mqtt auto discovery creates non existing devices Topic is solved
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
harrykausl
Domoticz version: 2021.1
Post by harrykausl »
before switching to zwavejsui I added one of my old z-wave thermostats to zwavejsui to test, if it works. Then I deletet the thermostat in zwavejsui. After migrating everything, I have the problem, that for this not existing thermostat, mqtt auto-devices are created. In zwave-js-ui I don't find anything. When deleting the devices and rebooting, they are back again. It seems, that there is something in the mqtt-messaging queue. I can't install mqtt-explorer on my debian bullsyeye 32 bit os. What can I do?
I stopped mosquitto and deleted the mosquitto.db. The devices were gone, but my shelly devices created with shellyteacher4demo didn't work again. So I recopied the old mosquitto.db, the shelly worked agin, but the devices reappear.
1. forbid creating new devices in setting
2. disable mqtt-autodiscover
Or is there a way to find the mqtt-messages?
harrykausl
Re: mqtt auto discovery creates non existing devices
I installed mqtt-explorer on my laptop and see the non existing device and the messages. I'll try to delete the messages there. Can I delete the whole zwave device Thermo_Test or only the messages
mqtt-explorer.pdf
(364.17 KiB) Downloaded 113 times
harrykausl
Solved, deleted all messages of thermo_test in mqtt-explorer.
