Shutdown domoticz pi
Egregius
Domoticz version: v2024.7
Re: Shutdown domoticz pi
Post by Egregius »
That's one you'll never forget ;)
So, if I understand correctly the &param replacement is just in the logfile as it opens the url?
DaWauZ
Post by DaWauZ »
Well my log is getting cleared after a reboot so I cant see it though.
I can see its rebooted in the log but I'm not seeing the command giving as its been gone after reboot.
Is there somehow a cli command to view it maybe? I can do that tonight when I'm home.
Raspberry Pi 2 model B with domoticz
OMV NAS installed on thin client HP T610
Openelec Kodi Mediaplayer on thin client HP T520 (and with multiboot windows 10)
Egregius
Post by Egregius »
I didn't know the logfile got cleared on a Pi. I know that happens on Synology. Is your logfile located at a tempfs storage?
If you really want to keep the logfile you could alter the /etc/init.d/domoticz script so it creates a copy of the logfile somewhere.
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
I would like to link up with this thread.
I use a 2nd pi as a media player (Squeeze Lite). Domoticz is also installed on it (Testing). I use this 2nd RPI not very much.
My Domoticz also runs on a Raspberry Pi. In Domoticz (1st RPI) I created a virtual switch (off action: http://192.168.0.7:8080/json.htm?type=c ... m_shutdown) to shut down the RPI with the media player. This worked well for a long time. Today I found out that it was not working anymore. The 2nd Pi does not shut down anymore.
When I use http://192.168.0.7:8080/json.htm?type=c ... m_shutdown" via my browser I get
"status" : "OK",
"title" : "SystemShutdown"
The Pi actually shuts down. I do not know where it goes wrong.
Searching for a solution, I created a new virtual switch. NO SUCCES.
I'm hoping for some help in solving the problem.
Thanks in advance
Jan
jannl
Domoticz version: 2022.2
Post by jannl »
Ehm. First you say no shutdown then you say the pi actually shuta down....
When I had the problem the pi did not shut down on the shutdown command, I had a corrupted sd card.
Jan Jansen
When using a virtual switch (Pi one) >> mediaplayer (Pi two) do not shut down.
When using "http://192.168.0.7:8080/json.htm?type=c ... m_shutdown" via browser >> mediaplayer shuts down as expected.
I don't think its the SD card.
