.afterMin not working  [SOLVED]
RobbieT
Post by RobbieT »
I've a few scripts that use a .afterMin(). For some reason however this isn't working.
Example; I have the following script:
--Creator: Rob
--Date: 08-10-2019
--Last update: 16-10-2019
--Changelog: Added devices to trigger. Changed function segment. isTimer nog longer used
--Source: -
--Description: Turn on/off heating depending if someone is home or not
        devices = {
            [78] =  { 'between 07:00 and 19:30' } --Trigger is iemand thuis tussen tijd
--Voeg logging toe voor dit script
   logging = {
   level = domoticz.LOG_INFO,
   marker = "Thermostaat automatisch"
    execute = function(domoticz, device, item)
        --Declarations
        local Thuis = domoticz.devices(78) --Is er iemand thuis
        local Toon  = domoticz.devices(116) -- Toon Programma's
    --Function
    if(Thuis.active) then
    Toon.cancelQueuedCommands()
    Toon.switchSelector(30)
    domoticz.log('Toon is automatisch ingesteld op programma Thuis via dzVents')
    domoticz.notify('Thermostaat automatisch', 'Er is iemand thuis. De thermostaat is automatisch op het programma Thuis ingesteld.', 'domoticz.PRIORITY_LOW')
    Toon.switchSelector(10).afterMin(30)
    domoticz.log('Toon is automatisch ingesteld op programma Weg via dzVents')
    domoticz.notify('Thermostaat automatisch', 'Er is niemand thuis. De thermostaat is automatisch op het programma Weg ingesteld.', 'domoticz.PRIORITY_LOW')
The thermostat (Toon) should go to program "Weg" when nobody's home. This should be done 30 minutes after nobody is home. The script but as soon as the virtual switch "Someone Home" is flipped the program "weg" is set instead of after 30 min.
Anyone got a fix for this?
Perhaps useful: I'm running Domoticz on my Synology with a package from Jdahl.
Re: .afterMin not working
RobbieT wrote: Monday 04 November 2019 15:55 I've a few scripts that use a .afterMin(). For some reason however this isn't working.
I cannot replicate this on my systems (Raspberry and Synology) .
Can you share the log from when the switchSelector(xx).afterMin(xx) is triggered ?
Please also include your domoticz / dzVents version
RobbieT
Post by RobbieT »
waaren wrote: Monday 04 November 2019 18:27
Hi Waaren,
I'm running Domoticz Version: 4.10717
Build Hash: b38b49e-modified
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
My log entry is as follows (in dutch)
2019-11-04 14:23:54.059  (Ping) Lighting 2 (Telefoon Rob)
2019-11-04 14:23:54.079  Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2019-11-04 14:23:54.111  (Dummy Switches) Light/Switch (Iemand thuis)
2019-11-04 14:23:54.131  Status: dzVents: Info:  Thermostaat automatisch: ------ Start internal script: Thermostaat automatisch: Device: "Iemand thuis (Dummy Switches)", Index: 78
2019-11-04 14:23:54.132  Status: dzVents: Info:  Thermostaat automatisch: Toon is automatisch ingesteld op programma Weg via dzVents
2019-11-04 14:23:54.132  Status: dzVents: Info:  Thermostaat automatisch: ------ Finished Thermostaat automatisch
2019-11-04 14:23:54.132  Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2019-11-04 14:23:54.151  Status: Notification: Thermostaat automatisch
2019-11-04 14:23:54.840  Notification sent (pushover) => Success
RobbieT wrote: Monday 04 November 2019 19:29 I'm running Domoticz Version: 4.10717
Hi, I only see the loginfo message and the notification in the log but I don't see the selector changing state.
If it switched I expect to see something like
2019-11-04 14:23:54.840 (virtual) Light/Switch (<name of Toon programma Selectorswitch>)
Are you sure the selector actual switched immediate or could it be that you only saw the log and notification?
RobbieT
Post by RobbieT »
waaren wrote: Monday 04 November 2019 20:04
Changed logging to debug and got some more information: I'm sure the selecter immedialty switched. When I turned off my Wifi when in front of the Toon I see the program change.
2019-11-05 08:15:19.377 Status: dzVents: Info: Thermostaat automatisch: ------ Start internal script: Thermostaat automatisch: Device: "Iemand thuis (Dummy Switches)", Index: 78
2019-11-05 08:15:19.377 Status: dzVents: Debug: Thermostaat automatisch: Processing device-adapter for Toon Scenes: Switch device adapter
2019-11-05 08:15:19.377 Status: dzVents: Debug: Thermostaat automatisch: Constructed timed-command: Set Level 10
2019-11-05 08:15:19.377 Status: dzVents: Debug: Thermostaat automatisch: Constructed timed-command: Set Level 10 AFTER 1800 SECONDS
2019-11-05 08:15:19.377 Status: dzVents: Info: Thermostaat automatisch: Toon is automatisch ingesteld op programma Weg via dzVents
2019-11-05 08:15:19.377 Status: dzVents: Info: Thermostaat automatisch: ------ Finished Thermostaat automatisch
2019-11-05 08:15:19.378 Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2019-11-05 08:15:19.397 Status: Notification: Thermostaat automatisch
Besides that, I also have another dzvents with .afterHour and that one isn't working also.
RobbieT wrote: Tuesday 05 November 2019 8:18 Changed logging to debug and got some more information: I'm sure the selecter immedialty switched. When I turned off my Wifi when in front of the Toon I see the program change.
Sorry still don't see the actual switch here.
Let's have a look at that after we found what is causing this. Can the Toon program selector also be switched by another script ?
Can you try this one (I added an extra trigger and some log statements to see what happens.
--Creator: Rob
--Date: 08-10-2019
--Source: -
        devices = {
            [78] =  { 'between 07:00 and 19:30' }, --Trigger is iemand thuis tussen tijd
            116,
   logging = {
   level = domoticz.LOG_DEBUG,
    execute = function( domoticz, item )
        --Declarations
        domoticz.log('State of ' .. Thuis.name .. ' is ' .. Thuis.state,domoticz.LOG_DEBUG)
        domoticz.log('State of ' .. Toon.name .. ' is ' .. Toon.state,domoticz.LOG_DEBUG)
        domoticz.log('Script is triggered by ' .. item.name,domoticz.LOG_DEBUG)
       if item == Toon then
            domoticz.log(Toon.name .. ' was updated ! Was it this script ?' ,domoticz.LOG_DEBUG)
            return
        --Function
        if Thuis.active then
            Toon.switchSelector(10).afterSec(30)
RobbieT
Post by RobbieT »
waaren wrote: Tuesday 05 November 2019 9:01
--Creator: Rob
--Date: 08-10-2019
--Source: -
        devices = {
            116,
   logging = {
        --Declarations
            return
        --Function
Thanks Waaren,
I've added the code and here is the log output (set to Debug inside Domoticz settings)
2019-11-05 09:15:07.905 Status: dzVents: Debug: - Device: Iemand thuis
2019-11-05 09:15:07.916 Status: dzVents: Info: Handling events for: "Iemand thuis", value: "Off"
2019-11-05 09:15:07.917 Status: dzVents: Info: Thermostaat automatisch: ------ Start internal script: Thermostaat automatisch 2: Device: "Iemand thuis (Dummy Switches)", Index: 78
2019-11-05 09:15:07.917 Status: dzVents: Debug: Thermostaat automatisch: Processing device-adapter for Toon Scenes: Switch device adapter
2019-11-05 09:15:07.917 Status: dzVents: Debug: Thermostaat automatisch: State of Iemand thuis is Off
2019-11-05 09:15:07.917 Status: dzVents: Debug: Thermostaat automatisch: State of Toon Scenes is Thuis
2019-11-05 09:15:07.917 Status: dzVents: Debug: Thermostaat automatisch: Script is triggered by Iemand thuis
2019-11-05 09:15:07.917 Status: dzVents: Debug: Thermostaat automatisch: Constructed timed-command: Set Level 10
2019-11-05 09:15:07.917 Status: dzVents: Debug: Thermostaat automatisch: Constructed timed-command: Set Level 10 AFTER 30 SECONDS
2019-11-05 09:15:07.917 Status: dzVents: Info: Thermostaat automatisch: Toon is automatisch ingesteld op programma Weg via dzVents
2019-11-05 09:15:07.917 Status: dzVents: Info: Thermostaat automatisch: ------ Finished Thermostaat automatisch 2
2019-11-05 09:15:07.917 Status: dzVents: Debug: Commands sent to Domoticz:
2019-11-05 09:15:07.917 Status: dzVents: Debug: - Toon Scenes = Set Level 10 AFTER 30 SECONDS
2019-11-05 09:15:07.917 Status: dzVents: Debug: - SendNotification = Thermostaat automatisch#Er is niemand thuis. De thermostaat is automatisch op het programma Weg ingesteld.#domoticz.PRIORITY_LOW#pushover##
2019-11-05 09:15:07.917 Status: dzVents: Debug: =====================================================
2019-11-05 09:15:07.917 Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2019-11-05 09:15:07.937 Status: Notification: Thermostaat automatisch
2019-11-05 09:15:08.500 Notification sent (pushover) => Success
2019-11-05 09:15:37.925 (Dummy Switches) Light/Switch (Toon Scenes)
2019-11-05 09:15:37.931 Status: dzVents: Debug: Dumping domoticz data to /usr/local/domoticz/var/scripts/dzVents/domoticzData.lua
2019-11-05 09:15:37.939 Status: dzVents: Debug: Processing device-adapter for Toon Scenes: Switch device adapter
2019-11-05 09:15:37.939 Status: dzVents: Debug: dzVents version: 2.4.19
2019-11-05 09:15:37.939 Status: dzVents: Debug: Event triggers:
2019-11-05 09:15:37.939 Status: dzVents: Debug: - Device: Toon Scenes
2019-11-05 09:15:37.950 Status: dzVents: Info: Handling events for: "Toon Scenes", value: "Weg"
2019-11-05 09:15:37.950 Status: dzVents: Info: Thermostaat automatisch: ------ Start internal script: Thermostaat automatisch 2: Device: "Toon Scenes (Dummy Switches)", Index: 116
2019-11-05 09:15:37.950 Status: dzVents: Debug: Thermostaat automatisch: Processing device-adapter for Iemand thuis: Switch device adapter
2019-11-05 09:15:37.950 Status: dzVents: Debug: Thermostaat automatisch: State of Iemand thuis is Off
2019-11-05 09:15:37.950 Status: dzVents: Debug: Thermostaat automatisch: State of Toon Scenes is Weg
2019-11-05 09:15:37.950 Status: dzVents: Debug: Thermostaat automatisch: Script is triggered by Toon Scenes
2019-11-05 09:15:37.950 Status: dzVents: Debug: Thermostaat automatisch: Toon Scenes was updated ! Was it this script ?
2019-11-05 09:15:37.950 Status: dzVents: Info: Thermostaat automatisch: ------ Finished Thermostaat automatisch 2
2019-11-05 09:16:00.189 EventSystem: Sending SetPoint to device 'ToonThermostat' (18) ....
2019-11-05 09:16:00.191 (Dummy Switches) Thermostat (ToonThermostat)
2019-11-05 09:16:00.469 Status: dzVents: Debug: Processing device-adapter for ToonProgramInformation: Text device
2019-11-05 09:16:00.469 Status: dzVents: Debug: dzVents version: 2.4.19
2019-11-05 09:16:00.469 Status: dzVents: Debug: Event triggers:
2019-11-05 09:16:00.469 Status: dzVents: Debug: - Device: Temperatuur Binnen
2019-11-05 09:16:00.469 Status: dzVents: Debug: - Device: ToonThermostat
2019-11-05 09:16:00.469 Status: dzVents: Debug: - Device: ToonProgramInformation
RobbieT wrote: Tuesday 05 November 2019 9:17 I've added the code and here is the log output (set to Debug inside Domoticz settings)
What I see in the log that the afterSec(30) works as expected. ( Minutes / hours in afterMin / afterHour are internally converted to seconds )
RobbieT
Post by RobbieT »
waaren wrote: Tuesday 05 November 2019 9:27
So this means?
RobbieT wrote: Tuesday 05 November 2019 9:33 So this means?
It means that .afterSec(), .afterMin() and .afterHour() are working for this device.
RobbieT
Re: .afterMin not working  [SOLVED]
Post by RobbieT »
waaren wrote: Tuesday 05 November 2019 9:35
Well, the only thing really changed, is the begin
        devices = {
            116,
instead of
        devices = {
(The 116 was added).
It looks like that that did the trick, or am I missing something?
RobbieT wrote: Tuesday 05 November 2019 9:45 It looks like that that did the trick, or am I missing something?
Happy that it's working now but adding the 116 was just to show when the device actually changed. Nothing fundamentally changed in the script.
RobbieT
Post by RobbieT »
waaren wrote: Tuesday 05 November 2019 9:55
Ok. Strange strange..
It seems to be something inside the script. When I change your script without the debug log options it isn't working anymore. I changed it to this
--Creator: Rob
--Date: 08-10-2019
--Last update: 05-11-2019
--Changelog: 16-10-2019: Added devices to trigger. Changed function segment. isTimer no longer used | 05-11-2019: Trying to solve the .afterMin not working
--Source: -
        devices = {
            116,
   logging = {
        --Declarations
    --Function
            Toon.switchSelector(10).afterMin(2)
