dzVents error on os.time  [SOLVED]
felix63
Domoticz version: 2020.1
Post by felix63 »
Running dzVents 3.0
Get an error 'time result cannot be represented in this installation' on the statement:
            local convertedTimestamp = os.time({year = runyear, month = runmonth, day = runday})
Doesn't make sense to me... anyone?
Re: dzVents error on os.time
felix63 wrote: Sunday 01 March 2020 21:35 Running dzVents 3.0
Kind of difficult to tell what the problem is without knowing what runyear, runmonth and runday are. This script works as expected.
return
	on =
		devices =
			'makeTimeStampTrigger',
    logging =
        level = domoticz.LOG_DEBUG,                        -- INFO, DEBUG or ERROR
        marker = 'makeTimeStamp'
	execute = function(dz)
        function string2Epoch(dateString) -- seconds from epoch based on stringdate (used by string2Date) -- Assuming a date pattern like: yyyy-mm-dd
    		local pattern = '(%d+)-(%d+)-(%d+)'
    		local runyear, runmonth, runday= dateString:match(pattern)
    		return convertedTimestamp
		dz.log(string2Epoch('2020-03-01'),dz.LOG_DEBUG)
felix63
Post by felix63 »
2020-03-01 23:09:01.293 Error: dzVents: Error: (3.0.1) datestring:2099-12-31
2020-03-01 23:09:01.293 Error: dzVents: Error: (3.0.1) An error occurred when calling event handler status afval2
2020-03-01 23:09:01.293 Error: dzVents: Error: (3.0.1) ...ticz/scripts/dzVents/generated_scripts/status afval2.lua:61: time result cannot be represented in this installation
Re: dzVents error on os.time  [SOLVED]
felix63 wrote: Sunday 01 March 2020 23:14 datestring:2099-12-31
Probably too far in the future for your system.
If I try this date on my system, the return is 4102398000
