New IHC Plugin, Dimmer question
jbjalling
I'm currently writing a new hardware plugin for the LK/Schneiders IHC system. Everything seems to work fine now, and I'm refining the last bits and pieces.
I have a question though.
What is the expected behavior of a dimmer switch when the "Turn On" button is clicked? Is it supposed to turn on, on full brightness? Or is it supposed to turn on, to the level it had when it was turned off?
Thanks,
BR Jonas
Thanks,
BR Jonas
Clemen
Re: New IHC Plugin, Dimmer question
Its turning on with the current level of the slider.
Nice with IHC, pm me if you want a tester.
jbjalling
Sure, I'll get back to you when I return from my vacation.
BR Jonas
BR Jonas
SoerenBM
- Domoticz version: 3.5169
Hi Jonas,
I'm very excited to read about your IHC plugin. I'm also ready if you need more testing.
It would be nice when you turn the dimmer on by using the lights icon, left of the slider, it turns on at a predefined procentage/level. Or even better have a option to select between predefined level or last used level.
Br Søren
Br Søren
jbjalling
Hi Søren,
thats great! I just got back from vacation, so I need to get up to speed on different things, but will continue the development soon. Can you give some details on your IHC setup (maybe in a private message)? What kind of devices do you have? I, personally, only have wireless modules, so it would be great to test the plugin on wired devices as well.
BR Jonas
BR Jonas
SoerenBM
Hi Jonas,
Sounds good.
Most of my IHC are wired. Inputs, Outputs, Controller. For dimmers I do use Wireless modules.
Currently I'm using openHAB and IHC Captainto keep Domiticz updated. IHC Captain to get the state of the IHC devices into Domoticz. OpenHAB so I can manipulate the state of the IHC devices from within Domoticz using dummy hardware and devices.
BR Søren
Sent using Tapatalk
Sounds good.
BR Søren
Sent using Tapatalk
I would also like to test your plugin for IHC. I am only using wireless products.
For my installation i have configured the IHC controller to a specific level, e.g. 40%, when a dimmer is turned on from an IHC device. But i also use the IHC Remote app were i turn on the light by moving the slider to the desired level.
Br Nikki
Br Nikki
Johans
Are you planning to use IHC controller? I think connect it to a "arduino controller" would be pretty simple using ArduinoIHC library http://dingus.dk/arduinoihc/ and connect it to usb-port.
jbjalling
no I don't want to put ekstra software in the IHC controller, so the only way is to use the SOAP interface.
I'm currently rewriting the plugin because of some licensing issues.
BR JOnas
BR JOnas
raverlution
Hi Jonas
I am also ready to test:)
Whats the status?
Br Kenn
Whats the status?
Br Kenn
Hijbjalling wrote: Sunday 19 June 2016 0:39 Hi all,
Thanks,
BR Jonas
what is the status for the IHC plugin?
jbjalling
Hello Janne,
it sort of works. Some people from the danish IHC forum are currently testing the plugin.
BR Jonas
BR Jonas
