIRslaapkamerJM (zwave_aeon)", Index: 68
2018-02-04 20:37:39.598 dzVents: Info: ------ Finished slaapkamerjm_aan
But the light does not switch on.
Can it be that the script I use to turn the lights off causes an error or something?
-- script_time_nomotion.lua
local motion_switch = 'PIRslaapkamerJM'
local nomotion_uservar = 'slaapkamerjm'
local status_switch = 'Slaapkamer JM lamp'
no_motion_minutes = tonumber(uservariables[nomotion_uservar])
if (otherdevices[motion_switch] == 'Off') then
no_motion_minutes = no_motion_minutes + 1
--print('<font color="red">No motion has been detected for: ' ..no_motion_minutes.. ' minutes</font>')
no_motion_minutes = 0
commandArray['Variable:' .. nomotion_uservar] = tostring(no_motion_minutes)
if no_motion_minutes > 15 then --change the 30 to the amount of minutes you prefer
commandArray[status_switch]='Off'
