good morning to everybody,
I need help since I can not find information on the internet.
Recently I discovered domoticz and I have been able to unify several domotic devices that I have at home, for example the NEST thermostat, XIAOMI GATEWAY, NETATMO meteorological station etc. I would like to install domotic on a raspberry v3.
I also have DIO 1.0 and 2.0 modules but at the moment they are not compatible with domoticz.
I have seen that you have the rfplayer 1000. it seems that rfplayer1000 is compatible with the frequency 868 mhz. The DIO 2.0 modules work on the 868.3 frequency and with the DIO BY EDISIO communication protocol (if I'm not wrong).
I would like to make sure (before buying the rfplayer 1000) if I could control my DIO 2.0 modules. from domoticz using rfplayer 1000.
I see that the rfplayer 1000 is compatible with edisio but nowhere do I find it compatible with the DIO 2.0 modules. But if it is compatible with modules DIO 1.0 to 433mhz.
Anyway, I think that if RFPLAYER1000 is not compatible with DIO 2.0, rfpayer 1000 can memorize frames in the air and learn frequencies, it also has the parrot function.
I have some questions,
1) If I send an order from the HOMEBOX DIO to a DIO 2.0 module, can the Rfplayer1000 device read that frame and memorize it?
2) so if it would be possible to integrate DIO 2.0 in domoticz using RFPLAYER 1000?
3) If I am sending an order to each DIO 2.0 module, could I integrate all the modules in domoticz?
4) DIO 2.0 modules would appear in domoticz as new devices/switches?
5) In the case that I detected a blind module DIO 2.0 using RFPLAYER in domoticz, the orders to send to the module that would be open, close and stop?
I have read in the forum comunity.domadoo that DIO 2.0 is compatible with rfplayer after the v.1.34 update of the RFPLAYER. I leave the link below so they can read it:
https://community.domadoo.com/t/compati ... 2-0/2859/6
Mr. Laurent writes:
"The edisio protocol is now compatible with RFP1000, which also supports DIO 2.0 products
It must be updated with firmware 1.34: http://rfplayer.com/telechargement/ 33
After depending on the box you use, the functionality may not be integrated yet "
Mr. Laurent also writes:
"For now, obviously the edisio protocol (DiO 2.0) is not yet compatible with Domoticz."
I think it is not compatible with domoticz but if I buy a rfplayer 1000 it would be compatible with domoticz?
Please, I have many doubts and I ask for your help before buying RFPLAYER1000 and then it does not work.
I would like to create an event with domoticz so that when it rains and NETATMO detects rain, the DIO 2.0 blinds are closed, and when NETATMO detects strong wind that the DIO 2.0 close my awnings
I await your news.
Thanks in advance to every body
RFPLAYER 1000 / DIO 2.0 Topic is solved
Re: RFPLAYER 1000 / DIO 2.0
Hi ,
Please, help me. No body have DIO 2.0 and rfplayer100?
Thanks in advance
Thanks in advance
Did you find a solution ? I am in the same case as you, thank you for your return
cordially
cordially
hi dear friend,
Sorry now i have read you answer.
I don´t found solution. I changed all dio system from my house . I have installed shellys. All works better and perfectly control with domoticz.
- Target OS: -
I know this topic is very old but I'm implementing missing features of RFPlayer natively (not a plugin) in domoticz. Currently, the implementation is able to control RTS store et get data from many sensors (oregon, RTS/X10/AC/ARC remotes,...). Others protocols effectors (ARC/AC//BLYSS...) are implemented too but may not work. The implementation handle jamming detection too. Implementation is still in progress but if people are motivated to test this... Those features are available in the beta channel.
- Target OS: -
A PR about RFPlayer 1000 has been accepted and I'm still interested to get feedback about this if someone is concern about it
