Toggle device?
theolsen
Toggle device?
Post by theolsen »
I'm pulling out my remaining hair with what I think should be a simple problem to solve.
I am using presence detection on my phone from a script running on my Asus router.
The script updates one of two virtual devices on either 2.4 or 5.0 Ghz network so that I can tell that my phone is in the house and which network it is connected to.
That works fine.
I have a further dummy device that is updated if either of the 2.4 or 5.0 dummies are on.
The problem is I want the dummy device to only turn on if it was previously off, for example right now if my phone switches from 2.4 to 5.0 the dummy device will be switched on again even though I am already home - I want this to only happen if it is already off...otherwise do not update.
I hope I have explained well.
Thanks in advance.
Egregius
Domoticz version: v2024.7
Re: Toggle device?
Post by Egregius »
Use the current state of the switch in a if block of your script.
theolsen
Re: Toggle device?
Post by theolsen »
Thanks Egregius, I was hoping to cheat it in Blockly but you are right..lua is the answer!
Egregius
Re: Toggle device?
Post by Egregius »
Or any other language... ;)
bloody2k
Re: Toggle device?
Post by bloody2k »
Would it be possible for you to share the script you use at your router?
pj-r
Domoticz version: V3.8650
Re: Toggle device?
Post by pj-r »
theolsen wrote:The problem is I want the dummy device to only turn on if it was previously off, for example right now if my phone switches from 2.4 to 5.0 the dummy device will be switched on again even though I am already home - I want this to only happen if it is already off...otherwise do not update.
Whats the problem with blocky?
if dummy <> on and (dummy24 = on OR dummy5 = on) then
set dummy = on
else if dummy = on and dummy24 <> on AND dummy5 <> on
set dummy = off
end if
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
theolsen
Re: Toggle device?
Post by theolsen »
bloody2k wrote:Hi
Of course, I cobbled it together from http://forum.micasaverde.com/index.php?topic=24084.0
I am sure it is far from efficient but it works for me and doesn't miss a beat.
#!/bin/sh
WATCHDOG_SLEEP_SEC=10
MAC_ADDRESS_1=“nn:nn:nn:nn:nn:nn” # Ken
c1_last_state="0"
c3_last_state="0"
MAC_ADDRESS_2=“nn:nn:nn:nn:nn:nn” # Barbie
c2_last_state="0"
c4_last_state="0"
VERAURL1="http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=26&switchcmd="
VERAURL2="http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=27&switchcmd="
VERAURL3="http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=29&switchcmd="
VERAURL4="http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=28&switchcmd="
x=0
y=0
offcount1=0
offcount2=0
offcount3=0
offcount4=0
while sleep $WATCHDOG_SLEEP_SEC
do
        if [ "$x" == 180 ]; then
                x=0
                c1_last_state="0"
                c2_last_state="0"
                c3_last_state="0"
                c4_last_state="0"
        fi
        x=$(( $x + 1 ))
        c1_new_state=`wl -i eth2 assoclist | grep $MAC_ADDRESS_1`
        if [ "$c1_new_state" == "$c1_last_state" ] ; then
                sleep 0
                if [ "$c1_new_state" == "assoclist $MAC_ADDRESS_1" ]; then
                        c1_last_state="$c1_new_state"
                         wget -qs "http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=27&switchcmd=On"
                        offcount1=0
                        offcount1=$(( $offcount1 + 1 ))
                fi
        fi
        c2_new_state=`wl -i eth2 assoclist | grep $MAC_ADDRESS_2`
        if [ "$c2_new_state" == "$c2_last_state" ] ; then
              sleep 0
                if [ "$c2_new_state" == "assoclist $MAC_ADDRESS_2" ]; then
                        c2_last_state="$c2_new_state"
                        wget -qs "http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=26&switchcmd=On"
                        offcount2=0
                        offcount2=$(( $offcount2 + 1 ))
                fi
        fi
        c3_new_state=`wl -i eth1 assoclist | grep $MAC_ADDRESS_1`
        if [ "$c3_new_state" == "$c3_last_state" ] ; then
                sleep 0
                if [ "$c3_new_state" == "assoclist $MAC_ADDRESS_1" ]; then
                        c3_last_state="$c3_new_state"
                        wget -qs "http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=28&switchcmd=On"
                        offcount3=0
                        offcount3=$(( $offcount3 + 1 ))
                fi
        fi
        c4_new_state=`wl -i eth1 assoclist | grep $MAC_ADDRESS_2`
        if [ "$c4_new_state" == "$c4_last_state" ] ; then
                sleep 0
                if [ "$c4_new_state" == "assoclist $MAC_ADDRESS_2" ]; then
                        c4_last_state="$c4_new_state"
                        wget -qs "http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=29&switchcmd=On"
                        offcount4=0
                        offcount4=$(( $offcount4 + 1 ))
                fi
        fi
        if [ $offcount1 -lt 6 ]; then
                # give not responding devices 1 minute to respond
                sleep 0
                wget -qs "http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=27&switchcmd=Off"
                                offcount1=0
        fi
        if [ $offcount2 -lt 6 ]; then
                sleep 0
                wget -qs "http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=26&switchcmd=Off"
                offcount2=0
        fi
          if [ $offcount3 -lt 6 ]; then
                sleep 0
                wget -qs "http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=28&switchcmd=Off"
                offcount3=0
        fi
          if [ $offcount4 -lt 6 ]; then
                sleep 0
                wget -qs "http://192.168.1.65:8080/json.htm?type=command&param=switchlight&idx=29&switchcmd=Off"
                offcount4=0
        fi
done
Last edited by theolsen on Thursday 03 November 2016 18:13, edited 1 time in total.
theolsen
Re: Toggle device?
Post by theolsen »
set dummy = on
set dummy = off
end if
Good call, I really don't know why I wasn't thinking like that :)
