Something has changed in the past month
I'm planing to reinstall my domoticz, I have a spare RPI I can set it up on.
Don't know. Not sure how to test.
oh I read it again, it's just a normal zwave switch.
So for example Domoticz will only create the switch if it discovered the device (in MQTT default topic homeassistant) and ZwaveJSUI has sent the state (ON/OFF). To trigger the state change you perhaps have to switch it from the device itself.After adding/updating the MQTT Client Gateway for Zwave-JS-UI the Zwave devices will be automatically added in the Domoticz device list if discovered by Zwave-JS-UI, check menu Setup - Devices. Domoticz devices will be created once data is received. So especially for battery operated devices it can take some time to have this data received. Sometimes it is possible to activate these sensors manually by pushing a button.
But everything this has been working for months, that is the big thing. I have just updated domoticz. Ya I know I'm running beta and it can have smal things that don't work but that the whole MQTT client gateway just crashes randomly it's more alpha issue.waltervl wrote: ↑Tuesday 06 February 2024 13:54 I mean as stated in https://www.domoticz.com/wiki/Zwave-JS-UISo for example Domoticz will only create the switch if it discovered the device (in MQTT default topic homeassistant) and ZwaveJSUI has sent the state (ON/OFF). To trigger the state change you perhaps have to switch it from the device itself.After adding/updating the MQTT Client Gateway for Zwave-JS-UI the Zwave devices will be automatically added in the Domoticz device list if discovered by Zwave-JS-UI, check menu Setup - Devices. Domoticz devices will be created once data is received. So especially for battery operated devices it can take some time to have this data received. Sometimes it is possible to activate these sensors manually by pushing a button.
I noticed that they may have dropped support for older nodejs, trying to update it.
I tried to install everything new but kept getting roadblocks with every thing so I installed the MQTT and Zigbee2MQTT as docker on my old installation and now everything is working as it should
2024-02-23 00:00:01.910 Error: Z-Wave JS UI: Switch not found!? (zwavejs2mqtt_0xd845223d_10-37-0-currentValue/Kitchen - Window light)
2024-02-23 00:00:01.910 Error: Error sending switch command, DevID: 6, Time: 2024-02-23 00:00:01
2024-02-23 00:00:01.910 Error: Z-Wave JS UI: Switch not found!? (zwavejs2mqtt_0xd845223d_8-37-0-currentValue/Livingroom - Window Lights)
2024-02-23 00:00:01.910 Error: Error sending switch command, DevID: 3, Time: 2024-02-23 00:00:01
2024-02-23 00:00:01.910 Error: Z-Wave JS UI: Switch not found!? (zwavejs2mqtt_0xd845223d_7-37-0-currentValue/Office - Screen backlight)
2024-02-23 00:00:01.910 Error: Error sending switch command, DevID: 2, Time: 2024-02-23 00:00:01
2024-02-23 00:00:01.910 Error: Z-Wave JS UI: Switch not found!? (zwavejs2mqtt_0xd845223d_59-51-0-currentColor/Balcony - Light)
2024-02-23 00:00:01.910 Error: Error sending switch command, DevID: 830, Time: 2024-02-23 00:00:01
