Export data from DB to Excel [SOLVED]
JuanUil
- Domoticz version: 4.11083
Hi There,
I have made an Excel sheet with all the date from outside temp, kWh usage and solar production.
At the moment I download the database and copy the data from there to my excel sheet.
Is the a way to do this automatically?
Curious if anyone has ever done this.
greetz
Jan
greetz
Jan
- waaren
Re: Export data from DB to Excel
If a CSV file works for you then a bash- or dzVents script can do this for you. Just let me know the ID's or names, the field names and the frequency and I will have a look.JuanUil wrote: Monday 30 December 2019 16:02 I have made an Excel sheet with all the date from outside temp, kWh usage and solar production.
At the moment I download the database and copy the date from there to my excel sheet.
JuanUil
Hi Waaren,
I Think I can find a way to import the csv to my workbook.
So The ID's
44 for the kWh used
48 for the solarproduction
72 for the outside temp
happy oud en nieuw
Jan
So The ID's
44 for the kWh used
happy oud en nieuw
Jan
- waaren
can you try this ? it collects the date from the daily history tables in the domoticz database.JuanUil wrote: Monday 30 December 2019 22:14 44 for the kWh used
--[[ -- sqliteDump.lua
Dumps daily data as csv file
requires sqlite3
install command on linux: sudo apt install sqlite3
install command on openwrt: opkg install sqlite3-cli
install command on synology: sudo /opt/bin/opkg install sqlite3-cli
History:
20191231
first public release
return
on =
timer =
"at 01:07",
logging =
level = domoticz.LOG_DEBUG,
marker = "sqliteDump"
execute = function(dz)
-- ======================= enter you settings below this line ==================
local path = "/home/pi/domoticz/" -- full qualified path to your domoticz directory
local database = "domoticz.db" -- database filename + extension
local sqlite = "/usr/bin/sqlite3" -- location of your sqlite3 tool -- which sqlite3
local allTemperatures = "72" -- comma separated list of temperature devices to export
local allUsages = "44" -- comma separated list
local allSolar = "48" -- comma separated list
local csvFile = "/home/pi/domoticz2excel.csv"
-- ======================= No modification needed below this line ==================
local copy = "safeCopy.db"
local baseCommand = "sudo " .. sqlite .. " -header -csv " .. copy
local closure = " >> " .. csvFile
local collects = {}
collects.meters = 'select a.id as meter, a.name as naam, b.Value as value, b.counter as counter from devicestatus a , meter_calendar b where a.id = b.devicerowid and a.id in (' .. allUsages .. ',' .. allSolar ..');'
collects.temperatures = 'select a.id as temperature, a.name as naam, b.temp_min as min, b.temp_max as max, b.temp_avg as avg, b.date as date from devicestatus a , temperature_calendar b where a.id = b.devicerowid and a.id in (' .. allTemperatures .. ') order by a.id;'
local function osCommand(cmd)
dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
if commandOutput:find '::ERROR::' then -- something went wrong
dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_DEBUG)
else -- all is fine!!
dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
return commandOutput,returnTable[3] -- rc[3] contains returnCode
local function sqliteDump()
local result, rc
if dz.utils.fileExists(path .. database) then
if dz.utils.fileExists(sqlite) then
result, rc = osCommand('cp ' .. path .. database .. ' ' .. copy)
if rc ~= 0 then return rc, result end
result, rc = osCommand('rm -f ' .. csvFile)
for type, sql in pairs (collects) do
result, rc = osCommand(baseCommand .. ' "' .. sql .. '" ' .. closure)
result, rc = osCommand('rm -f ' .. copy)
return -1,"sqlite3 not installed / not found"
return -1,"wrong path to database"
return 0, commandOutput
-- main program
local rc, result = sqliteDump()
if rc ~= 0 then dz.log(result,dz.LOG_ERROR) end
JuanUil
Hi Waaren,
Thank you for your effort!!!
I am not at home today so I will try it tomorrow and let you know.
Happy oud en nieuw
Happy oud en nieuw
JuanUil
Hi Waaren,
First of all: Best wishes for 2020!!!
I have tried your program and it makes a domoticz2csv file in home/pi.
The problem is that I can't open it.
In Filezilla it gives:
So I cannot check.
I have tried to change the rights of the file but was not succesful
Jan
Fout: /home/pi/Documents/test.csv: open for read: permission denied
Fout: Bestandsoverdracht mislukt I have tried to change the rights of the file but was not succesful
Jan
- waaren
Hi Jan,
also a happy new year for you.
What is the owner of the file ? And what are the permissions ?
For now I add a chmod statement to the script.
requires sqlite3
History:
20191231 first public release
20200102 Add sudo chmod to make csvfile readable for all
return
on =
timer =
"at 01:07",
logging =
local collects = {}
local result, rc
result, rc = osCommand('sudo chmod 777 ' .. csvFile)
-- main program
}Debian buster, bullseye on RPI-4, Intel NUC.
JuanUil
The owner is root and normaly I am pi, but it is working now!!
Fabulous, thank you verry much!!
I am going to make a macro to import the csv to my workbook now.
If you are interested I will show you the result.
Greetings
Jan
Greetings
Jan
- Egregius
- Domoticz version: v2024.7
Isn't it a better idea to put the data in a MySQL database instead of Excel?
How is Excel gonna handle the data after several years?
JuanUil
I have data from my Youless from 2015 till now.
The csv file made from the program of Waaren is gathering them perfectly.
The advandtage from excel is that you can make nice graphs and predictions.
- waaren
That would be nice. Thx in advance !
fzoet
- Domoticz version: 2020.2
Very interested in this script. I tried it and it runs but the csv file remains empty. The data i am trying to export is my P1 power meter (idx 17) and p1 gas meter (idx 21).
That way I can use excel to calculate the actual power usage when combined with the solar inverter download (until i can get this automated in Domoticz as well, see https://domoticz.com/forum/viewtopic.php?f=14&t=34272)
I just changed the idx numbers for allusages to 17, and allsolar to 21 to test. No other changes. So what else needs to be amended to get the export going?
- waaren
The P1 history is in another table ( MultiMeter_Calendar ) and was not implemented yet in this script. I updated the script to include it (see below)fzoet wrote: Friday 23 October 2020 14:29 Very interested in this script. I tried it and it runs but the csv file remains empty. The data i am trying to export is my P1 power meter (idx 17) and p1 gas meter (idx 21).
requires sqlite3
History:
20201023 Add option to use MultiMeter
return
on =
timer =
'at 01:07',
'at 14:47',
devices =
'sqlDump', -- test trigger can be ignored
logging =
level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all is OK
marker = 'sqliteDump',
local path = '/opt/domoticz/' -- full qualified path to your domoticz directory
local database = 'domoticz.db' -- database filename + extension
local sqlite = '/usr/bin/sqlite3' -- location of your sqlite3 tool; check with 'which sqlite3'
local csvFile = '/usr/local/domotica/data/domoticz2excel.csv'
-- set to '' for the types you don't need
local allTemperatures = '152,148' -- comma separated list of Temperature sensors to export
local allMeters = '36,1168,2872' -- comma separated list of Solar + Meters + Usage sensors
local allMultiMeters = '35' -- comma separated list P1 energy sensor
local copy = 'safeCopy.db'
local baseCommand = 'sudo ' .. sqlite .. ' -header -csv ' .. copy
local closure = ' >> ' .. csvFile
local collects = {}
collects.meters = 'SELECT a.ID Meter, a.Name Name, b.Value Value, b.Counter Counter, b.Date Date FROM DeviceStatus a , Meter_Calendar b ' ..
' WHERE a.ID = b.DeviceRowID AND a.ID IN (' .. allMeters .. ');'
collects.Temperatures = 'SELECT a.ID Temperature, a.Name Name, b.Temp_Min min, b.Temp_Max max, b.Temp_Avg avg, b.Date Date ' ..
' FROM DeviceStatus a , Temperature_Calendar b WHERE a.ID = b.DeviceRowID AND a.ID IN (' .. allTemperatures .. ') ORDER BY a.ID;'
collects.MultiMeters = 'SELECT a.Name, b.* FROM DeviceStatus a , MultiMeter_Calendar b WHERE a.ID = b.DeviceRowID AND a.ID IN (' .. allMultiMeters .. ') ORDER BY b.DeviceRowID;'
local result, rc
for _, sql in pairs (collects) do
return -1,'sqlite3 not installed / not found'
return -1,'wrong path to database'
-- main program
fzoet
@waaren thanks. With a few small modifications (paths and smart meter idx) this works and i get a CSV dump of the P1 meter per day.
How can I change the code so that I get the values for each day (so every measurement)? These are needed to calculate the actual usage per counter (high / normal), and the percentage of used solar energy - and with that the return on investment of the solar panels.
For others that are interested: I used the paths below for the raspberry pi Domoticz install. Note that the change is the reference to the home directory.
- waaren
Change the query strings tofzoet wrote: Monday 26 October 2020 12:33 How can I change the code so that I get the values for each day (so every measurement)? These are needed to calculate the actual usage per counter (high / normal), and the percentage of used solar energy - and with that the return on investment of the solar panels.
collects.meters = 'SELECT a.ID Meter, a.Name Name, b.Value Value, b.Usage Usage, b.Date Date '..
' FROM DeviceStatus a , Meter b WHERE a.ID = b.DeviceRowID AND a.ID IN (' .. allMeters .. ')'
collects.Temperatures = 'SELECT a.ID ID, a.Name Name, b.Temperature Temperature, b.Date Date ' ..
' FROM DeviceStatus a , Temperature b WHERE a.ID = b.DeviceRowID AND ' ..
' a.ID IN ( '.. allTemperatures .. ') ORDER BY a.ID '
collects.MultiMeters = 'SELECT a.Name, b.* FROM DeviceStatus a , MultiMeter b WHERE a.ID = b.DeviceRowID ' ..
' AND a.ID IN (' .. allMultiMeters .. ') ORDER BY b.DeviceRowID'Debian buster, bullseye on RPI-4, Intel NUC.
fzoet
Thanks @waaren.
As the file will be containing the past 24 hours and overwrite the previous file, I changed the filename to contain yesterday's date and run the timer at 00:04.
Question:
is there a way to dump this daily data from all the past months at once? - to get the backlog
local csvFile = "/home/pi/domoticz2excel"
local csvFile = csvFile .. "_" .. os.date("%Y-%m-%d",os.time()-24*60*60) .. ".csv"
- waaren
Only if you have daily backups that go back that far. The short log sensors (288 rows a day / sensor) are collated and averaged into the long term storage (1 row / day) once a day just after midnight.fzoet wrote: Monday 26 October 2020 17:22 Question:
The retention period for short log sensors is max. 7 days
fzoet
@waaren. Thanks, yes I feared that from what I have already read about domoticz. Thanks for the confirmation.
fzoet
Re: Export data from DB to Excel [SOLVED]
Here is the last full code, as it works in my setup. Thanks @waaren for all your contributions - the credits fully go to you!
requires sqlite3
History:
20201026 Added option to get daily data, and included yesterdays' date to csv filename
return
on =
timer =
'at 00:04',
--'at 17:16',
devices =
logging =
local csvFile = "/home/pi/domoticz2excel" --full path to the csv filename for the dump, without the .csv extension (will be added by script, together with date)
local allMultiMeters = '17' -- comma separated list P1 energy sensor
local collects = {}
--==Query for daily data==
--==end query daily data
--==Query for minute data
--==end query minute data
local result, rc
-- main program
