error loading module 'EventHelpers' from file  [SOLVED]
gsmink
Post by gsmink »
After updating to beta 12690 i get a lot of errors in the domoticz log,
Somebody any idea?
2020-11-28 15:29:51.670 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: error loading module 'EventHelpers' from file '/home/pi/domoticz/dzVents/runtime/EventHelpers.lua':
2020-11-28 15:29:51.670 /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:1101: ')' expected near <eof>
2020-11-28 15:29:51.681 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: error loading module 'EventHelpers' from file '/home/pi/domoticz/dzVents/runtime/EventHelpers.lua':
2020-11-28 15:29:51.681 /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:1101: ')' expected near <eof>
2020-11-28 15:29:52.478 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: error loading module 'EventHelpers' from file '/home/pi/domoticz/dzVents/runtime/EventHelpers.lua':
2020-11-28 15:29:52.478 /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:1101: ')' expected near <eof>
2020-11-28 15:29:52.486 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: error loading module 'EventHelpers' from file '/home/pi/domoticz/dzVents/runtime/EventHelpers.lua':
2020-11-28 15:29:52.486 /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:1101: ')' expected near <eof>
2020-11-28 15:29:52.672 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: error loading module 'EventHelpers' from file '/home/pi/domoticz/dzVents/runtime/EventHelpers.lua':
2020-11-28 15:29:52.672 /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:1101: ')' expected near <eof>
2020-11-28 15:29:52.679 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: error loading module 'EventHelpers' from file '/home/pi/domoticz/dzVents/runtime/EventHelpers.lua':
2020-11-28 15:29:52.679 /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:1101: ')' expected near <eof>
2020-11-28 15:29:53.392 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: error loading module 'EventHelpers' from file '/home/pi/domoticz/dzVents/runtime/EventHelpers.lua':
2020-11-28 15:29:53.392 /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:1101: ')' expected near <eof>
2020-11-28 15:29:53.399 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: error loading module 'EventHelpers' from file '/home/pi/domoticz/dzVents/runtime/EventHelpers.lua':
2020-11-28 15:29:53.399 /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:1101: ')' expected near <eof>
gsmink
Re: error loading module 'EventHelpers' from file
Post by gsmink »
seems like the beta update file is not extracting fine
at the end of ./updatebeta
dzVents/runtime/tests/testDevice.lua
dzVents/runtime/tests/testScriptdzVentsDispatching.lua
dzVents/runtime/TimedCommand.lua
gzip: stdin: unexpected end of file
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
Restarting Domoticz... (please standby...)
root@debian:/home/pi/domoticz#
gsmink wrote: Saturday 28 November 2020 15:46 seems like the beta update file is not extracting fine
If you do this on a Raspberry the latest available Beta is 12705 and that version seem to be ok?
gsmink
Post by gsmink »
i am running on debian
now domoticz showing 2020.2 (build 12707), but still the same errror
after ./updaterelease he should get the latest version
Updating to latest beta version...
Please Standby...
--2020-11-28 15:52:40-- https://www.domoticz.com/download.php?c ... ine=x86_64
Resolving www.domoticz.com (www.domoticz.com)... 104.31.79.142, 104.31.78.142, 172.67.190.40
Connecting to www.domoticz.com (www.domoticz.com)|104.31.79.142|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://releases.domoticz.com/releases/ ... x86_64.tgz [following]
--2020-11-28 15:52:40-- https://releases.domoticz.com/releases/ ... x86_64.tgz
Resolving releases.domoticz.com (releases.domoticz.com)... 146.185.159.228
Connecting to releases.domoticz.com (releases.domoticz.com)|146.185.159.228|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 16384000 (16M) [application/octet-stream]
Saving to: ‘domoticz_beta.tgz’
domoticz_beta.tgz 100%[==========================================================================================================>] 15.62M 4.84MB/s in 3.2s
2020-11-28 15:52:44 (4.84 MB/s) - ‘domoticz_beta.tgz’ saved [16384000/16384000]
domoticz
History.txt
License.txt
domoticz.sh
server_cert.pem
updatebeta
updaterelease
www/
gsmink
Post by gsmink »
"domoticz_linux_x86_64.tgz: download via "https://releases.domoticz.com/releases/?dir=./beta" also corrupt
gsmink wrote: Saturday 28 November 2020 16:12 "domoticz_linux_x86_64.tgz: download via "https://releases.domoticz.com/releases/?dir=./beta" also corrupt
Issue is known and reported on the issue list. I don't have access to the build environment so cannot correct it. :cry:
You could try
sudo wget "https://raw.githubusercontent.com/domoticz/domoticz/development/dzVents/runtime/EventHelpers.lua"
sudo EventHelpers.lua <domoticz dir>/dzVents/runtime/EventHelpers.lua
Or compile domoticz locally.
gsmink
Re: error loading module 'EventHelpers' from file  [SOLVED]
Post by gsmink »
Thx, thats solved the issue,
I don;t know more files are misseng, but waiting for the next bild.
