RFXCom not working on synology DS214Play
RonB
Post by RonB »
I get an error when I connect the RFXCom transceiver on my NAS DS214Play
RFXCOM: Using serial port: /dev/ttyUSB0
Error: Serial port closed!... Error: End of file
My NAS is the 214play with the RFXCOM transceiver on /dev/ttyUSB0. The error occurs with both, the stable and the beta release. The stable release crashes the webserver. The last Beta release ignores the error but Domoticz logs the error every 30 seconds. I've tried the 1005, 1006a but also the 250 and the 251 firmware versions. All with the same result.
Any Ideas on how to solve this?
Thanx, Ronald
gingercat
Re: RFXCom not working on synology DS214Play
Post by gingercat »
I had similar until I rebooted my DS215j with the device attached (read that somewhere else on here, don't have the link to give credit I'm afraid)
gizmocuz
Post by gizmocuz »
another tip, if you open a ssh terminal, issue
dmesg
now plugin the transceiver
type again
dmesg
you should see it is inserted and which usb port it is assigned to
