timer  [SOLVED]
ben92
timer
Post by ben92 »
hi,
i use a timer like this :
timer = {
'30 minutes after sunset',
but it doesnt start script, I think it hasn't worked for 1 week.
djalexnl
Re: timer
Post by djalexnl »
I also have the same problem...
After upgrading to 13080 this weekend all DZVENT scripts that have a trigger with ...after or before sunset or sunrise stopped working...
For example..
    active = true,
    logging = {
		level = domoticz.LOG_DEBUG, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level
		marker = "TEST"
        timer = {'10 minutes after sunset'},
    local ErkerLampLinks = domoticz.devices(2692)
    ErkerLampLinks.switchOn().checkFirst()
I noticed that the last 2 days my lights did not turn on after sunset... so i started testing with some test scripts...
Alcloud
Re: timer
Post by Alcloud »
Same problem here
Re: timer
Alcloud wrote: Monday 15 March 2021 22:07
Same problem here
Thx for reporting. Will be fixed in next build.
djalexnl
Re: timer
Post by djalexnl »
Thanx for the quick response. Will be looking forward :)
waaren wrote: Monday 15 March 2021 23:10
Same problem here
Re: timer
djalexnl wrote: Monday 15 March 2021 23:32 Thanx for the quick response. Will be looking forward :)
Should be fixed in build 13081. If you need it now you can already test by replacing <domoticz dir>/dzVents/runtime/Time.lua with below code but only if you are using a version with the described bug.
local utils = require('Utils')
local _MS -- kind of a cache so we don't have to extract ms every time
local gTimes --
local isEmpty = function(v)
	return (v == nil or v == '')
local function getTimezone()
	local diff = os.difftime(os.time(), os.time(os.date("!*t")))
	return ( os.date('!*t').isdst and ( diff + 3600 ) ) or diff
local function getSMs(s)
	local ms = 0
	local parts = utils.stringSplit(s, '.') -- do string splitting instead of math stuff.. can't seem to get the floating points right
	s = tonumber(parts[1])
	if (parts[2] ~= nil) then
		-- should always be three digits!!
		ms = tonumber(parts[2])
	return s, ms
local function parseDate(sDate)
	return string.match(sDate, "(%d+)%-(%d+)%-(%d+)[%sT]+(%d+):(%d+):([0-9%.]+)")
local function _getMS()
	if (_MS == nil) then
		local dzCurrentTime = _G.globalvariables.currentTime
		local y, mon, d, h, min, s = parseDate(dzCurrentTime)
		local ms
		s, ms = getSMs(s)
		_MS = ms
	return _MS
local getDiffParts = function(secDiff, ms, offsetMS)
	-- ms is the ms part that should be added to secDiff to get 'sss.ms'
	if (ms == nil) then
		ms = 0
	if (offsetMS == nil) then
		offsetMS = 0
	local secs = secDiff
	local msDiff
	msDiff = (secs * 1000) - ms + offsetMS
	if (math.abs(msDiff) < 1000) then
		secs = 0
	local minDiff = math.floor(math.abs((secs / 60)))
	local hourDiff = math.floor(math.abs((secs / 3600)))
	local dayDiff = math.floor(math.abs((secs / 86400)))
	local cmp
	if (msDiff == 0) then
		cmp = 0
	elseif (msDiff > 0) then
		cmp = -1
		cmp = 1
	return
		math.abs(msDiff),
		math.abs(secs),
		minDiff,
		hourDiff,
		dayDiff,
		cmp
-- week functions as taken from http://lua-users.org/wiki/WeekNumberInYear
-- Get day of a week at year beginning
--(tm can be any date and will be forced to 1st of january same year)
-- return 1=mon 7=sun
local function getYearBeginDayOfWeek(tm)
	local yearBegin = os.time{year=os.date("*t",tm).year,month=1,day=1}
	local yearBeginDayOfWeek = tonumber(os.date("%w",yearBegin))
	-- sunday correct from 0 -> 7
	if(yearBeginDayOfWeek == 0) then
		yearBeginDayOfWeek = 7
	return yearBeginDayOfWeek
-- tm: date (as returned from os.time)
-- returns basic correction to be add for counting number of week
-- weekNum = math.floor((dayOfYear + returnedNumber) / 7) + 1
-- (does not consider correction at begin and end of year)
local function getDayAdd(tm)
	local yearBeginDayOfWeek = getYearBeginDayOfWeek(tm)
	local dayAdd
	if(yearBeginDayOfWeek < 5 ) then
		-- first day is week 1
		dayAdd = (yearBeginDayOfWeek - 2)
		-- first day is week 52 or 53
		dayAdd = (yearBeginDayOfWeek - 9)
	return dayAdd
-- tm is date as returned from os.time()
-- return week number in year based on ISO8601
-- (week with 1st thursday since Jan 1st (including) is considered as Week 1)
-- (if Jan 1st is Fri,Sat,Sun then it is part of week number from last year -> 52 or 53)
local function getWeekNumberOfYear(tm)
	local dayOfYear = os.date("%j",tm)
	local dayAdd = getDayAdd(tm)
	local dayOfYearCorrected = dayOfYear + dayAdd
	if(dayOfYearCorrected < 0) then
		-- week of last year - decide if 52 or 53
		local lastYearBegin = os.time{year=os.date("*t",tm).year-1,month=1,day=1}
		local lastYearEnd = os.time{year=os.date("*t",tm).year-1,month=12,day=31}
		dayAdd = getDayAdd(lastYearBegin)
		dayOfYear = dayOfYear + os.date("%j",lastYearEnd)
	local weekNum = math.floor((dayOfYearCorrected) / 7) + 1
	if( (dayOfYearCorrected > 0) and weekNum == 53) then -- check if it is not considered as part of week 1 of next year
		local nextYearBegin = os.time{year=os.date("*t",tm).year+1,month=1,day=1}
		local yearBeginDayOfWeek = getYearBeginDayOfWeek(nextYearBegin)
			weekNum = 1
	return weekNum
local function Time(sDate, isUTC, _testMS)
	local LOOKUPDAYABBROFWEEK = { 'sun', 'mon', 'tue', 'wed', 'thu', 'fri', 'sat' }
	local LOOKUPDAYNAME = { 'Sunday', 'Monday', 'Tuesday', 'WednesDay', 'Thursday', 'Friday', 'Saturday' }
	local LOOKUPMONTHABBR = { 'jan', 'feb', 'mar', 'apr', 'may', 'jun', 'jul', 'aug', 'sep', 'oct', 'nov', 'dec' }
	local LOOKUPMONTH = { 'January', 'February', 'March', 'April', 'May', 'June', 'July', 'August', 'September', 'October', 'November', 'December' }
	local ms
	local now
	local time = {}
	local localTime = {} -- nonUTC
	local self
	local getMS = function()
		if (_testMS ~= nil) then
			return _testMS
			return _getMS()
	if isUTC and isUTC == true then
		now = os.date('!*t')
		now = os.date('*t')
		isUTC = false
	local function makesDate()
		local now
		if (isUTC) then
			now = os.date('*t')
		local ms = _testMS == nil and getMS() or _testMS
		return ( now.year .. '-' .. now.month ..'-' .. now.day .. ' ' .. now.hour .. ':' .. now.min .. ':' .. now.sec .. '.' .. tostring(ms) )
	if sDate == nil or sDate == '' then
		sDate = makesDate()
	local y, mon, d, h, min, s = parseDate(sDate)
	if not(y and mon and d and h and min and s) then
		sDate = makesDate()
		utils.log('sDate was invalid. Reset to ' .. sDate , utils.LOG_ERROR)
	-- extract s and ms
	s, ms = getSMs(s)
	local dDate = os.time{year=y,month=mon,day=d,hour=h,min=min,sec=s }
	time = os.date('*t', dDate)
	local tToday = os.time{
		day= now.day,
		year= now.year,
		month= now.month,
		hour= now.hour,
		min= now.min,
		sec= now.sec
	-- calculate how many minutes that was from now
	local msDiff, secDiff, minDiff, hourDiff, dayDiff, cmp = getDiffParts(os.difftime(tToday, dDate), ms, getMS())
	if (cmp > 0) then -- time is in the future so the xxAgo items should be negative
		msDiff = -msDiff
		secDiff = -secDiff
		minDiff = -minDiff
		hourDiff = -hourDiff
		dayDiff = -dayDiff
	if (isUTC) then
		localTime = os.date('*t', os.time(time) + getTimezone())
		self = localTime
		self.utcSystemTime = now
		self.utcTime = time
		self.utcTime.minutes = time.min
		self.utcTime.seconds = time.sec
		self = time
	self.rawDate = self.year .. '-' .. string.format("%02d", self.month) .. '-' .. string.format("%02d", self.day)
	self.time = string.format("%02d", self.hour) .. ':' .. string.format("%02d", self.min)
	self.minutesnow = self.hour * 60 + self.min
	self.rawTime = self.time .. ':' .. string.format("%02d", self.sec)
	self.rawDateTime = self.rawDate .. ' ' .. self.rawTime
	self.milliSeconds = ms
	self.milliseconds = ms
	self.dayAbbrOfWeek = LOOKUPDAYABBROFWEEK[self.wday]
	self.dayName = LOOKUPDAYNAME[self.wday]
	self.monthAbbrName = LOOKUPMONTHABBR[self.month]
	self.monthName = LOOKUPMONTH[self.month]
	-- Note: %V doesn't work on Windows so we have to use a custom function here
	-- doesn't work: self.week = tonumber(os.date('%V', dDate))
	self.week = getWeekNumberOfYear(dDate)
	self.raw = sDate
	self.isToday = (now.year == time.year and now.month == time.month and now.day == time.day)
	self.msAgo = math.floor(msDiff)
	self.millisecondsAgo = self.msAgo
	self.minutesAgo = minDiff
	self.secondsAgo = math.floor(secDiff)
	self.hoursAgo = hourDiff
	self.daysAgo = dayDiff
	self.minutes = self.min
	self.seconds = self.sec
	self.minutesSinceMidnight = self.hour * 60 + self.min
	self.secondsSinceMidnight = self.minutesSinceMidnight * 60 + self.sec
	self.utils = utils
	self.isUTC = isUTC
	self.dDate = dDate
	self.isdst = time.isdst
	if (_G.TESTMODE) then
		_G = _G or {} -- Only used when testing testTime.lua
		_G.timeofday = _G.timeofday or {} -- Only used when testing testTime.lua
		function self._getUtilsInstance()
			return utils
	self.current = os.date('*t')
	-- compares to self against the provided Time object (t)
	function self.compare(t)
		if (t.raw ~= nil) then
				getDiffParts(os.difftime(dDate, t.dDate), t.milliseconds, ms) -- offset is 'our' ms value
				mins = minDiff,
				hours = hourDiff,
				secs = math.floor(secDiff),
				seconds = math.floor(secDiff),
				minutes = minDiff,
				days = dayDiff,
				ms = math.floor(msDiff),
				milliseconds = math.floor(msDiff),
				compare = cmp -- 0 == equal, -1==(t earlier than self), 1=(t later than self)
			utils.log('Invalid time format passed to diff. Should a Time object', utils.LOG_ERROR)
	function self.localeMonths()
		local months =
			january = 1, february = 2, march = 3, april = 4, may = 5, june = 6, july = 7, august = 8,
			september = 9, october = 10, november = 11, december = 12, jan = 1, feb = 2, mar = 3, apr = 4,
			jun = 6, jul = 7, aug = 8, sep = 9, oct = 10, nov = 11, dec = 12
		local monthSeconds = 2678400 -- accurate enough for this purpose
		local startSeconds = 1577833200 -- 2020-1-1 00:00
		for monthNumber = 1, 12 do
			months[os.date('%B', startSeconds + ( monthNumber - 1 ) * monthSeconds ):sub(1,3):lower()] = monthNumber
			months[os.date('%b', startSeconds + ( monthNumber - 1 ) * monthSeconds ):lower()] = monthNumber
		return months
	function self.dateToTimestamp(dateString, control)
		local tm, dateTable, format = {}, {}, {}
		local pattern
		if control and control:find('%%') then
			pattern = control
		elseif control ~= nil then -- control = format
			local index = 1
			for word in control:gmatch("%w+") do table.insert(format, word) end
			for value in dateString:gmatch("%w+") do
				dateTable[format[index]] = value
				index = index + 1
			tm.year = dateTable.yyyy or ( dateTable.yy and ( dateTable.yy + 2000 )) or os.date('%Y')
			tm.month = dateTable.mm or
					( dateTable.mmm and self.localeMonths()[dateTable.mmm:lower()]) or
					( dateTable.mmmm and self.localeMonths()[dateTable.mmmm:lower()]) or 1
			tm.day = dateTable.dd or 1
			tm.hour = dateTable.hh or 0
			tm.min = dateTable.MM or 0
			tm.sec = dateTable.ss or 0
			return os.time(tm)
		pattern = pattern or '(%d+)%D+(%d+)%D+(%d+)%D+(%d+)%D+(%d+)' -- yyyy-mm--dd hh:mm
		tm.year, tm.month, tm.day, tm.hour, tm.min, tm.sec = dateString:match(pattern)
		return os.time(tm)
	function self.timestampToDate(timestamp, humanizedPattern, offSet)
		local function convertMnemomic2FmtCode(humanizedPattern)
			local humanizedPattern = humanizedPattern or 'yyyy-mm-dd hh:MM:ss'
			mnemomics =
				{'dddd' , '%A'}, -- full weekdayname(e.g. Wednesday) language depends on locale
				{'ddd'  , '%a'}, -- abbreviated weekdayname(e.g. Wed) language depends on locale
				{'dd'   , '%d'}, -- day of the month(16){[01-31]
				{'mmmm' , '%B'}, -- full monthname(e.g September) language depends on locale
				{'mmm'  , '%b'}, -- abbreviated monthname(e.g. Sep) language depends on locale
				{'mm'   , '%m'}, -- month[01-12]
				{'yyyy' , '%Y'}, -- 4-digit year
				{'yy'   , '%y'}, -- two-digityear(98){[00-99]
				{'hh'   , '%H'}, -- hour 24-hour clock){[00-23]
				{'ii'   , '%I'}, -- hour 12-hour clock[01-12]
				{'MM'   , '%M'}, -- minute{[00-59]
				{'ss'   , '%S'}, -- second [00-60]
				{'W'	, '%W'}, -- weeknumber [01-53]
				{'w'	, '%w'}, -- weekday{[0-6] Sunday-Saturday
				{'datm' , '%c'}, -- date and time (e.g. 09/16/98 23:48:10) format depends on locale
				{'mer'  , '%p'}, -- either "am" or "pm" locale
				{'date' , '%x'}, -- date(e.g. 09/16/98) format depends on locale
				{'time' , '%X'}, -- time(e.g. 23:48:10)
			for _, conversion in ipairs(mnemomics) do
				humanizedPattern = string.gsub(humanizedPattern, conversion[1], '%' .. conversion[2])
			return humanizedPattern
		local timestamp = ( timestamp or os.time() ) + ( offSet or 0 )
		local dateTimeString = os.date( convertMnemomic2FmtCode(humanizedPattern) , timestamp )
		if dateTimeString:find('nZero') then -- remove leading zero's
			return dateTimeString:gsub('nZero',''):gsub(' 0',' '):gsub('^0',''):gsub('%s*$','')
		return dateTimeString:gsub('%s*$','')
	function self.dateToDate(date, sourceFormat, targetFormat, offSet )
		return self.timestampToDate(self.dateToTimestamp(date,sourceFormat), targetFormat, offSet)
	function self.addSeconds(seconds, factor)
		if type(seconds) ~= 'number' then
			self.utils.log(tostring(seconds) .. ' is not a valid parameter to this function. Please change to use a number value!', utils.LOG_ERROR)
			factor = factor or 1
			return Time( os.date("%Y-%m-%d %X", self.dDate + factor * math.floor(seconds) ))
	function self.addDays(days)
		return self.addSeconds(days, 24 * 3600)
	function self.addHours(hours)
		return self.addSeconds(hours, 3600)
	function self.addMinutes(minutes)
		return self.addSeconds(minutes, 60)
	function self.makeTime(oDate, isUTC)
		local sDate = ( type(oDate) == 'table' and os.date("%Y-%m-%d %H:%M:%S", os.time(oDate)) ) or
						( tonumber(oDate) and self.timestampToDate(oDate) ) or oDate
		return Time(sDate, isUTC)
	function self.toUTC(oDate, offset)
		local sDate = ( type(oDate) == 'table' and os.date("%Y-%m-%d %H:%M:%S", os.time(oDate)) ) or oDate
		local offset = offset or 0
		return Time(sDate).addSeconds(-1 * getTimezone() + offset).raw
	-- return ISO format
	function self.getISO()
		return os.date("!%Y-%m-%dT%TZ", os.time(time))
	-- returns hours part and minutes part of the passed-in minutes amount
	function minutesToTime(minutes)
		local hh = math.floor(minutes / 60)
		local mm = minutes - (hh * 60)
		return hh, mm
	-- returns true if the current time is within a time range: startH:startM and stopH:stopM
	local function timeIsInRange(startH, startM, stopH, stopM)
		local function getMinutes(hours, minutes)
			return (hours * 60) + minutes
		local currentMinutes = getMinutes(self.hour, self.min)
		local startMinutes = getMinutes(startH, startM)
		local stopMinutes = getMinutes(stopH, stopM)
		if stopMinutes < startMinutes then -- add 24 hours (1440 minutes ) if endTime < startTime
			if currentMinutes < stopMinutes then currentMinutes = currentMinutes + 1440 end
			stopMinutes = stopMinutes + 1440
		return ( currentMinutes >= startMinutes and currentMinutes <= stopMinutes )
	-- returns true if self.day is on the rule: on day1,day2...
	function self.ruleIsOnDay(rule)
		local days = string.match(rule, '%s+on%s+(.+)$') or string.match(rule, '^%s*on%s+(.+)$')
		if (isEmpty(days)) then
			return nil
		local isDayRule = false
		for i,day in pairs({'mon', 'tue', 'wed', 'thu', 'fri', 'sat', 'sun'}) do
			if (string.find(days, day) ~= nil) then
				isDayRule = true
				break
		if (not isDayRule) then
			return nil
		if (days ~= nil) then -- on <day>' was specified
			local hasDayMatch = string.find(days, self.dayAbbrOfWeek)
			if (hasDayMatch) then
				return true
				return false
		return nil
	-- returns true if self.week matches rule in week 1,3,4 / every odd-week, every even-week, in week 5-12,23,44
	function self.ruleIsInWeek(rule)
		if (string.find(rule, 'every odd week') and not ((self.week % 2) == 0)) then
			return true
		elseif (string.find(rule, 'every even week') and ((self.week % 2) == 0)) then
			return true
		elseif string.find(rule, 'every even week') or string.find(rule, 'every odd week') then
			return false
		local weeks = string.match(rule, 'in week% ([0-9%-%,% ]*)')
		if (weeks == nil) then
			return nil
		-- from here on, if there is a match we return true otherwise false
		-- remove spaces and add a comma
		weeks = string.gsub(weeks, ' ', '') .. ',' -- remove spaces and add a ',' so we can do simple search for the number
		-- do a quick scan first to see if we already have a match without needing to search for ranges
		if (string.find(weeks, tostring(self.week) .. ',')) then
			return true
		-- now get the ranges
		for set, from, to in string.gmatch(weeks, '(([0-9]*)-([0-9]*))') do
			to = tonumber(to)
			from = tonumber(from)
			if (isEmpty(from) and not isEmpty(to) and self.week <= to ) then
				return true
			if (not isEmpty(from) and isEmpty(to) and self.week >= from ) then
				return true
			if (not isEmpty(from) and not isEmpty(to) and to ~= nil) then
				if (self.week >= from and self.week <= to) then
					return true
		return false
	function self.ruleIsOnDate(rule)
		local dates = string.match(rule, 'on% ([0-9%*%/%,% %-]*)')
		if (isEmpty(dates)) then
			return nil
		local _ = require('lodash')
		local dateTable = utils.stringSplit(dates,',') -- get all date(ranges)
		dates = string.gsub(dates, ' ', '') .. ',' --remove spaces and add a , so we can do simple search for the number
		-- do a quick scan first to see if we already have a match without needing to search for ranges and wildcards
		for index, value in ipairs(dateTable) do
			if tonumber(value:match('%d+')) == self.day and tonumber(value:match('/(%d+)')) == self.month then
				return true
		-- wildcards
		for set, day, month in string.gmatch(dates, '(([0-9%*]*)/([0-9%*]*))') do
			if (day == '*' and month ~= '*') then
				if (self.month == tonumber(month)) then
					return true
			if (day ~= '*' and month == '*') then
				if (self.day == tonumber(day)) then
					return true
		local getParts = function(set)
			local day, month = string.match(set, '([0-9%*]+)/([0-9%*]+)')
			return day and tonumber( day ), month and tonumber( month )
		--now get the ranges
		for fromSet, toSet in string.gmatch(dates, '([0-9%/%*]*)-([0-9%/%*]*)') do
			local fromDay, toDay, fromMonth, toMonth
			if (isEmpty(fromSet) and not isEmpty(toSet)) then
				toDay, toMonth = getParts(toSet)
				if ((self.month < toMonth) or (self.month == toMonth and self.day <= toDay)) then
					return true
			elseif (not isEmpty(fromSet) and isEmpty(toSet)) then
				fromDay, fromMonth = getParts(fromSet)
				if ((self.month > fromMonth) or (self.month == fromMonth and self.day >= fromDay)) then
					return true
				if
					( self.month > fromMonth and self.month < toMonth ) or
					( fromMonth == toMonth and self.month == fromMonth and self.day >= fromDay and self.day <= toDay ) or
					( self.month == fromMonth and toMonth < fromMonth and self.day >= fromDay ) or
					( self.month == fromMonth and toMonth > fromMonth and self.day >= fromDay ) or
					( self.month == toMonth and toMonth < fromMonth and self.day <= toDay ) or
					( self.month == toMonth and toMonth > fromMonth and self.day <= toDay )
				) then
					return true
		return false
	function self.ruleIsBeforeAstrologicalMoment(rule)
		local minutes = tonumber(string.match(rule, '%.*(%d+)%s+minutes%s+before%.*'))
		local astronomicalString = rule:match('minutes%s+before%s+(%a+)') or ''
		local moment = tonumber(gTimes[astronomicalString .. 'inminutes']) or ''
		if minutes ~= nil and moment ~= '' then
			return ( self.minutesnow + minutes ) == moment
		return nil
	function self.ruleIsAfterAstrologicalMoment(rule)
		local minutes = tonumber(string.match(rule, '%.*(%d+)%s+minutes%s+after%.*'))
		local astronomicalString = rule:match('minutes%s+after%s+(%a+)') or ''
			return ( self.minutesnow - minutes ) == moment
		return nil
	-- returns true if self.time is at a astronomical moment
	-- sunset, sunrise, CivilTwilightEnd, NautTwilightStart, etc
	function self.ruleIsAtAstronomicalMoment(rule)
		local astronomicalString = rule:match('at%s+(%a+)') or ''
		local moment = tonumber(gTimes[astronomicalString .. 'inminutes']) or -1
		return moment == self.minutesnow or nil
	-- returns true if self.time is at a astronomical range
	-- daytime, nightime, etc
	function self.ruleIsAtAstronomicalRange(rule)
		if type(gTimes[astronomicalString]) == 'boolean' then
			return gTimes[astronomicalString] or nil
	-- returns true if self.min fits in the every xx minute /every other minute/every minute rule
	function self.ruleMatchesMinuteSpecification(rule)
		local function fitsMinuteRule(m)
			return (self.min / m == math.floor(self.min / m))
		if (string.find(rule, 'every minute')) then
			return true
		if (string.find(rule, 'every other minute')) then
			return fitsMinuteRule(2)
		local minutes = tonumber(string.match(rule, 'every (%d+) minutes'))
		if (minutes ~= nil) then
			if ((60 / minutes) ~= math.floor(60 / minutes) or minutes >= 60) then
				self.utils.log(rule .. ' is not a valid timer definition. Can only run every 1, 2, 3, 4, 5, 6, 10, 12, 15, 20 and 30 minutes.', utils.LOG_ERROR)
				return false
			return fitsMinuteRule(minutes)
		return nil -- nothing specified for this rule
	-- return true if self.hour fits the every hour/every other hour/every xx hours rule
	function self.ruleMatchesHourSpecification(rule)
		local function fitsHourRule(h)
			-- always fit every whole hour (hence the self.min == 0)
			return (self.hour / h == math.floor(self.hour / h) and self.min == 0)
		if (string.find(rule, 'every hour')) then
			return fitsHourRule(1)
		if (string.find(rule, 'every other hour')) then
			return fitsHourRule(2)
		local hours = tonumber(string.match(rule, 'every% (%d+)% hours'))
		if (hours ~= nil) then
			if ((24 / hours) ~= math.floor(24 / hours) or hours >= 24) then
				self.utils.log(rule .. ' is not a valid timer definition. Can only run every 1, 2, 3, 4, 6, 8, 12 hours.', utils.LOG_ERROR)
				return false
			return fitsHourRule(hours)
	-- return true if self.time is at hh:mm / *:mm/ hh:*
	function self.ruleMatchesTime(rule)
		local hh, mm
		local timePattern = 'at% ([0-9%*]+):([0-9%*]+)'
		hh, mm = string.match(rule, timePattern .. '% ')
		if (hh == nil or mm == nil) then
			-- check for end-of string
			hh, mm = string.match(rule, timePattern .. '$')
		if (hh ~= nil) then
			if (mm == '*') then
				return (self.hour == tonumber(hh))
			elseif (hh == '*') then
				return (self.min == tonumber(mm))
			--elseif (hh ~= '*' and hh ~= '*') then
				hh = tonumber(hh)
				mm = tonumber(mm)
				if (hh ~= nil and mm ~= nil) then
					return (mm == self.min and hh == self.hour)
					-- invalid
					return false
		return nil -- no at hh:mm found in rule
	-- returns true if self.time is in time range: at hh:mm-hh:mm
	function self.ruleMatchesTimeRange(rule)
		local fromH, fromM, toH, toM = string.match(rule, 'at% ([0-9%*]+):([0-9%*]+)-([0-9%*]+):([0-9%*]+)')
		if (fromH ~= nil) then
			-- all will be nil if fromH is nil
			fromH = tonumber(fromH)
			fromM = tonumber(fromM)
			toH = tonumber(toH)
			toM = tonumber(toM)
			if (fromH == nil or fromM == nil or toH == nil or toM == nil) then -- invalid format
				return false
				return timeIsInRange(fromH, fromM, toH, toM)
		return nil
	-- returns true if 'moment' matches with any of the moment-like time rules
	function getMoment(moment)
		local minutes, astrologicalMoment
		-- first check if it in the form of hh:mm
		hh, mm = string.match(moment, '([0-9]+):([0-9]+)')
			return tonumber(hh), tonumber(mm)
		-- check if it is before astroMoment
		minutes, astrologicalMoment = string.match(moment, '%.*(%d+)%s+minutes%s+before%s+(%a+)')
		if minutes and astrologicalMoment then
			return minutesToTime(gTimes[astrologicalMoment .. 'inminutes'] - tonumber(minutes))
		-- check if it is after astroMoment
		minutes, astrologicalMoment = string.match(moment, '%.*(%d+)%s+minutes%s+after%s+(%a+)')
			return minutesToTime(gTimes[astrologicalMoment .. 'inminutes'] + tonumber(minutes))
		-- check at astroMoment
		if (gTimes[moment .. 'inminutes']) then
			return minutesToTime(gTimes[moment .. 'inminutes'])
		return nil
	-- returns true if self.time is in a between xx and yy range
	function self.ruleMatchesBetweenRange(rule)
		local from, to = string.match(rule, 'between% (.+)% and% (.+)')
		if (from == nil or to == nil) then
			return nil
		local fromHH, fromMM, toHH, toMM
		fromHH, fromMM = getMoment(from)
		toHH, toMM = getMoment(to)
		if (fromHH == nil or fromMM == nil or toHH == nil or toMM == nil) then
			return nil
		return timeIsInRange(fromHH, fromMM, toHH, toMM)
	-- remove seconds from timeStrings 'at 12:23:56-23:45:00 ==>> 'at 12:23-23:45'
	-- to allow use of rawTime in matchesRule
	local function sanitize(rule)
		if not rule:match("(%w+%:%w+:%w+)") then return rule end
		for strippedTime in rule:gmatch("(%w+%:%w+)") do
			if strippedTime:match("(%w+%:%w+:%w+)") then rule = rule:gsub(rule:match("(%w+%:%w+:%w+)"),rule:match(strippedTime)) end
		return rule
	local function populateAstrotimes()
		local LOOKUPASTRO =
			CivTwilightEndInMinutes = 'civiltwilightendinminutes',
			AstrTwilightStartInMinutes = 'astronomicaltwilightstartinminutes',
			AstrTwilightEndInMinutes = 'astronomicaltwilightendinminutes',
			SunAtSouthInMinutes = 'solarnooninminutes',
			NautTwilightEndInMinutes = 'nauticaltwilightendinminutes',
			NautTwilightStartInMinutes = 'nauticaltwilightstartinminutes',
			CivTwilightStartInMinutes = 'civiltwilightstartinminutes',
			Daytime = 'daytime',
			SunsetInMinutes = 'sunsetinminutes',
			Civildaytime = 'civildaytime',
			Civilnighttime = 'civilnighttime',
			SunriseInMinutes = 'sunriseinminutes',
			Nighttime = 'nighttime',
		gTimes = {}
		for originalName, dzVentsName in pairs(LOOKUPASTRO) do
			gTimes[dzVentsName] = _G.timeofday[originalName]
		gTimes.sunatsouthinMinutes = gTimes.solarnooninminutes
		gTimes.astronomicaldaytime = ( self.minutesnow <= (gTimes.astronomicaltwilightendinminutes or 0) and self.minutesnow >= (gTimes.astronomicaltwilightstartinminutes or 9999))
		gTimes.nauticaldaytime = (self.minutesnow <= (gTimes.nauticaltwilightendinminutes or 0) and self.minutesnow >= (gTimes.nauticaltwilightstartinminutes or 9999))
		gTimes.nauticalnighttime = not(gTimes.nauticaldaytime)
		gTimes.astronomicalnighttime = not(gTimes.astronomicaldaytime)
		return true
	-- returns true if self.time matches the rule
	function self.matchesRule(rule, processed)
		if type(rule) == 'string' and ( string.len(rule == nil and "" or rule) == 0) then
			return false
		-- split into atomic time rules to simplify and speedup processing
		elseif type(rule) == 'string' and not(processed) then
			local rule = rule:lower()
			local validPositiveRules = true
			local negativeKeyword = 'except'
			local function ruleSplit(rawRule)
				local ruleKeywords = 'on, between, every, in'
				local allRules = {}
				local aRule = ''
				for ruleWord in string.gmatch(rawRule, "[%S]+") do -- all "words" separated by spaces
					if ruleKeywords:find(ruleWord) and aRule ~= '' then
						table.insert(allRules, aRule)
						aRule = ''
					aRule = ( aRule == '' and ruleWord ) or ( aRule .. ' ' .. ruleWord )
				if aRule ~= '' then table.insert(allRules, aRule) end
				return allRules or {}
			local positiveRules, negativeRules
			local exceptPosition = rule:find(negativeKeyword)
			if exceptPosition then
				positiveRules = ruleSplit(rule:sub(1, exceptPosition - 1))
				negativeRules = ruleSplit(rule:sub(exceptPosition + #negativeKeyword, #rule))
				negativeRules = nil
				positiveRules = ruleSplit(rule)
			for _, aRule in ipairs(positiveRules) do
				validPositiveRules = validPositiveRules and self.matchesRule(aRule, true)
				if validPositiveRules == false then return false end
				for _, aRule in ipairs( negativeRules) do
					if self.matchesRule(aRule, true) then return false end
			return validPositiveRules
		local res
		local total = false
		local function updateTotal(res)
			total = res ~= nil and (total or res) or total
		res = self.ruleIsInWeek(rule)
		if (res == false) then --in week <weeks> was specified but 'now' is not on any of the specified weeks
			return false
		updateTotal(res)
		res = self.ruleIsOnDay(rule) -- range
		if (res == false) then -- on <days> was specified but 'now' is not on any of the specified days
			return false
		updateTotal(res)
		res = self.ruleIsOnDate(rule)
		if (res == false) then -- on date <dates> was specified but 'now' is not on any of the specified dates
			return false
		updateTotal(res)
		local _between = self.ruleMatchesBetweenRange(rule) -- range
		if (_between == false) then -- rule had between xxx and yyy is not in that range now
			return false
		res = _between
		updateTotal(res)
		if (_between == nil) then -- there was not a between rule.
		-- A between-range can have before/after sunrise/set rules so it cannot be combined with these here
			res = self.ruleIsBeforeAstrologicalMoment(rule) -- moment
			if (res == false) then -- (sub)rule has before xxstart, xxend, sunset, sunrise or solarnoon
				return false
			updateTotal(res)
			res = self.ruleIsAfterAstrologicalMoment(rule) -- moment
			if (res == false) then -- (sub)rule has after xxstart, xxend, sunset, sunrise or solarnoon
				return false
			updateTotal(res)
		res = self.ruleIsAtAstronomicalMoment(rule)
		if (res == false) then -- rule has at xxstart, xxend, sunset, sunrise or solarnoon
			return false
		updateTotal(res)
		res = self.ruleIsAtAstronomicalRange(rule)
		if (res == false) then -- rule has at xxdaytime or xx nighttime
			return false
		updateTotal(res)
		res = self.ruleMatchesHourSpecification(rule) -- moment
		if (res == false) then -- rule has every xx hour but its not the right time
			return false
		updateTotal(res)
		res = self.ruleMatchesMinuteSpecification(rule) -- moment
		if (res == false) then -- rule has every xx minute but its not the right time
			return false
		updateTotal(res)
		rule = sanitize(rule)
		res = self.ruleMatchesTime(rule) -- moment / range
		if (res == false) then -- rule has at hh:mm part but didn't match (or was invalid)
			return false
		updateTotal(res)
		res = self.ruleMatchesTimeRange(sanitize(rule)) -- range
		if (res == false) then -- rule has at hh:mm-hh:mm but time is not in that range now
			return false
		updateTotal(res)
		return total
	return self
return Time
djalexnl
Re: timer
Post by djalexnl »
Just updated, lets see what happends tonight 8-)
Ill let you know :)
Thanks again for the fast fix etc...
waaren wrote: Monday 15 March 2021 23:52
local gTimes --
	local ms = 0
	return s, ms
		local ms
		s, ms = getSMs(s)
		_MS = ms
	return _MS
	if (ms == nil) then
		ms = 0
		offsetMS = 0
	local msDiff
		secs = 0
	local cmp
		cmp = 0
		cmp = -1
		cmp = 1
	return
		math.abs(msDiff),
		math.abs(secs),
		minDiff,
		hourDiff,
		dayDiff,
		cmp
	local dayAdd
	return dayAdd
			weekNum = 1
	return weekNum
	local ms
	local now
	local time = {}
	local self
			return _testMS
			return _getMS()
		now = os.date('*t')
		isUTC = false
		local now
		if (isUTC) then
			now = os.date('*t')
		sDate = makesDate()
		sDate = makesDate()
	-- extract s and ms
	s, ms = getSMs(s)
		day= now.day,
		year= now.year,
		month= now.month,
		hour= now.hour,
		min= now.min,
		sec= now.sec
		msDiff = -msDiff
		secDiff = -secDiff
		minDiff = -minDiff
		dayDiff = -dayDiff
	if (isUTC) then
		self = localTime
		self.utcTime = time
		self = time
	self.raw = sDate
	self.utils = utils
	self.isUTC = isUTC
	self.dDate = dDate
			return utils
				mins = minDiff,
				hours = hourDiff,
				minutes = minDiff,
				days = dayDiff,
		local months =
		return months
		local pattern
			pattern = control
			local index = 1
				index = index + 1
			return os.time(tm)
		return os.time(tm)
			mnemomics =
		return hh, mm
			return nil
				isDayRule = true
				break
			return nil
				return true
				return false
		return nil
			return true
			return true
			return false
			return nil
			return true
			to = tonumber(to)
				return true
				return true
					return true
		return false
			return nil
				return true
		-- wildcards
					return true
					return true
					return true
					return true
				if
				) then
					return true
		return false
		return nil
		return nil
			return true
				return false
				return false
		local hh, mm
		if (hh ~= nil) then
			if (mm == '*') then
				hh = tonumber(hh)
				mm = tonumber(mm)
					-- invalid
					return false
			toH = tonumber(toH)
			toM = tonumber(toM)
				return false
		return nil
		return nil
			return nil
			return nil
		return rule
		local LOOKUPASTRO =
		gTimes = {}
		return true
			return false
				local allRules = {}
				local aRule = ''
						aRule = ''
				negativeRules = nil
		local res
		local total = false
			return false
		updateTotal(res)
			return false
		updateTotal(res)
			return false
		updateTotal(res)
			return false
		res = _between
		updateTotal(res)
				return false
			updateTotal(res)
				return false
			updateTotal(res)
			return false
		updateTotal(res)
			return false
		updateTotal(res)
			return false
		updateTotal(res)
			return false
		updateTotal(res)
			return false
		updateTotal(res)
			return false
		updateTotal(res)
		return total
	return self
return Time
djalexnl
Re: timer  [SOLVED]
Post by djalexnl »
Problem has been solved! Case can be closed ;-)
Thanks again for the fast fix! 8-)
