15326 - [WebServer] Depricated RType Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Re: 15326 - [WebServer] Depricated RType
I see! Thanks,
So i need wait App update?
Or is there anything I can do?
- Domoticz version: 2024.7
You need an update for the app if you have issues with events as those are not backwards compatible. The rest of the messages you have are deprecation warnings, not errors, and will keep working.
- Domoticz version: 2023-2
I am getting messages 'Deprecated RType (devices) for API request....' every 5s with Domoticz 2023.2
In my attempts to isolate the culprit I removed all my LUA scripts and as well as the Domoticz-Zigbee plugin directory. I also checked there is no shell scripts running.
With the WEBSERVER debug option set I can see calls to the JSON API using the old syntax (/json.htm?type=devices..) every 5 seconds, see lines with 'CWebServer::GetJSonPage(rtype) :devices :/json.htm?type=devices' below.
But unfortunatly this does not point me to the issuer of the bad JSON calls and, given my pretty basic Domoticz setup, I wonder if these commands might be scheduled internally by at tasks in Domoticz on a 5s basis.
Is there such tasks fired every 5s in Domoticz ?
Are there other debug options I could use to dig further more.
Below the log extract. In there the calls with format json.htm?type=devices are done for device id 50 but the same calls are done for the other devices in the configuration as well.
2023-07-28 23:19:49.719 Debug: [web:443] 'DH PARAMETERS' found in file ./server_cert.pem
2023-07-28 23:19:49.719 Status: WebServer(SSL) started on address: :: with port 443
2023-07-28 23:19:49.720 Debug: [web:443] Adding IPv4 network (192.168.1.*) to list of trusted networks.
2023-07-28 23:19:49.720 Debug: [web:443] Adding IPv4 network (127.0.0.1) to list of trusted networks.
2023-07-28 23:19:49.721 Debug: WebServer(SSL) started with 260 Registered Commands
2023-07-28 23:19:49.721 Debug: cWebEm Registration: 23 pages, 10 actions, 4 whitelist urls, 12 whitelist commands
2023-07-28 23:19:49.722 Starting shared server on: :::6144
2023-07-28 23:19:49.722 Status: TCPServer: shared server started...
2023-07-28 23:19:49.722 Status: RxQueue: queue worker started...
2023-07-28 23:19:51.723 Status: NotificationSystem: thread started...
2023-07-28 23:19:51.723 Status: EventSystem: reset all events...
2023-07-28 23:19:51.724 Status: EventSystem: reset all device statuses...
2023-07-28 23:19:51.751 Status: Python EventSystem: Initializing event module.
2023-07-28 23:19:51.751 Status: EventSystem: Started
2023-07-28 23:19:51.751 Status: EventSystem: Queue thread started...
2023-07-28 23:19:52.724 Status: MQTT: Connecting to 127.0.0.1:1883
2023-07-28 23:19:52.807 Debug: [web:8080] Host:192.168.1.11 Uri:/json.htm?type=devices&rid=50
2023-07-28 23:19:52.807 Debug: [web:8080] IP (192.168.1.11) is within Trusted network range!
2023-07-28 23:19:52.807 Debug: CWebServer::GetJSonPage(rtype) :devices :/json.htm?type=devices&rid=50
2023-07-28 23:19:52.807 [WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.1.11)
2023-07-28 23:19:52.808 Status: [web:8080] Incoming connection from: 192.168.1.11
2023-07-28 23:19:52.808 Debug: [web:8080] generate new session id token f5232d8a700555590be921f0e2ed5af0
2023-07-28 23:19:52.808 Debug: [web:8080] generate new authentication token MGRlMzYxNTQtYzJkOS00ODU3LWJlZWUtMTc0YWFlMzU3MDU2 for user Domoticz
2023-07-28 23:19:52.809 Debug: Web ACLF: 192.168.1.11 - - [28/Jul/2023:23:19:52.807 +0200] "GET /json.htm?type=devices&rid=50 HTTP/1.1" 200 1782 - -
2023-07-28 23:19:52.925 Status: MQTT: connected to: 127.0.0.1:1883
2023-07-28 23:19:57.808 Debug: [web:8080] Host:192.168.1.11 Uri:/json.htm?type=devices&rid=50
2023-07-28 23:19:57.808 Debug: [web:8080] IP (192.168.1.11) is within Trusted network range!
2023-07-28 23:19:57.808 Debug: CWebServer::GetJSonPage(rtype) :devices :/json.htm?type=devices&rid=50
2023-07-28 23:19:57.808 [WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.1.11)
2023-07-28 23:19:57.809 Debug: Web ACLF: 192.168.1.11 - - [28/Jul/2023:23:19:57.808 +0200] "GET /json.htm?type=devices&rid=50 HTTP/1.1" 200 1782 - -
2023-07-28 23:20:00.990 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:00.991 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:00.991 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:00.992 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:00.990 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.011 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.012 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.012 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.013 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.011 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.042 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=udevice&idx=87&nvalue=0&svalue=178;S;6.925;11.08;20;0
2023-07-28 23:20:01.042 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.043 Debug: CWebServer::GetJSonPage :udevice :/json.htm?type=command¶m=udevice&idx=87&nvalue=0&svalue=178;S;6.925;11.08;20;0
2023-07-28 23:20:01.044 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.042 +0200] "GET /json.htm?type=command¶m=udevice&idx=87&nvalue=0&svalue=178;S;6.925;11.08;20;0 HTTP/1.1" 200 49 - "curl/7.81.0"
2023-07-28 23:20:01.045 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.045 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.045 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.047 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.045 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.071 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=udevice&idx=88&nvalue=0&svalue=2.5
2023-07-28 23:20:01.071 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.071 Debug: CWebServer::GetJSonPage :udevice :/json.htm?type=command¶m=udevice&idx=88&nvalue=0&svalue=2.5
2023-07-28 23:20:01.072 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.070 +0200] "GET /json.htm?type=command¶m=udevice&idx=88&nvalue=0&svalue=2.5 HTTP/1.1" 200 49 - "curl/7.81.0"
2023-07-28 23:20:01.072 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.072 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.073 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.074 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.072 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.092 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=getdevices&rid=85
2023-07-28 23:20:01.092 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.092 Debug: CWebServer::GetJSonPage :getdevices :/json.htm?type=command¶m=getdevices&rid=85
2023-07-28 23:20:01.093 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.092 +0200] "GET /json.htm?type=command¶m=getdevices&rid=85 HTTP/1.1" 200 1316 - "curl/7.81.0"
2023-07-28 23:20:01.107 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_Automation_Volets_V1.3.lua: ...oticz/scripts/lua/script_time_Automation_Volets_V1.3.lua:517: attempt to index a nil value (global 'otherdevices_temperature')
2023-07-28 23:20:01.125 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.125 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.125 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.126 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.125 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.147 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=getdevices&rid=59
2023-07-28 23:20:01.147 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.147 Debug: CWebServer::GetJSonPage :getdevices :/json.htm?type=command¶m=getdevices&rid=59
2023-07-28 23:20:01.148 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.147 +0200] "GET /json.htm?type=command¶m=getdevices&rid=59 HTTP/1.1" 200 1626 - "curl/7.81.0"
2023-07-28 23:20:01.169 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.169 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.170 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.171 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.169 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.190 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=getdevices&rid=59
2023-07-28 23:20:01.190 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.190 Debug: CWebServer::GetJSonPage :getdevices :/json.htm?type=command¶m=getdevices&rid=59
2023-07-28 23:20:01.191 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.190 +0200] "GET /json.htm?type=command¶m=getdevices&rid=59 HTTP/1.1" 200 1626 - "curl/7.81.0"
2023-07-28 23:20:02.811 Debug: [web:8080] Host:192.168.1.11 Uri:/json.htm?type=devices&rid=50
2023-07-28 23:20:02.811 Debug: [web:8080] IP (192.168.1.11) is within Trusted network range!
2023-07-28 23:20:02.811 Debug: CWebServer::GetJSonPage(rtype) :devices :/json.htm?type=devices&rid=50
2023-07-28 23:20:02.811 [WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.1.11)
2023-07-28 23:20:02.812 Debug: Web ACLF: 192.168.1.11 - - [28/Jul/2023:23:20:02.811 +0200] "GET /json.htm?type=devices&rid=50 HTTP/1.1" 200 1782 - -
2023-07-28 23:20:07.812 Debug: [web:8080] Host:192.168.1.11 Uri:/json.htm?type=devices&rid=50
2023-07-28 23:20:07.812 Debug: [web:8080] IP (192.168.1.11) is within Trusted network range!
2023-07-28 23:20:07.812 Debug: CWebServer::GetJSonPage(rtype) :devices :/json.htm?type=devices&rid=50
2023-07-28 23:20:07.813 [WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.1.11)
2023-07-28 23:20:07.814 Debug: Web ACLF: 192.168.1.11 - - [28/Jul/2023:23:20:07.812 +0200] "GET /json.htm?type=devices&rid=50 HTTP/1.1" 200 1782 - -
- kiddigital
@bl34 , likely your browser has some cached parts left from the UI which still uses the old code and calls.
Clear cache (appcache/serviceworker).
You can use the Browser developer tools (F12) and on the network-tab enable ‘no-cache’ and reload the UI. That forces everything to get reloaded and refreshed.
I fact I had unplugged the eth connection to the server to make sure no browser would access Domoticz and I looked at the log with a tail command in a local terminal. This was to make sure no external connection would pass requests with the old command format. But no changes, and I was still getting the error messages.
After few more thoughts I realized that Homebridge was still active possibly would issue commands to Domoticz at a steady pace when idle. So I stopped the Homebridge server and ..bingo, no more error reported in the log !!
I guess I know now who to talk to
Nevertheless, and if at all possible, I think it would be very helpful to get an indication in the error message on the originator of the faulty request.
- kiddigital
Didn’t the IP address in the logline give that away?
Well not really. The IP in the error message, in my case the IP of the server itself did not tell me much about what piece of SW issued the bad request.
The IP of an external client (a remote web brower by instance) might have shown here if an old cached request was received. I did not see that but maybe.
By originator I meant the name of an app, the name of a script,etc.
At the moment I guess CWebServer::GetJSonPage has no clue on who invoked its service.
- kiddigital
Nope it doesn’t. Not really, maybe when running with debugflags enabled maybe some header like browserstring might give an indication.. but not something domoticz controls
Quick update on the problem with error messages in Domoticz log when Homebridge task runs.
The root cause was the homebridge-edomoticz plugin. File 'homebridge-edomoticz/lib/domoticz.js' has been updated to use the API calls with the correct syntax but no update was offered in the Homebridge GUI. I guess because the version was unchanged.
I fixed the problem by replacing file domoticz.js in /var/lib/homebridge/node_modules/homebridge-edomoticz on my system by the updated one found in the homebridge-edomoticz github repo.
Additionally I made the same change to the file index.js for the homebridge-domoticz-selector-switch plugin (no more maintained)
Hope this helps
Hope this helps
- Domoticz version: 2020.1
I am getting the same error
2023-08-01 18:12:46.248 [WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.1.107)
where the IP address is of a device running the website of dashticz. Any idea what this could be?
Solved with the latest Dashticz beta version.
Ah, then I'll just wait for the lastest beta to become table version
I got this same message:
[Webserver] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.x.xx)
I'm using another custom dashboard (not Dashticz)
The only possible API-request could be from Dutch "Buienradar" or ¨OpenWeatherMap"
Possibly i can be of help in solving the problem... although i'm not a script wizard.
So maybe someone can help me where to look and i could share the contents of the script.
With that info we might get any further in solving the problem.
Does someone also know where i can set the log level for the webserver?
I now get the above message every few seconds, i'm afraid my log is getting overloaded from that.
It will probably not come from Dutch "Buienradar" or ¨OpenWeatherMap"studiocascade wrote: ↑Tuesday 08 August 2023 21:28 I got this same message:
In the code of your own dashboard (why not mention/link it....?) search for "getdevices" and change the dashboard code so it uses the correct command
/json.htm?type=devices should be /json.htm?type=command¶m=getdevices
I which file should I change that in Dashticz? I went trough quite some files, but can't find the 'json.htm?type=devices'
- kiddigital
Latest Dashticz beta’s are updated to use the updated API structure and should not generate that message anymore.
and for openzwavenodes the change is:
old:
../json.htm?type=openzwavenodes&idx=[controller_idx]
new:
../json.htm?type=command¶m=getopenzwavenodes&idx=[controller_idx]
old:
new:
- Domoticz version: 2022.2
i have this curl command in my router
curl -s "http://192.168.1.50:8084/json.htm?type=devices&rid=$idx" | grep Status | awk '{print $3}' | sed 's/[",]//g'`
however when i change it to the new version it does not seem to work
curl -s "http://192.168.1.50:8084/json.htm?type= ... s&rid=$idx" | grep Status | awk '{print $3}' | sed 's/[",]//g'`
also the homebridge thermostat plugin from akamming does not work anymore
it also uses this api call but it seizes to work
in domoticz this call generated the depreciated warning but in the homebridge plugin screen this appears
invalid reponse code: 401, on http://192.168.1.50:8084/json.htm?type=devices&rid=378
it stopped working, it can not communicate with domoticz anymore
on 2023.1 15092 everything was working fine
also here is the question if the workaround change type=devices into type=command¶m=getdevices will work
i tested the new api call with the 2023.1 version and that creates an error
this means that everything who wants to talk to domoticz now needs multiple versions so that the calls/plugin work with both the old and the new version
so why al these api changes who aparently are not downwards compatible
i am ok with warning in domoticz so you have time to change/fix things but if things stop to work when they are trying to communicate with domoticz that is another thing
This has nothing to do with the Rtype api as devices is backwards compatible.
This seems an authorisation error. Check your trusted network setting and setting "Allow API basic authorisation on HTTP"
trusted network setting is ok. everything(homebridge,docker,domoticz) is running on the same host and ip address 192.168.1.50
all the containers use the same network setting
127.0.0.*;192.168.1.*
i even added 192.168.1.50:8581(this is the homebridge instance)
also switched on basic api authorisation but this did not help either.
it seems i am not the only one with this problem
https://github.com/akamming/homebridge- ... t/issues/1
for now i switched back to 2023.1
hopefully somebody will figur out what the problem is
