🌙 Nightglass Theme (WIP)
Gravityz
Domoticz version: 2026.3
Re: 🌙 Nightglass Theme (WIP)
Post by Gravityz »
strange,
i can not change the icon of any scene or group whether it has one or 2 buttons
i keep getting the domoticz refused error but can not read the complete error description. it is also not logged
Gravityz
Post by Gravityz »
indeed needed on the dynamic dashboard
dimmers have a slider but normal lights and temperature sensors do not and take up way to much space
if we can have smaller widgets for normals lights, switches and temperature sensors that would help a lot.
pfloryann wrote: Friday 04 September 2026 15:05 The smaller widgets in the nightglass tour are very nice, it would be interesting if they could be added to the dynamic dashboard or in pages to be able to select for each device if you want such a widget.
imautohuttraeger
Domoticz version: latest
Post by imautohuttraeger »
deleted. deleted
Stop, look and listen.
imautohuttraeger
Gravityz wrote: Friday 04 September 2026 16:34 strange,
You are right. Seems I have not clearly watched it while testing it on the fly on a smartphone. Sorry
galadril
Post by galadril »
imautohuttraeger wrote: Friday 04 September 2026 12:29
Gravityz wrote: Friday 04 September 2026 11:30 They already thought of that.
i think it is under setup-about-tips and tricks
That is is general tour for Domoticz. I mean the new tour for night glass theme since today's latest beta of night glass.
There is no option currently, ill add it.
For now, you can run this in your Dev Console when on a Domoticz page:
dzTour.reset()
And then hard refresh the page
imautohuttraeger
I just want to express my highest appreciation for all the work that has been done on this theme so far. It is meanwhile an every day tool for me that I don't want to miss anymore. Just one example for a best practise experience:
After installing the SolarEdge Modbus TCP plugin yesterday, 82 new devices were added. By simply filtering for the respective hardware and type, it is shrunk to just 11 energy devices where I am focusing on.
ferrosk
Domoticz version: 2026.2
Re: [emoji287] Nightglass Theme (WIP)
Post by ferrosk »
Hi galadril,
Many thanks for your work on this very nice theme.
Would it be possible to change the colors of the temperature trend arrows to match the original Domoticz theme? In the original theme, a rising temperature is shown in red and a falling temperature in blue, whereas in Nightglass it currently vice-versa.
To me, the original behavior makes more sense, as red is commonly associated with rising temperatures and blue with falling temperatures.
Domoticz 2026.2 on Odroid M1 and Armbian
MySensors (RFM69 Serial GW): bunch of DIY sensors/devices
Zwave (Z-Wave.me RaZberry board): Danfoss devices
Zigbee (Sonoff Dongle Plus): IKEA, Tesla devices
knasson
Domoticz version: 2026-3
Post by knasson »
Wonderful Job for this theme!
I ask myself why the wind icon overided by the theme is no longer animated
instead of the regular (or default) wind icon of domoticz remain animated.
hyeronimo
Post by hyeronimo »
Hi, love the nightglass theme! Just two things I ran into: creating a new floorplan is not possible any more. The device icons can not be dragged to the proper spot on the floorplan image. Or to be more precise, I could only drag one icon (heating on /off) but no other icons. Switching to default theme is a workaround.
Also I would really enjoy a more visible mini-graph in the device block. I cannot find how to change these colors.
imautohuttraeger
Only some of my temperature sensors have an indicator arrow for rising or falling temperature.
The two sensors marked with a red "X" on the screenshot are even of the same type and subtype. And there is definitely log data available.
What is the cause? I have not found any adjustment.
imautohuttraeger wrote: Monday 05 October 2026 11:18 Only some of my temperature sensors have an indicator arrow for rising or falling temperature.
This is not a theme issue but Domoticz. It has some logic to calculate the trend. If it can calculate it, it sets the trend attribute (that the theme will pick up). So if you want to discuss this in more detail please create a new topic.
imautohuttraeger
Ah, thanks for clarifying this. I thought these arrows don't show up in other themes, but now I see that it is in the default theme, too.
Will copy this and post it again.
Jeweettoch13
Domoticz version: 2026.4
Post by Jeweettoch13 »
imautohuttraeger wrote: Friday 18 September 2026 11:42 I just want to express my highest appreciation for all the work that has been done on this theme so far. It is meanwhile an every day tool for me that I don't want to miss anymore. Just one example for a best practise experience:
How did you get your icons on orange/yellow?
*edit: Got it!
Last edited by Jeweettoch13 on Saturday 17 October 2026 10:45, edited 1 time in total.
Jeweettoch13
I don't know if it's a bug or not, but when i have the auto flashing widgets upon change disabled, in the mobile view they still do. Is there a setting for to also apply the changes for both Desktop and mobile view?
Jeweettoch13
Is there also a way to modify the minimum width required to make a gauge? For my feeling it could easily fit into one block like the dial, but for the gauge it seems that the minimum width is 2 blocks?
imautohuttraeger
Jeweettoch13 wrote: Saturday 17 October 2026 13:46 Is there also a way to modify the minimum width required to make a gauge? For my feeling it could easily fit into one block like the dial, but for the gauge it seems that the minimum width is 2 blocks?
This is not related to nightglass theme, but to the Dynamic Dashboard.
viewtopic.php?t=44536
So maybe you copy and paste your question there. I also have the impression that there could be more space used for a gauge and other things. But I guess it is a challenge because it has to fit also in edit mode and for different display resolutions.
